Re: converting Windsprint to motorboat
That's an idea.
--- In bolger@y..., "Lincoln Ross" <lincolnr@m...> wrote:
> Another thought. If you only want to go slow, why not row? It's
easy.
> If it's supposed to be a datelike activity, you'll be facing each
> other and there will be very little noise. With a gas motor, you
won't
> be able to talk, and you'll both be looking the same way, probably.
> With a trolling motor you probably won't have a performance
advantage
> over rowing.
> When my s.o. and I go boating, she is really crabby while we get
our
> odds and ends together, but when we get on the water and row, she
> starts to smile.
> You'll want to put an extra pair of oarlocks forward for proper
> balance with two on board.
> --- In bolger@y..., drewnel@p... wrote:
> > Hello listers, long time no post! I have a problem. Because of
> > knockdown my wife and I had last year, she wants nothing to do
with
> > our Windsprint. I was thinking of installing a putt-putt gas
engine
> > or trolling motor on a two by four off the aft thwart to make it
> into
> > a slow motorboat, and am wondering if anyone else has tried this
> > yet. I think it would be the ultimate in slow shore cruising,
> > especially if I finish putting oarlocks on it, and some other
> > accommodations like seats, etc.. Whattaya all think?
> > Drew
Do the 34-50 lb thrust electric trolling motors work very well? How
do they keep from overheating? Does anyone on the list have
experience with their performance/range?
Drew
> I can relate, I have a 3HP Tanaka on my boat, they are noisy!
Cheap, run
> good, efficient for that size, reliable, but noisy!
> Just keep an extra spark plug handy! They are hard on spark plugs.
> Jeff
> From: "Chris Crandall" <crandall@u...>
> To: <bolger@y...>
> Sent: Thursday, June 28, 2001 1:36 PM
> Subject: Re: [bolger] converting Windsprint to motorboat
of a
with
engine
it into
this yet.
especially if
> > > I finish putting oarlocks on it, and some other accommodations
like
> > I've done it with my Teal. I put a 1.2hp Tanaka on it. Aside
from having
> > a noisy engine up so close, it worked out pretty well. My wife
liked it,
> > and we could sit in seats (very low ones made for double-paddle
canoes)
> > rather than on the cockpit sole.
> > Attachment took a little ingenuity, but the noise issue is the
big one.
> > - no cursing, flaming, trolling, or spamming
> > - no flogging dead horses
> > - add something: take "thanks!" and "ditto!" posts off-list.
> > - stay on topic and punctuate
Gloucester, MA,
> 01930, Fax: (978) 282-1349
Bolgerites,
I'm personally in favor of tweaking the Bolger designs, especially Windsprint
since that is the one I built. But why put a motor on it? It rows
beautifully. Or if a motor, why not mount an electric where you normally
mount the rudder? Or mount it on the rudder.
I'm working on converting my Windsprint into a trimaran. Have the akas built
rough, need to finish them and then mount the main hull.
Mike Masten
Another thought. If you only want to go slow, why not row? It's easy.
other and there will be very little noise. With a gas motor, you won't
With a trolling motor you probably won't have a performance advantage
over rowing.
When my s.o. and I go boating, she is really crabby while we get our
starts to smile.
> Hello listers, long time no post! I have a problem. Because of a
> knockdown my wife and I had last year, she wants nothing to do with
> our Windsprint. I was thinking of installing a putt-putt gas engine
into
> Drew
On Thu, 28 Jun 2001staehpj1@...wrote:
> I notice that you said you and your wife were in the Teal. One of the
> other folks on this list is of the opinion that the Teal is unsuitable
> for two adults. I know that this can be a somewhat subjective thing
> depending on conditions and expectations. Care to comment on what you
> feel the capacity is for the Teal under calm conditions and oar power?
Two adults is OK. When it comes to sailing, the Teal is crowded with two
adults. Take the sail, lines, and daggerboard out, and there's room for
two full-size adults.
> from having a noisy engine up so close, it worked out pretty
> well. My wife liked it, and we could sit in seats (very low
> ones made for double-paddle canoes) rather than on the cockpit
> sole.
the other folks on this list is of the opinion that the Teal is
unsuitable for two adults. I know that this can be a somewhat
subjective thing depending on conditions and expectations. Care to
comment on what you feel the capacity is for the Teal under calm
Pete Staehling
I can relate, I have a 3HP Tanaka on my boat, they are noisy! Cheap, run
> > or trolling motor on a two by four off the aft thwart to make it into
> > a slow motorboat, and am wondering if anyone else has tried this yet.
> > I think it would be the ultimate in slow shore cruising, especially if
> > I finish putting oarlocks on it, and some other accommodations like
> I've done it with my Teal. I put a 1.2hp Tanaka on it. Aside from having
> a noisy engine up so close, it worked out pretty well. My wife liked it,
> and we could sit in seats (very low ones made for double-paddle canoes)
> Attachment took a little ingenuity, but the noise issue is the big one.
Cool! I, like Jim, am most concerned with lack of controllability
due to the rockered bottom. My Pirogue with minimum skeg maneuvers
too well to go straight for any length of time without wearing my
butt out making course corrections. I'm going to put a man-sized
skeg on both before I go out again in them.
Drew
> Drew:
> Jim Michalak did this to his birdwatcher. Here are a few details:
>http://marina.fortunecity.com/breakwater/274/1997/1121/
> Chuck
with
engine
into
> > Drew
> Are you sure a LOT of floatation wouldn't do the job?
Unfortunately, the "job" is convincing my wife to get in a boat
again. I don't think making it safer would do that. Thanks, anyway.
Drew
Plus maybe a
> smaller sail? I have thought
> of enclosing areas for floatation with aircraft fabric (Platt
Monfort
> makes whole boats with this stuff). ALso you could add a tiny
> daggerkeel like on singlehanded schooner (but don't do it without
> adding floatation).
with
engine
> into
> > Drew
engine
into
> Drew
About 2 hp max. If you intend to steer with the outboard, mounting
it as far back as possible will help steering. If you intend to
steer with the rudder, you can move the outboard forward a little to
make it easier to start and operate. Most right-handed people perfer
to have the engine mounted to starboard. If you leave the sailing
hardware intact, you will still have the option of sailing when
desired. I don't know if I would take the outboard along when
sailing, however, as a knock-down may drown it.
Max
Are you sure a LOT of floatation wouldn't do the job? Plus maybe a
of enclosing areas for floatation with aircraft fabric (Platt Monfort
adding floatation).
into
> Drew
Drew:
> Drew
Drew
