Re: [bolger] Re: Scrubbing epoxy
I vote for vinagar when getting it out of your hair, as in "just crawl under the boat and place a few
dabs to hold it together". Clyde
John Bell wrote:
> From: <mike_vacanti@...>
> | Even better yet, buy a large box of disposable rubber gloves, wear
> | them religiously and avoid getting epoxy on your hands in the first
> | place.
> | Mike
> No argument there. But even with the best intentions I usually wind up with
> some on me somewhere. That's what happened yesterday.
> - no flogging dead horses
| place.
| Mike
Ok guys,
I guess I left off the part about the cheap latex gloves from
Sears that I always wear 1.49 for six. They are also great to grab
the roller and remove it and gloves at the end of the task. Then the
Lava Soap.
I have tried the vinegar schtick before. It was not as effective
and I had a craving for antipasto for about a week. (no anchovies
please). Please do not use solvents such as lacquer thinner or
acetone on your hands. It is readily absorbed into the skin and may
increase the tendency to develop a sensitivity to epoxy, it is also
a known carcinogen.
Port side is glassed, now waiting to smooth it with a dull paint
scraper at exactly the right time. One more thin coat and off to
more fun things.
David JOst
"enjoying my afternoon off, way too much"
--- In bolger@y..., Chris Crandall <crandall@u...> wrote:
> On Sun, 27 May 2001 StepHydro@a... wrote:
> > I suppose everyone knows gthe vinegar trick? A quick wash with
that,
> > followed by hand soap and your hands are clean.
> I was told directly by Kern Hendricks of System 3 that one should
use the
> vinegar trick on tools, etc., but not on skin.
> There is some concern that the vinegar will react with the hardener
(I
> think), and that we don't know the safety properties of the
resulting
> chemicals, and that the vinegar might actually help the chemicals
pass
> into the skin more readily (ditto with acetone).
> He recommends soap and water--and I think it's an easy and safe
> recommendation to make.
On Sun, 27 May 2001StepHydro@...wrote:
> I suppose everyone knows gthe vinegar trick? A quick wash with that,
I was told directly by Kern Hendricks of System 3 that one should use the
There is some concern that the vinegar will react with the hardener (I
think), and that we don't know the safety properties of the resulting
chemicals, and that the vinegar might actually help the chemicals pass
place.
Mike
--- In bolger@y..., "John Bell" <jmbell@m...> wrote:
> | "scrubbing off the epoxy with Lava soap. It really works quite
> | well, much more tame than solvents."
> Try waterless hand cleaners like "Go-Jo" or "Goop". It works great.
> It only took a minute to get the googe off of me after glassing
the bottom
> of my AF4 yesterday.
> JB in Kennesaw.
followed
> Carron
I find just hot water, soap and a hard brush work fine
I suppose everyone knows gthe vinegar trick? A quick wash with that, followed
Carron
It only took a minute to get the googe off of me after glassing the bottom
JB in Kennesaw.
