Re: New file uploaded to bolger (Idaho?)
--- Inbolger@yahoogroups.com, "chodges31711
<chodges@a...>" <chodges@a...> wrote:
> It appears that the boats with rocker (TN & Dak.) are less than
5:1,
> length to width, and the flat bottoms are more than 6:1 (to
make them
> faster??). Is that right?
The length to beam of Dakota is about 4.74:1; however, the
bottom is not immersed until about 5' aft of the stem. With the
rocker, it is a displacement hull and will not be anywhere near as
fast as Idaho or Wyoming. It should be a lot drier in choppy
conditions. My town is on Lake Michigan which can definitely get
choppy.
Dakota's cabin headroom varies from 6'3" to 6'6". It doesn't
appear top heavy. As someone mentioned, the Dakota hull
sides up to the shear are higher in relation to the overall height
than in Idaho. Dakota has a heavy 1 1/2" bottom with a 2' wide 2"
thick full length shoe in addition.
Vince Chew
It appears that the boats with rocker (TN & Dak.) are less than 5:1,
length to width, and the flat bottoms are more than 6:1 (to make them
I also looked at several section drawings and it appears that cabin
height is always near to or less than the width (to prevent being top
heavy?). So max. height for a sneakeasy shelter would be <4 feet,
Idaho- <5 feet. Stand up headroom would be marginal for Tenneessee
(some modified TN Duck Flats boats have stand up shelters, I think)
and generous in the bigger boats. Theory may have holes.
Charles
> Dakota's beam is 2.5 meters (about 8.2 feet). This includes the
> rub rails at the shear, so the beam at the waterline is about 7.95
> feet.
> Vince Chew
I'm not sure about Dakota's width. I have seen
> inconsistent numbers on several sites.
feet.
Vince Chew
I think the State boats are all about the same 6:1, length to width,
except Tenneesee. I'm not sure about Dakota's width. I have seen
inconsistent numbers on several sites. The house height and bottom
rocker vary and do not seem proportional from one size to the next.
The weigth problem with Sharpshooter was people weigth up high and as
stated standing headroom does encourage standing.
Charles
--- Inbolger@yahoogroups.com, "dbaldnz <oink@p...>" <oink@p...>
> You might have to be a little bit careful to raise the
> superstructure of Idaho. Isn't she narrower proportionally than the
> other State class boats? Read Bolgers comments re Sharpshooter in
30-
> Odd Boats.
> DonB
other State class boats? Read Bolgers comments re Sharpshooter in 30-
Odd Boats.
DonB
--- Inbolger@yahoogroups.com, "chodges31711 <chodges@a...>"
> mayby I shall go for a ply house instead of a lumber made.
> > the Idaho 31.
> > Claus
> I think you can make the sheer about 6 inches higher. That will
give
> you more freeboard and keep the house from looking too tall (if
you
> increase the head room). The sides of some of the others like
Dakota
> are proportionally higher than Idaho' sides.
> Charles
> the Idaho 31.
> Claus
I think you can make the sheer about 6 inches higher. That will give
you more freeboard and keep the house from looking too tall (if you
increase the head room). The sides of some of the others like Dakota
Charles
--- Inbolger@yahoogroups.com, "Peter Lenihan <ellengaest@b...>"
<ellengaest@b...> wrote:
> Hi Claus,
> Go to Bolger2,files section.Click on BANTAM folder,it is the
> last file in that folder.
> Peter Lenihan
Many thanks peter!
I thought that boat was a modifide of the Tennessee, Jeff wrote that
on the picture on his website (dreamwater builder of Tennessee,
Frolic, Wyoming) I am glad to hear if the Turtle is based on the
Idaho, mayby I shall go for a ply house instead of a lumber made.
Again Peter, many thanks for your support, I hope to be member of
the club "owner of a finished Bolger boat" Any-way I have started up
the Idaho 31.
Claus
> --- Inbolger@yahoogroups.com, "aquatronclaus <aquatronboat@h...>"
> <aquatronboat@h...> wrote:
> > Where can I find that picture of the Turtle, have just started
an
> > Idaho 31, I really like to see a picture of this boat, who can
help?
> > The link dosn´t work!
> > Claus
Hi Claus,
> Where can I find that picture of the Turtle, have just started an
> Idaho 31, I really like to see a picture of this boat, who can help?
