Re: [bolger] Rub rails
Both at the same time always, for all longitudinals around the outside edge, chines or sheer rails or
rub rails.
roger99a@...wrote:
> I'm cutting the rub rails for my Gypsy, and I clamped one on to see
> how it would work. When I got it on my boat was twisted. I released
> it, and she went back strait. Will this problem go away when I have
> the second rail on or should I do them both at the same time to avoid
> the twist?
> Roger S
_ _ _ _ _
% Harrywelshman@...
Getting the rub rails on Nymph was simply awful. On Rubens Nymph I
soaked them overnight in the pond, and they bent into place, roughly
clamped into place, with great ease. I let them dry out and the final
location and gluing and screwing was very easy.
Bill Wallace in Houston
Hi
Do both together, clamping/screwing alternately each side, so the strain is
always more or less equal. If one is entirely screwed in place before the
other, the twist will be locked in. The other rail won't be able to
completerly cancel it out when its put on second.
You can tie a string between the loose ends while you fasten the other, to
keep them under control -- doing them together sounds awkward, but it isn't
when you try it.
Have fun.
Jamie Orr
Sent: Saturday, May 19, 2001 11:35 AM
Subject: [bolger] Rub rails
the twist?
Roger S
- no cursing, flaming, trolling, or spamming
- no flogging dead horses
- add something: take "thanks!" and "ditto!" posts off-list.
- stay on topic and punctuate
Roger,
I didn't notice that problem with my Gypsy but I did do both rails at the
same time. Have you glassed the bottom yet? If not, that will stiffen things
up considerably. Try clamping both on and see how it looks--assuming you
have enough clamps (you never have enough clamps).
John
"When one tugs at a single thing in nature, he finds it attached to the rest
of the world." --John Muir--
the twist?
Roger S
