Re: [bolger] Thinning epoxy results coming
I wouldn't worry too much about fumes, especially at low temps, but AVOID
contacting the liquid components and sanding dust.
Don Hodges
Sent: Thursday, February 15, 2001 3:58 PM
Subject: [bolger] Thinning epoxy results coming
> Thanks for all the info on thinning epoxy. As I said, I hope to use
> thinned epoxy to coat the interior and exterior to waterproof the
> plywood. There were some other good ideas listed, such as using it as
> a slow mix for coating and laying glass. I know not to use it where
> structional strength is important. I will also not use it in the
> garage because of the fumes. Warm weather is coming and I can work
> outside in 40 or 50 degree weather, or at least in the garage with it
> opened up.
> I'll keep good notes on the results, in case someone else needs the
> information.
> Thanks again.
> Claude
> - no flogging dead horses
opened up.
information.
Thanks again.
Claude
