AF4, was Re: midwest messabout
--- In bolger@y..., "John Bell" <jmbell@m...> wrote
> Max,
> We met at last year's Messabout. I had a blast riding around in
your
little
> skiff powered by that wonderful old knucklebuster outboard.
> I've been corresponding with Jim about AF4 and even stuck a check
in
> mail for a set of plans. He said you had an AF4 about ready to go.
My Micro
> project is going on hiatus while I build an AF4 for myself. Since I
already
> have a pile of 3/8 and 1/2" plywood in the garage, my boat will
probably be
> a little heavier than Jim's. Jim told me you built yours with the
same
> scantlings that I'm considering. Have you got any idea about the
weight? I'm
> a little concerned especially since I want a little more furniture
than you
> or Jim did in your boats. I liked the way Jim's boat ran with the
three of
> us aboard and I want mine to do about the same with a full load of
about 500
> lbs of family and gear. How big a motor are you using and how fast
do plan
> to go? I'm figuring you'll need about 20 hp to push it at 15 mph
with a full
> load.
> I just DL'ed the pictures of yours the other night to show my wife.
She
> approved the project on the basis of your photos, so I appreciate
your
> contribution.
> (It's probably blasphemy to say I'm putting the Micro project on
hiatus on
> this group. Rest assured you Micrites, I'll get back to it sooner
or
later.
> A power cruiser just makes more sense for us right now.)
> JB
> From: <cadbury@s...>
> To: <bolger@y...>
> Sent: Friday, March 16, 2001 6:27 PM
> Subject: [bolger] AF4, was Re: midwest messabout
> | --- In bolger@y..., j.c.ewing@h... wrote:
> | > Max, your AF4 looks mighty nice!! I wish it and the Midwest
> | Messabout
> | > weren't so far away so I could get a closer look. As you may
> | recall,
> | > I have considered the AF4; maybe I should at least order plans,
eh?
> | > Tell me what I see on the floor in the AF4 interior photo; is it
> | > plastic lattice and, if so, does it do the job? It makes a
striking
> | > feature asthetically.
> | > --John Ewing (who's catching up on Bolger postings after
returning
> | > from a funeral in cold, cold Ontario to find daffodils blooming
in
> | > Victoria)
> | Good evening: The stuff on the deck that looks like cheap
> | plastic lattice, is cheap plastic lattice. A gentleman
> | over on the Duckworks site was using it in a smaller boat,
> | and it struck me as a good idea- saves wear and tear on the
> | paint; is non-skid; since it is about 3/8" thick, helps keep
> | your shoes dry during rain (when the cockpit will be impossible
> | to keep absolutely dry). It is not fastened down- just lays
> | there so is easy to remove. Only bad points are, it is probably
> | rough on bare feet, and hard to set chairs on.
> | Have not had it in the water yet (picking up a trailer 3/24).
> | The boat did not take long to build. Started the first week
> | of October and the photos were taken the first week of March.
> | Did not do anything on it during Dec. due to extreme cold.
> | Worked evenings and weekends. Lost at least a week to changes
> | I made in the plans (transom and cabin front). And it actually
> | looks halfway decent.
> | Sounds like there will be a good turn-out for the Midwest
> | Messabout this year. Looking forward to seeing a
Michalak-designed,
> | Texas-built Caprice. Wish an AF3 or a Norm's boat would show
> | up. Also like the shantyboats (Harmonica, shanteuse, GP-16, etc.)
> | Have you started the Clam Skiff yet?
> | Later
> | Max
> | Bolger rules!!!
> | - no cursing, flaming, trolling, or spamming
> | - no flogging dead horses
> | - add something: take "thanks!" and "ditto!" posts off-list.
> | - stay on topic and punctuate
> | - add your comments at the TOP and SIGN your posts
> | - To order plans: Mr. Philip C. Bolger, P.O. Box 1209,
Gloucester,
MA,
> 01930, Fax: (978) 282-1349
> | Your use of Yahoo! Groups is subject to
Good evening, Capt. John:
Am considering a Sport dory, like yours, as I am in need of
some exercise. Enjoy your web site, and I, also, have a set
of Micro plans (I think darn near everyone does) Maybe someday...
