Re: [bolger] Japanese Pullsaws
maybe i don't get it, isn't a pull hacksaw just one with the blade in backwards?
Richard
Jim Chamberlin RCSIS wrote:
> Thanks to all of you for the responses. Seems that Home Depot here doesn't
> carry the replacement blades. Thought I would go with another source where
> I could get separate blades and handles. My pull saw is fast becoming the
> only hand saw I use. I even found one source that makes a hack saw blade.
> For those of you who haven't tried one; suggest you pick up a cheaper
> version and have at it. This saw has really improved my crude versions of
> joinery work.
> Thanks, again, group.
> Jim C.
> > From: William Samson [mailto:willsamson@...]
> > Sent: Friday, May 11, 2001 12:57 AM
> > To:bolger@yahoogroups.com
> > Subject: [bolger] Japanese Pullsaws
> > Jim Chamberlin was wopndering where I got my pullsaw.
> > The answer is "Homebase" - which I suspect is the UK
> > equivalent of Home Depot!
> > It was very cheap, but seems to work fine. The blade
> > is very thin and floppy. The trick is to start the
> > cut with the saw at a low angle using the tip of the
> > blade. The great advantage is that it doesn't tear
> > out the grain like an ordinary handsaw (or jigsaw, or
> > circular saw). Also, with that floppy blade, cutting
> > curves is no problem.
> > There's a pic of me in action with it at
>http://www.fortunecity.com/marina/pier/525/peachpie/Page.html
> Incidentally, I find the smaller size is easiest to
> use on plywood up to 1/2" thick.
> Someday I'll treat myself to a really good quality
> one, and no doubt will come back to the list raving
> about how great it is!
> Bill
> ____________________________________________________________
> Do You Yahoo!?
> Get your free @... address athttp://mail.yahoo.co.uk
> or your free @... address athttp://mail.yahoo.ie
> - no flogging dead horses
> 01930, Fax: (978) 282-1349
To invent, you need a good imagination and a pile of junk. --Thomas Edison
joinery work.
Jim C.
Bill
Do You Yahoo!?
Bill
Do You Yahoo!?
