Re: [bolger] Re: MJ sponsons
I have always thought that I would use Plat Monfort's Classic 10 at his web page
http://www.geodesicairoliteboats.com/
If I ever build a small (less than 30') sailboat this is my choice.
At 27 lbs it offers minimum drag, I thought that you could put it right up against the stern quarter
in really heavy going to windward. If you were going down wind it might kite on you, I haven't
thought of a solution to that one yet.
One of the boats fairly high on my list to get built before I go to the great boatshop in the sky is
a Tumlaren. This would be my choice for a dingy.
I have always towed my dinghy's, if the weather is to bad to tow a dingy in it is to bad to be out
in. I have always been prepared to cut them loose, I figure the loss would more than be compensated
for by not having to deal with a Zodiac type.
> Hi -
> That sounds like a lot of dingy. I am building a Nymph for to use as
> a dingy for my MJ.
> Mike
Hi -
a dingy for my MJ.
Mike
--- In bolger@y..., "Seabird Aviation Australia Pty Ltd"
<seabird@a...> wrote:
> The MJ was built to the original design, and I would like to add
the sponsons at some stage. While motoring back yesterday towing an
9' dinghy into a 20 knot head wind and tidal current, apart from
deciding the 4.5 HP outboard was not powerful enough, I also had a
thought that it maybe possible to mount a two piece kayak or
windsurfer type hull, in cradles, either side in place of the
sponsons. This could then be used as a tender when needed.
I think I would be a skeptic about this plan - but that's just my opinion.
Steve Anderson
In a message dated 4/16/2001 7:50:04 PM Eastern Daylight Time,
seabird@...writes:
<< I also had a thought that it maybe possible to mount a two piece kayak or
windsurfer type hull, in cradles, either side in place of the sponsons. This
could then be used as a tender when needed. >>
Since launching my MJ a few months ago, I have kept it anchored in a creek close by.  Being the only boat of this size in the creek that can come and go even at low tide, I have been able to use it quite frequently.
The only problem is that you need a dinghy to get out to it. And then either have to leave the dinghy on the beach or tow it behind.
The MJ was built to the original design, and I would like to add the sponsons at some stage.  While motoring back yesterday towing an 9' dinghy into a 20 knot head wind and tidal current, apart from deciding the 4.5 HP outboard was not powerful enough, I also had a thought that it maybe possible to mount a two piece kayak or windsurfer type hull, in cradles, either side in place of the sponsons. This could then be used as a tender when needed.
Has anyone any ideas where to look for an existing kayak or winsurfer design that may be suitable.
Regards
Peter Adams
Has anyone any ideas where to look for an existing Kayak or windsurfer design that may be suitable.
Regards
Peter Adams