My AF4 is built out of BC pine exterior; the sides are 3/8";
the bottom is 5/8"; the bulkheads are all 1/4"; the cabin tops
are 5.2 mm luan, and the transom is laminated from 2 layers
of 5/8" BC and one layer of 5.2 mm luan. Butt straps on the sides
are 1 x4, per plans; butt straps on the bottom are 1 X 6, except
the center one is 1 X 8 because there would have been a 1 inch
gap between the forward edge of the butt strap and the center
bulkhead. The chines have (2) layers of 3" tape, but there is
no other fiberglass, and no epoxy coating. Both the primer and
topcoat paints are all latex exterior. Also, only one "keel"
on the bottom, a tapered 2 x 4.
Completed, less motor, motor controls, and steering
controls, the boat weighs 410 lbs.
As I am sure you will remember, Jim's boat was still
able to barely plane with 10 hp, and you, me, and Jim in
it. I weigh all of 230 lbs (and not because of, as Jim delicately
put it on his web site, my "heavy boots and clothes"!),
so I have little doubt the design can stand some extra
weight. Concerning bottom strength, I have the boat
sitting on a pair of 2 ft by 2 ft wheeled dollies, and
see little flex in the bottom as I walk around in it.
The old '57 Johnson 18 hp shown in the pictures is
the same outboard that pushed Jim's @ about 22 mph, and I
think is was a little "over-propped", i.e. too much pitch
in the propeller, so it may have had a little more potential.
I intend to run mostly 15's and 18's on mine, with an
occasional antique of about 9 1/2 hp when I feel the need
to run something "old" (1957 aint "old"). I do not intend
to use anything bigger that the 18's, which I believe
will produce about 20 mph with just me in it. Assuming
flat water, of course. By the way, late model outboards
are rated on prop shaft horsepower- my older ones are not.
After riding around in Jim's AF4, and after building
mine, I think the AF4 is about the best design around for
an 18 foot flat-bottom skiff- very easy and quick to build,
low power requirements, and if someone were to put in
a little more effort than I did, it could be very nice looking
indeed.
To modify a Bolger quote, let's just say that, if one
backs away from mine 20 feet, "... that boat looks real good."
Keep in touch, and put Rend Lake in your travel plans.
Max
Max,
We met at last year's Messabout. I had a blast riding around in your little
I've been corresponding with Jim about AF4 and even stuck a check in the
mail for a set of plans. He said you had an AF4 about ready to go. My Micro
project is going on hiatus while I build an AF4 for myself. Since I already
have a pile of 3/8 and 1/2" plywood in the garage, my boat will probably be
a little heavier than Jim's. Jim told me you built yours with the same
scantlings that I'm considering. Have you got any idea about the weight? I'm
a little concerned especially since I want a little more furniture than you
or Jim did in your boats. I liked the way Jim's boat ran with the three of
us aboard and I want mine to do about the same with a full load of about 500
lbs of family and gear. How big a motor are you using and how fast do plan
to go? I'm figuring you'll need about 20 hp to push it at 15 mph with a full
load.
I just DL'ed the pictures of yours the other night to show my wife. She
approved the project on the basis of your photos, so I appreciate your
contribution.
(It's probably blasphemy to say I'm putting the Micro project on hiatus on
this group. Rest assured you Micrites, I'll get back to it sooner or later.
JB
| Messabout
| recall,
| > I have considered the AF4; maybe I should at least order plans, eh?
| > plastic lattice and, if so, does it do the job? It makes a striking
| > --John Ewing (who's catching up on Bolger postings after returning
| > from a funeral in cold, cold Ontario to find daffodils blooming in
| > Victoria)
| Messabout this year. Looking forward to seeing a Michalak-designed,
| Later
| Max
| Bolger rules!!!
