Re: Starting myTennessee
I will be using all 3/8" ACX plywood. The local lumber yard had some
nice exterior glue, G1S pieces ($15.69/ea.). I'll epoxy saturate all
the exterior with 3.75 oz. T. glass from the rub rail down. RAKA
suggested the 3.75T because it's very strong but a bit harder to wet
out so I'll try and glass the sides flat on saw horses before
assembly. Above the rub rail I'm thinking of adding a layer of
Mahogany door skins for the old wooden boat look, otherwise I'll
glass that also to keep it from checking.
I will coat the inside with epoxy only where it's exposed to weather
as it's very dry here in Colorado, USA and she'll live on a trailer
covered 99% of the time. With an average humidity of less than 35%
year around, mildew and rot is not common. I'll just give everthing
else several coats of a good preservative/water proofing and paint.
The Tennesse has no chines to tape. It's a vertical sided boat with
external rub rails along the bottom. The bottom glass will protect
the plywood edges at the chine.
This should be a significantly easier boat to build than the Michalak
Frolic I put together. ( a little sister to Chuck Lienwebers
Caprice) Other than 10' bigger it's a straight forward project. (I
hope!)
hope!)
> What kind of plywood? Are you going to "epoxy satuate,"
> cover with cloth, just tape chines???
> Inquirering minds want to know!
> Good Luck!
> Max
Good Luck!
Max
> I've been watching this group for over year now and staying quietbut
> digesting a lot of good information. Just thought I'd let everyonehave
> know that I'll be starting my Tennessee this weekend. I hope to
> it done by next season.and
> This is my third but largest project. Previously I built a canoe
> a 20' Michalak Frolic. My wife and I decided we wanted a motorI
> cruiser for the relaxed side of life so the Tennessee has been
> decided upon.
> Thanks to Chuck Lienweber the sharing of his experience with his
> Tennessee. I've decided to keep it as Bolger designed except for a
> windshield. I figure the designer knows his stuff a lot better than
> do.What kind of plywood? Are you going to "epoxy satuate,"
> Epoxy from RAKA should be here this week and the plywood will be
> bought tomorrow.
> I'm sure I'll be posting some questions too.
> Jeff
Good Luck!
Max
jeff@...wrote:
them. I'm very interested in how Bolger's big plywood boats go together.
Good luck. I hope it is more fun and goes faster than you hope.
Phil Smith
>Please keep us informed. I hope you take a bunch of pictures and post
> I've been watching this group for over year now and staying quiet but
> know that I'll be starting my Tennessee this weekend. I hope to have
Phil Smith
This is my third but largest project. Previously I built a canoe and
decided upon.
windshield. I figure the designer knows his stuff a lot better than I
do.
bought tomorrow.
decided upon.
do.
bought tomorrow.
