Re: folding schooner question
Based on my discussions with Leander (who met with Payson), Payson
did not like or use the Bolger-designed latches. At least one Payson-
built boat had straps fastened thru the bilge keels, rather than thru
the chines.
If built as designed, the chines have a lot of hole thru them in way
of the daggerboard trunks. Payson thought that strength might be too
much reduced.
--- In bolger@y..., stephen@p... wrote:
> Hello Mitch: The plans for the folding schooner also appear (very
> much reduced) in Dynamite Payson's original "Instant Boats." All
> three sheets are there, but the keyed instructions, which may
contain
> additional information, are not included.
> I'm puzzled by your reference to holes "on the bottom of the
boat."
> If this is accurate, the latches may not have been built to the
plans
> I'm looking at.
> As best I can tell, the plans show two sets of hardware: four
> large "hinge brackets" mounted on the deck, and two "chine latches"
> mounted on the SIDES of the exterior chine logs (near the bottom,
but
> not ON the bottom). (The latches, of course, hold the boat "open"
> while sailing.) The dimensions for the latches are listed as 3" x
> 1'0".
> If you like, I'll try to scan an blow-up of the latches at the
office
> tomorrow and send it to you via e-mail.
> Stephen Paskey
> --- In bolger@y..., mitchfeeney@y... wrote:
> The problem is this: the metal bracket mounted on the keel that
holds
> the two halves together is missing. There are two holes drilled on
> either half of the keel, on the bottom of the boat, below the
> hinges. I am looking to replace these brackets. Does anyone have
> the dimensions of them so that I can have one made . . .
three sheets are there, but the keyed instructions, which may contain
I'm puzzled by your reference to holes "on the bottom of the boat."
If this is accurate, the latches may not have been built to the plans
I'm looking at.
mounted on the SIDES of the exterior chine logs (near the bottom, but
1'0".
If you like, I'll try to scan an blow-up of the latches at the office
Stephen Paskey
The problem is this: the metal bracket mounted on the keel that holds
Our friend Leander is still looking to have latches made for his
Folding Schooner. If you solve the mystery, be sure to share the
secret with him.
--- In bolger@y..., Stuart Crawford <scrawford@p...> wrote:
> Plans for the Folding schooner and their latch's are in the
book "The
> Folding Schooner" by P.C. Bolger. I would suggest having a look in
> library for it, unless some one else scans them into the files.
> Stuart Crawford.
> on 7/8/01 2:41 AM, mitchfeeney@y... at mitchfeeney@y... wrote:
> > Hi-
> > I am currently in the process of restoring a folding schooner that
> > was built by the Payson Boatyard in '73. She is a fine boat and
is
> > starting to look pretty sharp now that she has been repainted.
The
> > boat came to me via Lake Sunapee, NH where she had been sailed on
> > off for the past 20 years. As far as I know she has not been in
> > water for 5 or 6 years.
> > Now that she is painted, we are very close to a launch date. The
> > the dimensions of them so that I can have one made, or do you
know of
> > any pre-made for sale? Any help would be greatly appreciated.
> > Thanks,
> > Mitch Feeney
> > - pls take "personals" off-list, stay on topic, and punctuate
> > - add your comments at the TOP and SIGN your posts, snip all you
like
Gloucester, MA, 01930,
> > Fax: (978) 282-1349
Plans for the Folding schooner and their latch's are in the book "The
Folding Schooner" by P.C. Bolger. I would suggest having a look in the
Stuart Crawford.
on 7/8/01 2:41 AM,mitchfeeney@...atmitchfeeney@...wrote:
> Hi-
> was built by the Payson Boatyard in '73. She is a fine boat and is
> starting to look pretty sharp now that she has been repainted. The
> boat came to me via Lake Sunapee, NH where she had been sailed on and
> off for the past 20 years. As far as I know she has not been in the
> problem is this: the metal bracket mounted on the keel that holds the
> the dimensions of them so that I can have one made, or do you know of
> Thanks,
> Mitch Feeney
> - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930,
> Fax: (978) 282-1349
Hi-
Mitch Feeney
