Re: A Question of Weight
6mm is equal to .236 inches or .945% of 1/4" say .945*25=23.85#. Since
Jim Michalaks numbers are rough approximations I would use the same
numbers ie 6mm=25# etc. The difference is minor (.055%). I assume the
numbers Jim Michalak uses consider waste, glue, paint, framing etc.
Perhaps when you're done with your estimate using Jim's figures you
can just deduct the .055% if you are really concerned about it.
Bob Chamberland
Bob Chamberland
--- In bolger@y..., bgbeck55@y... wrote:
> Okay, I think I have a better question this time. In April '99,
> Jim Michalak wrote a piece about calculating weight based on the
> amount of plywood in the boat. His figures were:
> 1/4" = 25 lbs per sheet
> 3/8" = 37 lbs per sheet
> 1/2" = 50 lbs per sheet
> Question: What is the weight per sheet of 6mm, 9mm, and 12mm okume
> or other marine plywoods per sheet?
West Wind Hardwoods site gives the following for occoume:
6mm 20-21 lbs
9mm 30 lbs
12mm 40lbs.
The site is at:http://www.westwindhardwood.com/
Jamie Orr
Sent: Wednesday, May 23, 2001 7:09 AM
Subject: [bolger] A Question of Weight
- no cursing, flaming, trolling, or spamming
- no flogging dead horses
- add something: take "thanks!" and "ditto!" posts off-list.
- stay on topic and punctuate
6mm 20-21 lbs
9mm 30 lbs
12mm 40lbs.
Jamie Orr
