[bolger] Re: finish MDO and lauan
> From: Sean Rooney <sean@...>
> Dumb question: What's different about finishing MDO? I've never even
> seen MDO - it's got a thin plastic coat on one side, right? Is it
> stiffer than plain ply? Does it have any abrasive resistance? How
> expensive compared to regular exterior ply?
Medium Density Overlay (MDO) has a layer of kraft paper in phenolic resin
on 1 or both sides. It is higher quality exterior fir plywood made for
exterior plywood signage and other (?) uses. The MDO surface is flat and
SMOOTH, making that side easy to paint with good results. I am using single
sided MDO on the current boat under construction with the fir side out,
since that will be fiberglassed. The interior (MDO) will be epoxy coated.
> less most likely) and be stored in my garage or off the ground under
> a tarp. I'm thinking of 1/4"
> lauan
I have used Luan to make a couple of canoe/pirogue/kayak type boats with
good results, but coated both side with an epoxy sealing coat. The boats
were only taped at the chines and stems. They are holding up under rough
(read that as we don't care what they look like so we crash into lots of
stuff) usage. But.....
I have also used Lauan to cover lumber drying racks in the open with
nothing on the lauan and it comes COMPLETELY apart in about 6 months. It
apparently must be sealed. Now use pine ACX and it is lasting much better.
UV damage, but no delamination.
> resin on taped joints, leftover latex house paint,
Painted every boat so far with latex inside and out and that lasts just
fine. The Flint river's rocks will scrape off almost any kind of paint and
the latex is easy to recoat.
Richard Barnes
