[bolger] Re: finish MDO (was 1/4" ply on Work Skiff (was:Questions to Bolger))
MDO has a phenolic face on the "good" side, no filling or sanding required
except at joints.
No 1/4 MDO, it starts at 3/8.
I just built an almost-disposable 12 foot skiff, used 1/4 exterior luan from
Home Depot - I was very pleased with the light weight, smooth face veneer,
and working properties for a small boat. I used some epoxy, some TiteBond
II, and some PL foaming polyurethane glue. If you use chine logs and
screws/nails, the PL works great. I haven't had much luck with polyester;
epoxy is great for taped seams and fillet joints, but expensive if the
"disposable" is your only project.
I would go with the PL, chine logs, and butt blocks - no epoxy or polyester
needed. Oh, and 3/4 or 7/8 stainless or bronze ring nails are great quick
permanent fasteners - just a few needed if you can find them, try a "real"
local hardware store. Predrill before nailing, they will split light
framing.
You can see the skiff at the site in the sig below - link is "12 Foot
Skiff". I took it for one of those "1-hour cruises" today. Great therapy!
Don Hodges
dhodges@...
http://www.ecoastlife.com
except at joints.
framing.
Don Hodges
dhodges@...
To: <bolger@egroups.com>
Sent: Tuesday, December 14, 1999 10:44 PM
Subject: [bolger] finish MDO (was 1/4" ply on Work Skiff (was:Questions to
Bolger))
> >The ease of finishing MDO is the big attraction for me.
> Dumb question: What's different about finishing MDO? I've never even
> seen MDO - it's got a thin plastic coat on one side, right? Is it
> stiffer than plain ply? Does it have any abrasive resistance? How
> expensive compared to regular exterior ply?
> I'm thinking of building an ultracheap Teal or Elegant Punt for two
> years of sailing and rowing in the pond in a park near my house with
> my daughters, aged 2 and 5. It will go on short cruises (an hour or
> less most likely) and be stored in my garage or off the ground under
> a tarp. When I move in 2002 I'll give it away. I'm thinking of 1/4"
> lauan (or MDO), deck screws, whatever glue I have on hand, polyester
> resin on taped joints, leftover latex house paint, polytarp sail.
> Sean Rooney
>sean@...
> Boat buyers and sellers! Do you feel lost in a sea of classified ads?
> Stop treading water and get to iWant.com, the Internet community that
> connects buyers and sellers-FREE! It's all smooth sailing from here.
>http://clickhere.egroups.com/click/1958
>The ease of finishing MDO is the big attraction for me.Dumb question: What's different about finishing MDO? I've never even
Sean Rooney
sean@...
To: <bolger@...>
Sent: Tuesday, December 14, 1999 8:00 PM
Subject: [bolger] Re: Questions to Bolger
snip
> As to your questions about the 15'work skiff: I bought these plans at the
> same time I bought those of Windsprint. I decided to build the Windsprint
> first, as I really wanted to see if I could build a boat that would
actually
> sail. When looking at the work skiff plans, the first thing I noticed was
> lack of permanent molds/bulkheads frames, compared to one of the skiffs
> meant to be built in 1/4. Adding up all the plywood, this thing will be
> HEAVY. Which is actually what I want to replace an aluminum boat that is
> just too light for Tampa Bay. Based on looking at the plans, I think 3/8
> (if you could get some good 3/8) would work; To use 1/4" you'd probably
> want to add a more significant gunwale structure (just add another course
> gunwale, in and out). I'd probably keep the 1/2 or at least 3/8 in the
> bottom (its layered). Never know where you'll find a rock.
I've been thinking a lot about using 3/8" MDO. For building a moderately
cheap and easily finished boat it seems like a good bet. Unfortunately all
my current projects call for 1/4" ply and they don't make 1/4" MDO as far as
I can tell. The ease of finishing MDO is the big attraction for me.
John Bell
Kennesaw, GA
jmbell@...
