[bolger] Re: bondo
RE: [bolger] Re: bondo
Bondo is good for fairing the hull after you glass and sand etc. gives a nice smooth sandable finish and then paint - works really nice.
Bill Derby
Sent: Monday, December 20, 1999 9:09 AM
To: bolger@egroups.com
Subject: [bolger] Re: bondo
A couple of questions, please.
  I'm building a Zydeco. This is my first boat and I need to know if I can
use Bondo on the inner seams. I've seen this mentioned, but no details, and
the context was not sufficiently clear for me to understand whether this is
a good idea or not. I'm using System 3 on all the surfaces while they are
flat. And I'm finding that the cure rate is very slow, about 24 hours to a
stage where I can handle the parts and a full 72 hours to total cure. Is
this normal?
  The Zydeco is a learning project. If it floats, I want to build a Micro.
   Carlos in Houston
Also, c_byars@...
Want to send money instantly to anyone, anywhere, anytime?
You can today at X.com - and we'll give you $20 to try it!  Sign
up today at X.com.  It's quick, free, & there's no obligation!
http://click.egroups.com/1/332/5/_/3457/_/945709712
eGroups.com Home:http://www.egroups.com/group/bolger/
http://www.egroups.com- Simplifying group communications
Bondo isn't strong at all, although the glass-filled types (kitty-glass)
probably are. They would be a suitable filet to support a glass tape,
although you would have to use a compatible resin, probably polyester. The
polyester bond to wood is generally thought inferior to epoxy, 'though many
have used it (including me) on cheap boats.
Gregg C.
>this normal?
> Carlos in Houston
>Also,c_byars@...
this normal?
Carlos in Houston
Also,c_byars@...
