RE: [bolger] forward to Bolger group
Do I so want to see this one when its done.
Jim C.
> -----Original Message-----
> From: Chuck Leinweber [mailto:chuck@...]
> Sent: Tuesday, April 10, 2001 1:09 PM
> To:bolger@yahoogroups.com
> Subject: [bolger] forward to Bolger group
> Group:
> Harold Schuller sent me this e-mail after he was unable to post to the
> group. While he is figuring out how to join, at least he can read your
> responses.
> Chuck
> From: <haroldschuller@...>
> To: <chuck@...>
> Sent: Tuesday, April 10, 2001 7:34 AM
> Subject: HELP! GLUB, GLUB! I'M SINKING AT BOLGERS!
> > HELLO MR. LEINWEBER,
> > MY NAME IS HAROLD SCHULLER AND I RECENTLY TRIED TO JOIN THIS GROUP.I
> > AM NOT EVEN SURE YET IF I HAVE A PASWWORD, ETC. I AM NOT VERY
> > FAMILIAR WITH GROUPS, BOLGER, YAHOO ETC, PERHAPS YOU CAN GIVE ME A
> > POINTER OR TWO AND SHOW ME HOW I CAN GET A MESSAE OUT TO A LOT OF
> > THESE BOLGER PEOPLE.. THANK YOU.HAROLDSCHULLER@...AND
> >HAROLDSCHULLER@...
> > I USED TO WORK AS A CABINET MAKER MANY MANY YEARS AGO. I AM ALSO A
> > SEAPLANE PILOT AND HAVE OWNED A NUMBER OF BOATS.
> > I WANT TO BUILD HE GLEN l VERA CRUISE 21 FOOT CABIN CRUISER BECASUE I
> > LIKE OLD CARS, PLANES AND BOATS. I WILL USE THIS BOAT IN THE
> > PROTECTED WATERS OF FLORIDA BAY AND THE HAWK CHANNEL BETWEN THE
> > FLORIDA KEYS AND THE OPEN ATLANTIC. IT IS A RATHER BENIGN BOATING
> > ENVIRONMENT, NO ROCKS OR CORAL HEADS STICKING ABOVE THE SURFACE.
> > BASICALLY SOFT BOTTOM MUD,CORAL TYPE SAND, MANGROVES, ETC. OUT IN THE
> > HAWK CHANNEL, THE REEF THAT IS OFFSHORE THE KEYS IS RARELY LESS THAN
> > FIVE FEET BELOW THE WATER AT LOW TIDE. THEREFORE I WANT TO BUILD A
> > LITTLE LIGHTER BOAT THAN USUAL.I DO THINK THAT I WILL USE A MARIME
> > PLYWOOD 1/2 BOTTOM WITH DYNEL ON IT.
> > IN ORDER TO SAVE WEIGHT WHICH IS MY MAJOR CONSIDERATION SINCE I WANT
> > IT TO BE EASY TO BUILD,TRAILER AND POWER. I AM THINKING OF MAYBE TWO
> > HONDA FOUR STROKES. OR TWO 25 HONDA FOUR STROKES.
> > I CAN SPEND ALL THE MONEY I WANT ON THE BOAT BUT KIND OF ENJOY
> > BUILDING THINGS THAT AE SIMPLE, NOT COMPLEX, LIGHT AND CHEAP. I WAS
> > THINKING OF USING CHEAP EXERIOR PLY ONTHE CHINES AROUND 1/4 INCH UP
> > TO THE GUNWHALES AND HAVING A GOOD SHOP COVER IT WITH A LIGHT COATING
> > OF FIBREGLASS UP TO THE WATER LINE. FROM THE WATERLINE UP I WANT TO
> > SHOW MAHOGANY SO I WAS THINK OF PERHAPS USING A 1/4 EXTERIOR WITH A
> > MAHAGONONY VENEER ON IT. IT SEMS THAT MOST VENEERS ARE KIND OF THIN
> > BUT I BASICALLY WANT TO SHOW MAHAGONY FROM THE WATERLINE UP FOR THE
> > CLASSIC LOOK AND PERHAPS SPRAY THE CHINE FROM THE WATERLINE UP WITH
> > CLEAR EPOXY. IF I GO THIS ROUTE I WOULD NOT HAVE THE SHOP PUT
> > FIBREGLASS ALL THE WAY UP TO THE GUNWHALE BUT ONLY UP TO THE RAIL AT
> > THE WATERLINE.
> > I WAS THINKING OF USING 1'4 PLY WITH A LAYUP OF 1/8 MAHOGANY VENEER
> > BUT THAT IS EXPENSIVE AND A LOT OF WORK.
> > FOR THE DECK I WAS ALSO THINIKING OF GETTING 3/8 EXTERIOR WITH A TEAK
> > VENEER AND IF POSSIBLE AN IMITATION TEAK PLANKING VEENER,LATER
> > SPRAYED WITH A LOT OF EPOXY.
> > FOR THE CABIN WALLS(BULKHEADS) I WOULD LIKE TO GET AROUND 1/4
> > EXTERIOR WITH A LIGHT COLORED VENEER ON ON BOTH SIDES AND THEN SPRAY
> > WITH CLEAR EPOXY.
> > I WOULD USE THE ORIGINAL FRAM KIT FROM GLEN l FOR THE FRAME. I MIGHT
> > PLANE THEM DOWN A LITTLE IN A PLANER TO SAVE WEIGHT, EXCEPT FOR THE
> > KEEL.
> > OF COURSE I WOULD USE A GOOD STRONG THICK TRANSOM.
> > FOR THE COCKPIT/REAR DECK SOLE I MIGHT GO 1/4 EXTERIOR AND LAY SOME
> > TEAK VEENER ON IT.IF I GO THAT ROUTE I MIGHT AS WELL GET A WHOLE
> > SHEET AND VENEER THE GUNWHALES AND FOREDECK AND IF I HAVE ANY LEFT
> > OVER AFTER I DO THE CABIN FLOOR.
> > DOES ANYONE HAVE ANY PROS OR CONS ABOUT MY IDEAS AND DOES ANYONE KNOW
> > OF A PLYWOOD HOUSE IN THE SOUTHERN FLORIDA AREA THAT MIGHT HAVE THESE
> > VENEERS?
> > THANK YOU,
> >HAROLDSCULLER@...
> >HAROLDSCHULLER@...
> - no flogging dead horses
Group:
responses.
To: <chuck@...>
>HAROLDSCHULLER@...
> THE WATERLINE.
> WITH CLEAR EPOXY.
> KEEL.
> VENEERS?
> THANK YOU,
>HAROLDSCULLER@...
>HAROLDSCHULLER@...
