[bolger] Micro update
BO>Ready to cut now. Question: would you use the port sides as a pattern
BO>for the starboard ones, or do you prefer to redo lofting again?
BO>Best, Pippo
I re-did it for the LS, thinking that tracing the pattern might lead to
inaccuracies. in retrospect, i wouldn't have noticed the 1-2mm
inaccuracies from tracing, becuase they would have been hidden by the
15mm error in the sheer clamps! ;(
Tim & Flying Tadpole
BO>Best, Pippo
>BO>Ready to cut now. Question: would you use the port sides as a patternDearie me - it's slab-sided BOLGER boats we're talking about, not replicas
>BO>Best, Pippo
of historical gems. Bang 'er together and gerrit painted. THEN you'll get
into the water and get some enjoyment out of it before you're kicking up
daisies.
Bill
>Accurate impartial advice on everything from laptops to tablesaws.
>http://clickhere.egroups.com/click/1701
>-- Talk to your group with your own voice!
>--http://www.egroups.com/VoiceChatPage?listName=bolger&m=1
"giuseppe 'pippo' bianco (work)" <bianc-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=1130
first take to lay out - 3 hours? Using that side to lay out the second
will do two things: it will assure the two sides are identical and it
will save you about two hours and 45 minutes!
In cutting out panels, I like to cut a little bit outside the lines and
do the final trim to the line with a low angle block plane. This really
helps fair any wobble you might have had in cutting the curves.
John Bell
Kennesaw, GA
jmbell@...
> Ready to cut now. Question: would you use the port sides as a patternUse the first side as a template for the the second. How long did the
John Bell
Kennesaw, GA
jmbell@...
Hi all - waiting for the time to update the web site, I've completed
the lofting of the sides of the boat. Working on the floor (VERY
uncomfortable, even with knee pads!), it took me about 3 hours to do
everything. Pretty easy, basic stuff. I found a few of the points
clearly off, in particular the forward sheer curve.
Best, Pippo
Best, Pippo
