Re: SKIMMER
On Fri, Jan 9, 2015 at 7:38 PM,welshman@...[bolger]<bolger@yahoogroups.com>wrote:I built a Work Skiff on 10.5" centers rather then 12" to shorten it up to fit on
the aft deck of the classic yacht I skipper. Looks way better than the rigid that
used to be there. I have put these pics up before, hopefully not boring
this is probably the tack I will take I have built several bolger boats that turned
> out well even after SLIGHT MODS LIKE A 14 FOOT WORKSKIFF :) instead of a 15"6" one
> just had ta "WIGGLE" THE SEATS/THWARTS A LITTLE
Dave Gray
PolySail International
Leigh Ross
On Jan 8, 2015, at 12:41,jmeddock@...[bolger] <bolger@yahoogroups.com> wrote:
Would be a good use of an extra sheet of plywood if you can stand the extra weight. Probably best to add another thwart or frame at the butt or make a foredeck a few feet long. Now we've made it too heavy to cartop or lift in the back of a pickup and increased power needed to plane to make our 12 footer. Made it cost nearly as much as a similar size jon boat.
I always thought widening the center skid to a 1x6 and doubling it may help light load top speed. This would be irresponsible and encourage shenanigans and I'm all for that sort of thing. Would be tempted to add a 3rd layer of center skid if it didn't break free.
I built one years ago and gave it away before I used it.
Has anyone ever added a foot or 3 to skimmer by simply adding a butt jointed extra pannel to the back end of either side and of course not building a "zipper" into the boat thanks guys
I send you this file in order to have your advice
See you later. Thanks
