[bolger] Re: Bobcat or Surf
Here are my figures for the surf.
Montauk Home Depot
4 sheets 1/4" ACX fir $100 $60
100 feet 2x4 fir $ 50 $25
3 gallons raka 2:1 epoxy $120
10 yards raka 4 oz cloth $ 50
1 big bag of rake glass dust $ 12
misc. raka glassing tools $ 10
1 gallon porch paint $ 33 $20
Shraeder gudgeons and pintels $ 50
Some rope
A thrown away jig with 13' luff
TOTAL $425 $347
This is enough glass to do the topsides as well as the bottom, and
enough resin to do the job twice (which you'll need the first time
out,) and enough paint to paint another boat. I didn't glass the
topsides of my teal, and did glass the topsides of my scooner. No
comparison on how the two of them are weathering.
134 West 26th St. 12th Floor
New York, New York 10001
(212) 247-0296
Montauk Home Depot
Some rope
TOTAL $425 $347
>Well, there can be a lot of variation depending on what materials youCRUMBLING EMPIRE PRODUCTIONS
>use. AXC fir, or marine plywood? If marine, will it be fir,
>Malaysian Meranti or Bruynzeel? Polyester or epoxy resin? On Surf,
>will you sheath the entire outside, just the bottom, or not at all?
>Real sail or polytarp? Trim of mahogany or mystery "whitewood" from
>Home Despot? House paint, marine enamel, or 2-part polyurethane?
>That said, I did a rough calculation for Bobcat, assuming epoxy
>resin, Malaysian marine plywood, relatively decent wood for trim and
>spars, and Kirby's paint. I also added the price of a sail from
>Payson, and a moderate amount of Harken Hardware. This is what I'd
>use if I were building her myself.
>8 sheets 6mm plywood @ $30 ea - $240
>½ sheet 19mm plywood $60
>2 gallons epoxy resin @ $30 ea $120
>Fillers for epoxy $50
>15 yds glass cloth @ $8 /yd $120
>40 yds glass tape @ $3 /yd $120
>Other wood $200
>Fasteners $45
>Paint 3 Quarts. @ $20 $60
>Sail $425
>Rope $50
>Hardware $100
>Miscellaneous and optimism $200
>Total $1900
>Of course you could cut this down by twenty or 30 percent by using
>cheaper materials, and by a lot if you scrounged well. I'd guess
>that Surf would be about half of that, FWIW.
>Keith Wilson
>--- In bolger@y..., John Kennedy <john.kennedy@g...> wrote:
>> What is the best guess for the cheapest price of putting together
>> (a) Bobcat and (b) Surf?
>- pls take "personals" off-list, stay on topic, and punctuate
>- add your comments at the TOP and SIGN your posts, snip all you like
>- To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
(212) 247-0296
Hello again John, For materials you might want to check out
www.noahsmarine.com/canada, warehouse in Ladysmith, BC, Main
location is Toronto all of which would be a fair walk.
Bob Chamberland
Bob Chamberland
Other wood $200
Fasteners $45
Sail $425
Rope $50
Hardware $100
Total $1900
Keith Wilson
Other wood $200
Fasteners $45
Sail $425
Rope $50
Hardware $100
Total $1900
Keith Wilson
best
estimate for building it including sails is US$1591. This is using
better material than marine fir and not as good as Brynzeel or
equivalent.
Plywood 8sheets @ $55=440, Epoxy $150, Mast $30, Boom $10, Gaff $10,
Sail (from Mr Payson) $420, Plans and book $56, running rigging $50
Lead $50, Fibreglass cloth $115, Fibreglass tape $20, Hardware, I'm
guessing at $100, Contingencies $140, Total US$1591. Probably the
biggest saving would be in making your own sail. Cheaper plywood
might
save a few dollars but at the expense of longevity. I think BobCat is
a nice enough boat to use good quality and it is not a whole lot more
than your original $1000 budget. But then these prices are US
dollars.
I started with the mast but have been delayed by a renovation project
on a Cape Dory Typhoon. When I get rid of everything else I will have
the Typhoon and a BobCat. I plan to work very slowly on the Cat and
have a quality boat at completion.
Bob Chamberland
> What is the best guess for the cheapest price of putting together(a) the
> Bobcat and (b) Surf?there's
> I'm on a limited budget and can scrounge with the best of them, but
> always a limit.Hi John, I have purchased the plans for BobCat from Mr Payson. My
> Thanks, folks.
> John S. Kennedy
best
equivalent.
might
dollars.
Bob Chamberland
What is the best guess for the cheapest price of putting together (a) the
I'm on a limited budget and can scrounge with the best of them, but there's
always a limit.
Thanks, folks.
John S. Kennedy
always a limit.
Thanks, folks.
John S. Kennedy