Messabout
recall,
> Victoria)
Later
Max
Max, your AF4 looks mighty nice!! I wish it and the Midwest Messabout
weren't so far away so I could get a closer look. As you may recall,
Victoria)
Max:
I checked out the AF4 pictures - nice boat. I am looking forward to meeting
her in person at Rend Lake.
> Good evening Cap'n Chris:
> Initially, it will be powered with an old OMC 18 hp.
> I have uploaded files with one of these engines hanging
> on the transon. They have gearshifts which occasionlly
> come in handy
> When I get bored with that, I have several old Evinrude
> "light-fours" which are non-shift, 4 cylinder opposed,
> separate-throttle-and-spark engines of about 9 1/2 hp
> that were made from the 30's up to the late 40's.
> Next project may be a sailboat- possibly an AF3 or
> a Norm's boat- I have the drawings for both.
> Later, dude
> Max
come in handy
Later, dude
Max
In bolger@y..., "chris" <manta@l...> wrote:
> hey Max ... I didn't know that you were in this group.... thanks
for the
> comments about " Folly"
> I am looking forward to seeing your AF4.... are you going to power
it with
> an antique motor?
> Chris Flynn
> Flynn's folly
> _/)
> To: <bolger@y...>
> Sent: Tuesday, March 06, 2001 10:44 PM
> Subject: [bolger] Re: midwest messabout
> > --- In bolger@y..., manta@l... wrote:
> > > hey Chuck L. are you planning on attending the midwest
messabout
> > > in June at Rend lake? if so do you know when the dates are?
> > > also is any one else from the Bolger list attending?
> > > Chris Flynn
> > > Flynn's Folly
> > > _/)
> > I am planning on attending. I was there last year with
> > an aluminum boat and a 1940 Johnson. This year I will
> > bring the AF4 I am just finishing up, assuming water
> > trials don't disclose any big problems. Not too bad
> > looking a boat for a first effort, though definetly
> > not up to the "Flynn's Folly" level of spit and polish.
> > Max
Gloucester,
MA,
hey Max ... I didn't know that you were in this group.... thanks for the
I am looking forward to seeing your AF4.... are you going to power it with
an antique motor?
Chris Flynn
Flynn's folly
_/)
> > hey Chuck L. are you planning on attending the midwest messabout
> > Chris Flynn
> > Flynn's Folly
> > _/)
> Max
In a message dated 03/06/2001 8:<BR40:<BR11 PM
Eastern Standard ,mkstocks@...writes:
> Where is Rend Lake, and what is the date of this event?
Just south of Mt. Vernon IL, near KY and IN borders. June 10/11
Cheers/Carron
> Chris Flynn
> Flynn's Folly
> _/)
Max
Rend Lake , is the spring Midwest messabout.. it is located in the
mid-southern part of Illinois. The lake is located about an hour south
of the I-70.... I-57 junction... or just about 20 miles ( I think) south
of the I-57 ..... I-64 junction ... look on an Illinois map and you can't
miss it.
Last year I went and took a few pictures.. I believe that the pictures are
still on the duckwork's website...
www.duckworks.com
also you might watch Jim Michalak's web site for the dates... it is
usually the first weekend in June.. I am not sure what dates are set for it
http://homepages.apci.net/~michalak/
hope that helps!
Chris Flynn
Flynn's Folly
_/)
Sent: Tuesday, March 06, 2001 8:38 PM
> Hi -
> Thanks!
> Mike
> > Chris Flynn
> > Flynn's Folly
> > _/)
> Chris Flynn
> Flynn's Folly
> _/)
> Chris Flynn
> Flynn's Folly
> _/)
Hi -
Thanks!
Mike
> Chris Flynn
> Flynn's Folly
> _/)
Hi Chris:
Yes, I am planning to attend, with Caprice in tow. I am not sure of the
exact date, but I am pretty sure it is in June. Jim Michalak will have the
date on his site. I am looking forward to meeting you and Dave there.
> Chris Flynn
> Flynn's Folly
> _/)
Chris Flynn
Flynn's Folly
_/)
