Re: welding advice needed
Uploaded file to "photos" section
--- In bolger@y..., wattleweedooseeds@b... wrote:
> --- In bolger@y..., "Richard Spelling" <richard@s...> wrote:
> > welded some stainless for the boat tonight with the SS flux core
> wire. beaded up real bad, (see picture), didn't appear to mix in
with
> the base metal. Any thoughts?
> > Held ok when boring the hole out on the lathe, though.
> > Richard, I've never had any luck with flux cored wire. A
> boilermaker friend tells me that the flux goes off if left unused
or
> warmed , cooled, warmed , etc. it is often affected by moistureas
> well , and is not very tolerant of alloy variations.
> on the other hand stainless stick rods have few of these
problems ,
> except the moisture . Keep em dryand sealed. Theyare great flat ,
> up ,down ,on most ferrous alloys except cast. Oh and dont use more
> than the suggested amps! i had a 1.6 mm rod melt when 1/4 used ,
> messy,messy, ouch burnies!!!. watch the slag as it pings off hot
> fast. one good reason for safety goggles
> cheers, Paul]
Thanks. I use flux core wire all the time for carbon steel. Differnt
brands react differently, with Lincoln working the best and FireWire
a close second.
This is SS flux core. It looks like the surface tension is way to
high, tonight I'll try cleaning the work better, and pre-heating with
the oxy-propane torch. I had it on the highest heat setting of my
little wire feed welder, but my best working theory is that it wasn't
hot enough.
Sorry, no picture. Yahoo snipped it. I'll stick one in photos.
If worst comes to worst, I'll have a friend stick weld the stuff.
Would like to weld it myself, though.
a close second.
hot enough.
with
or
problems ,
> cheers, Paul]
on the other hand stainless stick rods have few of these problems ,
messy,messy, ouch burnies!!!. watch the slag as it pings off hot and
cheers, Paul]
> welded some stainless for the boat tonight with the SS flux corewire. beaded up real bad, (see picture), didn't appear to mix in with
>boilermaker friend tells me that the flux goes off if left unused or
cheers, Paul]
welded some stainless for the boat tonight with the SS flux core wire. beaded up real bad, (see picture), didn't appear to mix in with the base metal. Any thoughts?
