Re: re:lesson learned
Whatever you use, be sure to test some with the epoxy you will use,
unless those statements that some epoxies stick to things others don't
are just marketing claims.
--- In bolger@y..., wattleweedooseeds@b... wrote:
> I usually use plastic shopping bags underneath. Since they are now
> made too thin to recycle as rubbish bags and too small also i just
> put one or two under the joint ,they peel straight off. Also used
> them as Emergency glueing gloves!!
> Cheers Paul
Cheers Paul
