Re: Loose Moose 2 or AS39 Bill of Materials
--- In bolger@y..., lecabotin@h... wrote:
> Hi
> Until now I have bought 55 sheets of BS 1088 Okoume Ply 1/2, at
about
> $90.00 each. And 10 sheets of Russian Ply(9 ply) for others thing
at
> about $60.00 each. 45 gls of East Epoxy at $4,000.00. 640 bare foot
> of White Ash at $1780.00 Aerosil, Inox screws and Transport:
$600.00
> 1 roll of fiberglass 60 inches by 300 feets 11.3 oz at $1200.00. 2
> rools of fiberglass tape ( dont remember the price). The mast and
> spars will be made of Douglass Fir for about $1200.00. The lead
will
> cost nearly $1500.00. I have found a place 42 x 50 feets for
$565.00
> a month with possibility of heating. 'LE CABOTIN' should be
ensemble
> within 5 months. Next monday we enter in the place, the truck is
> reserve, the big things will begin.
> P.S all price in Canadians dollars ( near 45% of exchange rate)
> I hope that will help you and everybody in any decision...
> Jean in Montreal.
Jean,
are you referring to the AS29 or the Loose Moose 2 (the AS39)?
Because the AS29 requires 55 sheets of 1/2in and you refer to this
number.
For the groups information, here in Queensland Australia boatbuilders
can buy top quality Pacific Maple 12mm (1/2inch) Marine Ply at BS
1088 standard for $A77 a sheet. 9mm (3/8in) is $A65, 6mm (1/4in) is
$A47 a sheet. This includes sales tax.
30 liters of epoxy (don't know gallons? anybody help) is $A430,
cheaper in bulk. this stuff is mixed by a gifted chemical engineer
who also makes an excellent one pack adhesive/filler called Purbond.
I use that in all my woodworking projects and repairs, beautiful
stuff.
The real expensive stuff Down Under is fittings, electronics, etc.
Anything that has to be manufactured past a basic level (as Australia
has almost nil industry anymore). This all comes in from USA or Japan
or Europe at a very expensive price - note the Aussie dollar can only
buy 50c US - but our wages are similar.
sorry for the long rant, but any information is welcome. Thanks Jean,
and good luck mate.
Chris
--- In bolger@y..., c_i_becker@y... wrote:
> Without the plans at hand, I can only estimate the bill of
materials
> for an AS39/LM2.
Hi
Until now I have bought 55 sheets of BS 1088 Okoume Ply 1/2, at about
$90.00 each. And 10 sheets of Russian Ply(9 ply) for others thing at
of White Ash at $1780.00 Aerosil, Inox screws and Transport: $600.00
spars will be made of Douglass Fir for about $1200.00. The lead will
cost nearly $1500.00. I have found a place 42 x 50 feets for $565.00
a month with possibility of heating. 'LE CABOTIN' should be ensemble
Jean in Montreal.
LMII requires more like one hundred sheets of plywood, I'm afraid,
unless you leave out the interior furnishings. You'll also need at
least 150 square yards of fiberglass (more if you double the bottom)
and an ungodly quantity of epoxy. The pivoting mast, which is 10" in
diameter and *must* be built of sitka spruce (aluminum? carbon fiber?)
to keep the counterweight within reason, costs quite a wad all by
itself.
As I recall, Bob Archbald's Wizard, professionally built in the
southeastern US to this design, had US$30,000 worth of materials in
her, plus more than US$70,000 in labor. That was using high quality
marine plywood, bronze fastened, and yacht finished, of course. I
think US$30,000 is what he sold her for, barely used. Resale value is
a hidden cost of any unconventional design,
:o(
porky (david galvin)
> --- In bolger@y..., Phil Smith <pbs@w...> wrote:
> > As I recall the plans are only a couple of hundred bucks. If you
are
> > going to build a Loose Moose or even if you are thinking about it,
> why
> > not get some plans from PB&F to study and dream over?
> > Phil Smith
> Wow! That's relatively cheap....yeah, might do that. I assume you
> mean US dollars, which means $300 US equals over $600 Australian.
> Hmph. damn exchange rates!
> I've looked through BWAOM and tallied up in my head what I think it
> would take, around 70 sheets of 1/2", probably 30-50 gallons of
epoxy?
> Anyhoo, I'm writing to Mr.Bolger so I might order a set of LM plans
> for my old man as well.
> Ta
> Chris
> As I recall the plans are only a couple of hundred bucks. If you are
why
> Phil Smith
would take, around 70 sheets of 1/2", probably 30-50 gallons of epoxy?
Ta
Chris
c_i_becker@...wrote:
> Without the plans at hand, I can only estimate the bill of materials
> for an AS39/LM2.
going to build a Loose Moose or even if you are thinking about it, why
Phil Smith
for an AS39/LM2.
Can someone out there help? My old man wants to build this to retire
on, and needs some sort of building estimate - not costs, as they
vary country to country, state to state, but totals of 1/2" marine
ply, epoxy, paint, stuff like that?
I remember reading that the AS29 uses 55 sheets of 1/2" and 2 sheets
of 1/4".
Ta
Chris
"In theory there is no difference between the theoretical and the
practical. In practice there is."
