Re: divine inspiration
--- In bolger@y..., "Michael Surface" <msurface@h...> wrote:
was an amateur and today could not become a licenced naval architect,
go figure. We also know that Jesus walked on water to visit the
fishermen. We do not know what kind of boat they were in as the
details are sketchy, but I bet that it was similar to the clam skiff.
(there got Bolger boats in!).
"Leaving work early to epoxy"
> DavidYes, I know that Noah was the first boatbuilder of noteable fame. He
> Remember Noah!
Remember Noah!
Get your FREE download of MSN Explorer athttp://explorer.msn.com
Remember Noah!
>From:djost@..._________________________________________________________________
>Subject: [bolger] divine inspiration
>Date: Tue, 01 May 2001 01:52:59 -0000
>Ok, in keeping with the current discussion on Bolger politics,
>libertarianism etc... I know he would disapprove of divinely
>inspired boatbuilding. but it happens. . .
>While listening to the sermon on Sunday, I figured out a quick a
>clever way to get that darned 400 lb. lead keel in place. Today
>after work, I tried it out and the keel is in place and ready for
>sheathing and glass work. This makes the idea divinely inspired. I
>may have to raise my church pledge if this continues.
>1. I placed the keel flat on the starboard side of the cradle under
>the boat.
>2. I attached vertical 1.5" square posts from the port side of the
>keel batten to the cradle. This serves to capture the keel as it is
>lifted to its vertical state.
>3. The keel is lifed with a hydraulic floor jack to vertical.
>4. I temporarily secured more vertical posts on the starboard side
>of the keel batten. The keel can't fall over, but can be slid fore
>and aft.
>5. The keel is positioned in place and screws from the port side to
>the lead hold it in place while the starboard sheathing is drilled
>and fit dry. Next to apply epoxy and nail it shut. the process is
>repeated on the other side and then the whole assembly will be
>sheathed with 6 oz. glass.
>This whole process of lifting and positioning took under an hour with
>no heavy labor.
>David Jost
> "celebrating the moment with a fine Czech pilsner"
--- In bolger@y..., KF4call@a... wrote:
for it. At 200lbs, I would think that it would be a great deal
easier, even if you were to try to lift the keel into a pre-formed
pocket. But the way I did it does not involve jacking the boat way up
in the air which is impossible in my garage due to the electric door
closer being in the way.
I did check with a large T square to be sure that it is not set up
askew.
Good Luck with your project
> Wonderful...I'm going to save it so I remember the procedure.no problem Warren, remember that free advise only worth what you paid
> Any objection if I publish it to the Oldshoe builders group?...the Oldshoe
> has a lead keed installed in a similar manner to that of Micro only it weighs
> in at 200lbs, quite a bit lighter.
> Regards,
> Warren
askew.
Warren
the boat.
and aft.
no heavy labor.
"celebrating the moment with a fine Czech pilsner">>
Warren
>>Ok, in keeping with the current discussion on Bolger politics,libertarianism etc... I know he would disapprove of divinely
the boat.
and aft.
no heavy labor.
the boat.
and aft.
no heavy labor.
the boat.
and aft.
no heavy labor.
