Re: What is checking ?
--- In bolger@y..., Chris Crandall <crandall@u...> wrote:
> On Fri, 24 Aug 2001 director@p... wrote:
> > Chris, can you then paint it with latex primer, or do you have
> > use oil base?
> but I cannot recall for sure if I used the shellac-based original
Kilz.
I suspect it was shellac based, IMHO, because I think that would do
the trick over linseed oil.
Don Craig
On Fri, 24 Aug 2001director@...wrote:
> Chris, can you then paint it with latex primer, or do you have to
> use oil base?
My memory is fuzzy on this, to be honest. I believe that I used Kilz
water-based as the primer on my last DF plywood boat, over linseed oil,
but I cannot recall for sure if I used the shellac-based original Kilz.
In short, I dunno.
use oil base?
Don Craig
> A great way to minimize checking in fir is to use linseed oil. After
> you're all glued up, but before painting, a complete flooding of
linseed
> oil (unboiled first, followed by boiled), will minimize checking *a
lot*.
> The oil will interfere with epoxy and other glues, so use it post
glue.
> You can then prime and paint it just fine. It's worked for me.
I had a pirogue for many years (see other discussion) that was
painted with oil based paint (I think) and it checked like crazy with
little fine cracks every 1/4" or so. This happened pretty early on
in its lifespan and there was never any rot. This was in the intense
heat and humidity of South Louisiana. The boat was stored both
outside and inside over the years.
Frank
> Sounds like a great tip!
> Jeff
> From: "Chris Crandall" <crandall@u...>
> To: <bolger@y...>
> Sent: Friday, August 24, 2001 10:53 AM
> Subject: Re: [bolger] Re: What is checking ?
After
linseed
*a lot*.
glue.
> > - pls take "personals" off-list, stay on topic, and punctuate
> > - add your comments at the TOP and SIGN your posts, snip all you
like
Gloucester, MA,
> 01930, Fax: (978) 282-1349
> you're all glued up, but before painting, a complete flooding of linseed
> oil (unboiled first, followed by boiled), will minimize checking *a lot*.
> The oil will interfere with epoxy and other glues, so use it post glue.
Just sand smooth and repaint. If the cracks are large, you can use filler
such as Bondo or good wood filler to smooth things out.
It'll be an annual event usually.
Sent: Friday, August 24, 2001 10:08 AM
Subject: [bolger] Re: What is checking ?
> Okay so what if you have not used epoxy or glass on a boat and one of
> the panels start to check? My Starboard panel was checking before i
> painted it. So I sanded it and filled some of the deep grooves and
> sanded some more and painted it.
> What should I do if other panels start to check now that the boat is
> already painted?
> Todd
> > > Well what is checking ?
> > Cracks, large and small that open up in the surface of the wood.
> Usually
> > caused by the different rates of expansion / contraction from the
> different
> > wood densities found in many plywood products, especially Fir and
> Pine.
> > Glass is very strong with epoxy if strong and stops this expansion
> on the
> > surface anyway not allowing the cracks to develop.
> > From: "Todd" <bitme1234@y...>
> > To: <bolger@y...>
> > Sent: Thursday, August 23, 2001 10:06 PM
> > Subject: [bolger] What is checking ?
> > > thanks ,
> > > Todd
> > > Bolger rules!!!
> like
> Gloucester, MA,
Sand, fill and paint again. Don't lose sleep over it, annual maintenance
should keep things in order. Our fir plywood Blue Jay lasted for years with
no more than its annual painting. It checked, but the paint filled the
cracks and we never had any rot. It spent the summers in fresh water, and
the winters upside down under the snow.
JamieOrr
Sent: August 24, 2001 9:09 AM
already painted?
Todd
Usually
different
Pine.
on the
> To: <bolger@y...>
> > thanks ,
> > Todd
like
Gloucester, MA,
already painted?
Todd
Usually
different
Pine.
on the
> To: <bolger@y...>
> > thanks ,
> > Todd
like
Gloucester, MA,
Cracks, large and small that open up in the surface of the wood. Usually
caused by the different rates of expansion / contraction from the different
wood densities found in many plywood products, especially Fir and Pine.
Plywood is rotary cut from the tree using a blade to shave a thin veneer off
the tree trunk. Some woods have different densities of wood fibers from the
center to the outside of the trunk, even around the branch locations. When
all is glued up into a panel there is no real way to match densities. Hence
as the sun and temperature change each layer and/or density will want to
expand at different rates and direction. It's a very strong pressure which
cracks the epoxy easily.
Glass is very strong with epoxy if strong and stops this expansion on the
> thanks ,
> Todd
Small splits or cracks in the surface of the wood caused by surface
stress, aging, drying, weathering, etc -
Don
> thanks ,
> Todd
thanks ,
Todd
