Re: re; pirogue
I recently launched a six hour canoe with a lateen sale based on
the aca rig. The sail worked very well but keep in mind that the
gaff is over 11ft. long which is a little troublsome if you are
trying to stow it while underway. The sale was fabricated out of
ripstop nylon from the local fabric store on a houshold sewing
machine. We used the spar dimesions from one of the aca web sites
and layed out the sail backwards from there. Although the six hour
canoe is not a Bolger design it is very simmilar in construction. I
just recieved the plans for the pirogue and plan to build one in July.
Jim
I like the sound of
> the 44' lateen sail that Ray mentioned, anyone have the dimentions?
> Just looking at the pictures, the pirogue (why not call it what it
> looks like to me, a canoe?) looks like it could be a bit under-
> powered. Any comments?
> Thanx again,
> Rique
I don't have the dimensions of the ACA 44 sq ft sail, but you can go to
www.enter.net/~skimmer/ and check out the ACA page info and photos. I'm sure
someone attached to that site could give you the specs. Although I'm a
novice at this, if you wanted to go with the ACA sail and then wanted more
power, particularly in light winds, you might consider a small jib. I
believe that Bob Halsey who is considered by the ACA folks as a Guru of
sorts, uses a 44 ft ACA sail and an 11 ft jib when he races in the 55 sq ft
C Class canoesail races. Also, if the 11 ft (or more) jib had a furling
attachment, you could increase or decrease the size easily from your seat in
the piroque. My last novice comment is that you might want to consider
having a narrower side deck, maybe 3 inches max so that in moderate winds
you can just slide your weight over closer to the rail inside the piroque,
similar to a canoe, and not have to get up on top except in heavier winds.
Makes for a more relaxing (but still spirited) sail. Please keep me up to
date on your progress since I am also considering building the piroque. Ray
>From:Rique@...
>Subject: [bolger] re; pirogue
>Date: Sat, 12 May 2001 01:20:47 -0000
>Thanx for all the input to my original question, it gives me some
>more perspective to help with my decision.
>my next thoughts are that if it is as stable as most of you have
>said, (except for you, Gregg, but could you not sit on the side-deck
>to stack out?) why not put a bigger sail on it? I like the sound of
>Thanx again,
>Rique
_________________________________________________________________
Get your FREE download of MSN Explorer athttp://explorer.msn.com
Thanx again,
Rique
