[bolger] Re: BRICK QUESTION????
In a message dated 12/21/1999 6:00:09 AM Central Standard Time,
HenryClann@...writes:
<< Curtis in /\/\onTana! {=-{> >> >>
"Mooving to Montana...gonna raise some dental floss......"
If you know what song & songwriter that came from you're telling your age...
Larry
In a message dated 12/20/1999 11:00:07 PM Central Standard Time,
berniew@...writes:
<< A building tip, I use sheet rock screws and a drill motor instead of
clamps. They are cheaper, faster and hold in more situations than
clamps. >>
Ok Bernie! Do you just leave the screws in & cut-sand down any protruding
ends? I am abiut ready to cut & fit the lower hull chines, if i get any time
over the (promised) 3 day weekend (Fri-Sat-Sun) unless "bossey" makes us work
Friday. It's all sitting on top pf Windsprint out under the silver tarp,
fence rail, picknic shelter out back. If it doesn't rain i hope to get the
chines done & rest of the frames glued up.
I can't wait to get her done & sailing and see the :"what the hell is that"
looks on the windsurfers faces down at the local "flats" as they sail by me,
with a cold CokaCola in my hand...na na na na....
It was a beautiful day for sailing this last Sunday. Wind but no chop...blue
sky...white puffy clouds.....floating bath tubs everywhere....
Larry
In a message dated 12/20/1999 10:26:39 PM Central Standard Time,
cbarrow@...writes:
<< I glued it all with Weldwood...but it hasn't gone in the water yet, so
who knows if it need more!!!
That's good Curtis 'cause that's basically what i planned to do. Unless
Weldwood has been changed from the formula used back in the 1960s the wood
will break before the Weldwood. We used it on the ply-boat runabout we
rebuilt back in the late 1960s (1967-68) or so. That was one fun little 12'
6" boat.
Larry
Larry,
This is almost a philosophical question, which is, is BRICK a throw
away boat? I have built BRICKS out of nothing but CDX plywood, pine
scraps, roofing nails and Weldwood to actually epoxy/taping the outside
of the chine and side transom seam and painting with left over enamel.
I have never built a "gold plater" BRICK, and that is my answer to the
philosophical question. I think BRICK is about as close to a throw away
boat as you can get. Please do no imply from this that I have any
pejorative thoughts towards BRICK. It is just that BRICK delivers more
joy for less concern than any other boat. The one justification I can
see for building a fancy BRICK is to practice fancy techniques.
clamps.
Bernie
Self-promotion at the expense of others
Only hurts those who try it.
> You Brick builders; did you tape & epoxy the interior hull chines, or
> just
> >>glue-eopxy every thing up real well on attaching the bottom? I have
> to find
> >>my C-clamps so i can start attaching my frames to transomes &
> hullsides....
>>BRICK QUESTION????
just
to find
hullsides....
>>Larry H.
