Re: [bolger] Re: ...conflicted
If you're going to glass, do it before turning over (after removing the ties) and filling the seams
on the inside will be very easy and you can use epoxy which is not as thick, and will better flow
into small voids etc. Clyde
> Zip ties should work very well for Gypsy. As you probably know, leave them
> loose until you have them all in place. Get everything lined up then pull
> them snug. If you space them @ 3" intervals you can fillet between them very
> neatly with a 3" putty knife. The ties will come out very easily later.
> Masking tape the seams before you flip it over to prevent lumps on the
> outside. Good luck
> jeb
> - no flogging dead horses
I managed to follow Mr. Payson's tack instructions until I layed the
bilge panels on. That's when I discovered just how inacurate my
sawing skills were so I resorted to the zip ties. It made it a lot
easier to line the panels up and drew them a little closer to each
other as well. As far as flipping the boat, I decided to go ahead
and glue the bottom together so I could flip it without fear. It's
my first boat so I'll tend to be cautious.
I wish you luck on your irrigation project. Myself, I'm taking
Friday off to work on the boat.
Roger S
Roger S
--- In bolger@y..., "Larry Barker" <lgbarker@i...> wrote:
> Zip ties worked well for me when I built my Nymph. I failed
miserably with
> Payson's tack method and his additional suggestion of using a hot
glue gun
> resulted in the Magically Disassembling Nymph. Zip ties were solid
> allowed easy hull alignment before they were tightened.
> One difference from Jack - I didn't take them out. One of the
best things
> about them is that they were soft and sanded away like nothing
after the
> epoxy hardened.
> I didn't think of turning the boat before applying the epoxy but it
sounds
> like a great idea and the zips should hold it just fine.
> Larry
> Who cannot play with boats of any sort until that @#(!
irrigation system
> is up and running.
> From: "Jack E. Bearden" <jalo@i...>
> To: <bolger@y...>
> Sent: Thursday, May 10, 2001 1:39 AM
> Subject: [bolger] Re: ...conflicted
leave them
then pull
between them
> very
later.
on the
> > outside. Good luck
Zip ties worked well for me when I built my Nymph. I failed miserably with
Payson's tack method and his additional suggestion of using a hot glue gun
resulted in the Magically Disassembling Nymph. Zip ties were solid and
One difference from Jack - I didn't take them out. One of the best things
about them is that they were soft and sanded away like nothing after the
epoxy hardened.
I didn't think of turning the boat before applying the epoxy but it sounds
Larry
Who cannot play with boats of any sort until that @#(! irrigation system
is up and running.
epoxy hardened.
Larry
is up and running.
very
> outside. Good luck
In a message dated 05/10/2001 8:<BR54:<BR43 AM
Eastern Daylight ,jalo@...writes:> As you probably know, leave them
back and re-adjust the ties after getting them all in. The chines showed
waves which required cutting the joints with a fine saw and re-epoxying.
There are still ripples in the chines. At the time, I didn't know about wire
ties and didn't think of it myself.
Cheers/Don
> loose until you have them all in place. Get everything lined up then pullThis is imortant. On our Toto, son Bryce and I used wire and we didn't go
> them snug.
Cheers/Don
outside. Good luck
jeb
outside. Good luck
jeb
