Re: [bolger] micro trailer
It is best to have the keel fully supported along its entire length by a central
board with chocks that follow the shape of the keel. The two support bunks
merely keep the boat upright and do not support the hull.
My trailer is a converted "caravan" chassis and has suspension and brakes!
Good luck
Daniel
This email and any attachments are confidential and intended for the addressee
only. If you are not the named recipient, you must not use, disclose,
reproduce, copy or distribute the contents of this communication. If you have
received this in error, please contact the sender and then delete this email
from your system.
Hi group,
I'm goling to build a Micro, and I was given a boat trailer
the other day, so I thought I'd get started and modify it. I've seen
the web page on the micro trailer, but the bunk setup has me a little
confused. Is all the weight taken on the keel, at each end of the
lead piece? Can anyone give me a description of how the bunks are
actually set up? Even better, does anyone know of a photo of a Micro
trailer on the web? Has this thread been discussed before?
Col
