Re: How do I detect hidden dryrot?
--- In bolger@y..., John Kennedy <john.kennedy@g...> wrote:
> I'll never forget the dull "thud" of dry rot when I tap on rotten
wood (had
> another plywood boat once!), BUT, is there some way of detecting dry
rot in
> the frames which might be hidden by otherwise sound deck and
top-side
> plywood?
> Any suggestions as to how to inspect those hidden areas?
> Thanks, everyone.
Hi John,
I think tapping with a plastic hammer will indicate when something is
amiss. Either bad glue joints or dry rot. I wouldn't worry about the
sealed volumes; they are not likely to have the requisite moisture
content for rot. Where you are replacing panels you can inspect
visually. Bad glue joints at this stage might possibly indicate rot. I
would concentrate on the centerboard trunk and really give it a good
going over. Do the fore and aft decks cover sealed compartments? I
think the previous storage conditions may indicate whether you could
have a problem or not. If well stored you are probably worrying
needlessly.
Bob Chamberland
Boat is OT (Fireball), but I don't think the question is.
The Fireball has plywood bulkheads, strengthened by frames. The fore and
aft decks conceal some of the forward and aft frames.
I'll never forget the dull "thud" of dry rot when I tap on rotten wood (had
another plywood boat once!), BUT, is there some way of detecting dry rot in
the frames which might be hidden by otherwise sound deck and top-side
plywood? I don't have an X-ray machine, unfortunately, and my x-ray
vision only works on what my nine-year-old gets up to when it's TOO quiet in
the house (grin).
Thanks, everyone.