> Claus
--- Inbolger@yahoogroups.com, "Jeff Blunck" <boatbuilding@g...>
> I have never been on either boat but I did do a lot of research
balancing
> the pro's and con's between the Idaho and Tennessee. I have plans
for both
> and have via snail mail gotten some information from Mr. Bolger.
Here is
> why I am currently building a Tennessee instead of the Idaho.
> As designed the Idaho will be faster but use a lot more fuel where
> Tennessee is a displacement design to use minimal fuel but limited
to 2x
> hull speed at best. The Idaho will be more sensitive to weight
distribution
> as an boat with a flat run, where the Tennessee will be more
forgiving with
> a load. The Tennessee is about 10 inches wider with a more
conventional lay
> out for the cabin.
> The Idaho has no rocker in the hull where the Tennessee has full
rocker for
> her draft. Though Phil Bolger claims both are about equal in
handling rough
> weather "to a point" ( what that means I'm not sure), I have a
personal
> belief that a bit of rocker is better anytime you have sizable
waves.
> So again, if you want speed and not concerned about load
sensitivity, go
> Idaho. If you want to be able to cruise and speed isn't a big
issue, go
> Tennessee as she can handle a bit more of a load and not as
critical of
> where it's placed. Also as noted before, because of her rocker the
> Tennessee will handle better in tight quarters such as marinas.
I.E.
> tighter turning radius with less drift.
> My decision was based on personal needs, each of us have our own.
Best of
> luck in you endeavors building either the Idaho or Tennessee.
> Jeff
> From: "Bruce Fountain" <B_Fountain@M...>
> Sent: Tuesday, July 03, 2001 1:39 AM
> Subject: RE: [bolger] New file uploaded to bolger (Idaho?)
> > Can we have a little more information please? Is this a
> > modified Idaho?
> > And on the subject, can anyone give me a quick rundown on
> > the pros and cons of the Idaho vs Tennessee? I must say,
> > the boat pictured below has much nicer lines than the
> > Tennessee to my eye.
> > Bruce Fountain
> > > This email message is a notification to let you know that
> > > a file has been uploaded to the Files area of the bolger
> > > group.
> > > File : /turtle1.jpg
> > > Uploaded by : bysc@i...
> > > Description : IDAHO Like Bolger Boat
> > > You can access this file at the URL
> > >http://groups.yahoo.com/group/bolger/files/turtle1.jpg
Claus
> > - no cursing, flaming, trolling, or spamming
> > - no flogging dead horses
> > - add something: take "thanks!" and "ditto!" posts off-list.
> > - stay on topic and punctuate
Gloucester, MA,
> 01930, Fax: (978) 282-1349
I have never been on either boat but I did do a lot of research balancing
the pro's and con's between the Idaho and Tennessee. I have plans for both
and have via snail mail gotten some information from Mr. Bolger. Here is
As designed the Idaho will be faster but use a lot more fuel where the
Tennessee is a displacement design to use minimal fuel but limited to 2x
hull speed at best. The Idaho will be more sensitive to weight distribution
as an boat with a flat run, where the Tennessee will be more forgiving with
a load. The Tennessee is about 10 inches wider with a more conventional lay
out for the cabin.
The Idaho has no rocker in the hull where the Tennessee has full rocker for
her draft. Though Phil Bolger claims both are about equal in handling rough
weather "to a point" ( what that means I'm not sure), I have a personal
belief that a bit of rocker is better anytime you have sizable waves.
So again, if you want speed and not concerned about load sensitivity, go
Idaho. If you want to be able to cruise and speed isn't a big issue, go
Tennessee as she can handle a bit more of a load and not as critical of
Tennessee will handle better in tight quarters such as marinas. I.E.
My decision was based on personal needs, each of us have our own. Best of
> modified Idaho?
> Bruce Fountain
> > group.
> > File : /turtle1.jpg
> > Uploaded by :bysc@...
> the pros and cons of the Idaho vs. Tennessee? I must say,
> Bruce Fountain
Bruce:
The Idaho has a flatter run aft to allow for a larger motor and planing.
The Tennessee is strictly a displacement boat, but is a little more
efficient at low speeds. The boat in the picture is a "serious" boat,
unlike the Bolger boats mentioned above which are "instant" boats.
Basically they are cheap plywood boxes that can get you on the water with a
minimal investment in time and money. I don't mean to disparage "instant"
boats, either - I have built half a dozen (including Tennessee) and am
wondering what my next one will be.
modified Idaho?
Bruce Fountain
> group.
> File : /turtle1.jpg
