Re: [bolger] Mast hoops
That sounds like a good way, and would appeal to me.
Steaming and riviting would probably be just as easy,
or easier, so it shouldn't be discounted out of hand.
--- prthober <prthober@...> wrote:
<I <BR>
am thinking of laminating the hoops from long thin
strips of wood - <BR>
is there a better way
Find, Connect, Date!http://personals.yahoo.ca
Maybe you could cut them out of plywood and round off the edges. You would
waste a lot of plywood, though, unless you could use the offcuts as beer
coasters.
Howard
John Leather (in The Gaff Rig Handbook) gives the traditional diameter as
being one and a quarter times the OD of the mast at the boom.
I've heard of folk using slices of plastic pipe as hoops - not very salty
but cheap and effective.
Cheers
Derek
What is the correct dimension for mast hoops in relation to mast
diameter so that they do not jam when raising or lowering the sail? I
am thinking of laminating the hoops from long thin strips of wood -
is there a better way?
Paul
<<(Hey, maybe we could use a septic tank to make a Brick! Hey,
ferro-cement hulls!)>>
Well, this is our version of "Junkyard Wars," isn't it??
CM
http://www.angelfire.com/mi/mmmkkk/
(Last of the Red Hot DJs)
Michalak has an essay on this, somewhere in the archives of his site,
or at least he used to. www.apci.net/~michalak
--- In bolger@y..., dcraig@w... wrote:
>snip; seems
unnecessary
> with a leg-o-mutton sprit sail on a teal.
> Next fat question: Is there any way to reef that kind-o-sail,
> particularly if it's polytarp? And are there any other sail designs
> for the teal?
--- In bolger@y..., <darus@v...> wrote:
> There was a web page somewhere out there by someone selling plans to
build a
> couple different boats out of PVC tubing.
Those gotta be ugly boats.
> I think the drawback of this idea is that PVC is kinda heavy.
The white stuff used for septic field drainage is probably lighter
than the black.
--- In bolger@y..., "david galvin" <porcupine@d...> wrote:
I've also seen mast hoops simply lashed to eyelets set in
> sail's luff, but then why use a hoop? Just lash the sail to the mast
> and save the complication and expense,
Sounds right, that's what Lincoln said in an earlier post. I
expect hoops are only necessary where you're raising and lowering the
sail with a halyard, as on a big mast on a big boat; seems unnecessary
for the teal?
> Here's a thought: How about capped and sealed PVC tubes for hard
> rigid flotation devices? For what, I don't know. Maybe a raft.
> Outriggers. Buoys. Docks. Square life preservers. I expect it's been
> done already.
There was a web page somewhere out there by someone selling plans to build a
Comments below....
> --- In bolger@y..., "Harry W. James" <welshman@p...> wrote:
> > Others have discussed the fact that you probably don't need
> > mast hoops for the Teal, but I got to thinking anyway. How
> > about slicing PVC pipe in to thin circles and sanding the
> > edges, for hoops. I am sure that this is not a new idea,
> > does anybody know if it works?
> Sounds like a great idea, Harry. It still needs a connector
> between the ring and the sail. Maybe an S-hook?
Pert Lowell Co., Inc. (Lanes End, Newberry, MA 01950; phone:
978-462-7409; no web page or E-mail) sells these really neat little
cast bronze mast hoop fasteners. One half is sewn to the sail, the
other is screwed to the hoop, and they lock together and come apart
with a twist--very tidy and secure. They are a bit expensive, as I
recall. I've also seen mast hoops simply lashed to eyelets set in the
david galvin
That black rigid PVC pipe will last a long time out in the sun.
Some years ago, I made a drop-in-rack for my pick-up out of black PVC
(got my cue from those people who make lawn furniture out of it) to
carry a 17-foot wood and canvas canoe. A very light weight rack, but
strong, cost about $60 in materials and two hours work. That rack sat
in the back yard, when it wasn't in the truck, for about 7 years of
hot summers and sub-zero winters. The pipe lost its shine but didn't
seem to lose any strength - in other words it didn't crack, split or
disintegrate.
done already.
Don
This was recommended to me by a first-rate builder from the North
Fork. His work is super high-end, so I'd guess it would work fine. He
preferred the green PVC because it's UV resistant.
>HJ
>dcraig@...wrote:
>> I've rowed the Teal, now that I'm rigging it to sail I'm wondering
>> what to do about mast hoops. I'm almost considering something as
>> simple as those plastic electrical ties, the kind that cops and bounty
>> hunters use to tie somebody to a car bumper. Or should I use the
>> wooden rings that drapery hangers use? Or is there something else?
>> Don
>- pls take "personals" off-list, stay on topic, and punctuate
>- add your comments at the TOP and SIGN your posts, snip all you like
>- To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
CRUMBLING EMPIRE PRODUCTIONS
134 West 26th St. 12th Floor
New York, New York 10001
(212) 247-0296
> Don
wondering
bounty
> Don
Hi Don, Hoops are not necessary and the Teal does not have halliards
for raising or lowering the rig. The sail from Mr Payson has grommets.
Merely tie the sail at the grommets to the mast; tie off with a square
knot. I used heavy twine and it works fine. Tie the knots tight, the
taper of the mast keeps the rig from sliding down. Electrical ties
would work fine except they don't untie readily.
Bob Chamberland
Are hoops necessary? Can't you just use loops of chute cord or
something. We're still using braided rope that's a bit too thick on
our Brick. If I recall, the Teal rig is like the Brick rig and doesn't
have a halyard, so there's no critical need for easy sliding.
Electrical ties sound pretty effective, actually.
wondering
bounty
> Don
Don
