Re: Pressure treated wood
Plain cheap roofing tar, applied hot, will do the job of sealing end
grain. If you want to get fancy you can even cut it with kerosene so it
penetrates better. It is also handy for filling in all sorts of nooks
and corners in a traditional framed boat where fresh water might
otherwise collect.
Tom K
otherwise collect.
Tom K
> Date: Fri, 28 Sep 2001 09:17:12 -0400 (EDT)
> From: thomas dalzell <proaconstrictor@...>
> Subject: Re: Re: Pressure treated wood
> Unless you cut both ends off, there is usually
> something left to stick in the ground. As far as
> posts are concerned, has anyone tried soaking the
> treated or untreated endgrain in epoxy prior to
> burrying? I am thinking of post ends.
Why does this remind me of P.D.Q. Bach?
--- In bolger@y..., pateson@c... wrote:
> "Flower Trellis" is one of the lesser known early
> designs of M. Francis Hereshoff, half-brother to L.
> He called it a "Cat Crawl".
I suggested that the "Slats" be closer together,
and maybe calked, but again they didn't listen
to me, just saying "Build it as drawn."
Still haven't gotten my check.
Pat
Pat
--- In bolger@y..., jhkohnen@b... wrote:
> Who designed Flower Trellis? I know it wasn't Bolger, maybe Billy
Atkin?
> I always wear a lifevest when out on the water in a Flower
Trellis. ;O)
> Pat Pateson wrote:
> I built a Flower Trellis for a customer a few
> months ago, and they insisted that I build it
> of all pressure treated wood, instead of my
> suggested Cedar.
> On Thu, 27 Sep 2001 16:39:43 EDT, Mark wrote:
> > I'd advise the wearing of
> > lifevest on this boat
> > Mark
> John <jkohnen@b...>
>http://www.boat-links.com/
> Correlation does not imply causation; except, of course, to
your cat.
> <Craig O'Donnell>
Who designed Flower Trellis? I know it wasn't Bolger, maybe Billy Atkin?
I always wear a lifevest when out on the water in a Flower Trellis. ;O)
suggested Cedar.
suggested Cedar.
> Mark
John <jkohnen@...>
Correlation does not imply causation; except, of course, to your cat.
<Craig O'Donnell>
---cha62759@...wrote:
<HR>
<html><body>
<tt>
Hi Pat,<BR>
I would avoid burying any fresh cut ends of posts. If
you must bury <BR>
fresh cut ends I would suggest soaking the ends in a
bucket of <BR>
whatever was used originally or what the treatment
association <BR>
recommends. I assume you being out there in the
western rainforest <BR>
you are using treated hemlock or douglasfir. I would
brush the same <BR>
stuff on any cuts out of the ground. I've been away
from that scene <BR>
for quite a while but I believe that if you dig around
<BR>
www.wwpinstitute.org you will find that after the
stuff dries if will <BR>
be harmless to the flowers. But then you said you have
built it so <BR>
this is all after the fact. To answer your original
question if it's <BR>
out of the ground (untreated bits) it will probably
hold up but not<BR>
as <BR>
well as it would if fully treated. There should be no
trouble glueing.<BR>
Bob Chamberland<BR>
--- In bolger@y..., pateson@c... wrote:<BR>
</tt>
<br>
<tr bgcolor=#FFFFCC>
</tr>
<tr bgcolor=#FFFFFF>
href="http://rd.yahoo.com/M=210544.1579876.3135161.1261774/D=egroupweb/S=1705065791:HM/A=776675/R=0/*http://ads.track-star.com/adspace.ts?ts=1;2;217;107_220_105_264"target=_top><img
src="http://us.a1.yimg.com/us.yimg.com/a/di/dietsmart/300x250_11_12.gif"alt="Lose
20 lbs by November 12th" width="300" height="250"
</tr>
src="http://us.adserver.yahoo.com/l?M=210544.1579876.3135161.1261774/D=egroupmail/S=1705065791:HM/A=776675/rand=758685692"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
topic, and punctuate<BR>
snip all you like<BR>
- Unsubscribe:
<br>
<br>
of Service</a>.</tt>
</br>
</body></html>
Do You Yahoo!?
Get your free @... address athttp://mail.yahoo.ca
<HR>
<html><body>
<tt>
Hi Pat,<BR>
you must bury <BR>
bucket of <BR>
association <BR>
brush the same <BR>
<BR>
built it so <BR>
hold up but not<BR>
as <BR>
Bob Chamberland<BR>
> A question of general information.<BR>pieces,<BR>
> <BR>
> I built a Flower Trellis for a customer a few<BR>
> months ago, and they insisted that I build it<BR>
> of all pressure treated wood, instead of my <BR>
> suggested Cedar. <BR>
> (Floweres were probably not very happy about<BR>
> their decision.)<BR>
> <BR>
> Question is. I had to Rip some of the
> for slats, and could see the "pressuretreated" <BR>
> part only going about 1/2" or so into thewood.<BR>
> Also ends of pieces that were cut.<BR>thinks he's<BR>
> <BR>
> Any "Experts" (I know, everybody here
> an "Expert", including me.) that knowwhether this<BR>
> is going to hold up to weather over the longrun.<BR>
> <BR>treated wood?<BR>
> Also, what about "Glueing" pressure
> <BR><BR>
> Thank<BR>
> <BR>
> Pat Patteson<BR>
> Molalla, Oregon<BR>
</tt>
<br>
</tr>
</tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
Do You Yahoo!?
--- In bolger@y..., maosborn@a... wrote:
near the surface, it is still green all the way through.
swimming yet.
Regardless, it will be epoxy coated to help stabilize the wood.
> Quality treated lumber will be treated to a depth of 2" We haveripped and
> or crossed cut several thoiusand board feet in the last year. Onlyon 6/6
> have I seen a lack of full penetration.I'm with you there, even though the green of the treatment is darker
> If you are exposeing untreated woodstability. I
> it will surley rot. I would also be concerned about the wood's
> have seen 2/6 turn into pretzels overnight. I'd advise the wearingof
> lifevest on this boatRightttttt.. I've used this stuff before on boats, and haven't gone
> Mark
swimming yet.
Quality treated lumber will be treated to a depth of 2" We have ripped and
or crossed cut several thoiusand board feet in the last year. Only on 6/6
have I seen a lack of full penetration. If you are exposeing untreated wood
it will surley rot. I would also be concerned about the wood's stability. I
have seen 2/6 turn into pretzels overnight. I'd advise the wearing of
Hi Pat,
I would avoid burying any fresh cut ends of posts. If you must bury
fresh cut ends I would suggest soaking the ends in a bucket of
whatever was used originally or what the treatment association
recommends. I assume you being out there in the western rainforest
you are using treated hemlock or douglasfir. I would brush the same
stuff on any cuts out of the ground. I've been away from that scene
www.wwpinstitute.org you will find that after the stuff dries if will
be harmless to the flowers. But then you said you have built it so
this is all after the fact. To answer your original question if it's
out of the ground (untreated bits) it will probably hold up but not
as
well as it would if fully treated. There should be no trouble glueing.
Bob Chamberland
as
Bob Chamberland
> suggested Cedar.
> their decision.)
> Question is. I had to Rip some of the pieces,
> for slats, and could see the "pressure treated"
> part only going about 1/2" or so into the wood.
> Any "Experts" (I know, everybody here thinks he's
> an "Expert", including me.) that know whether this
> is going to hold up to weather over the long run.
> Also, what about "Glueing" pressure treated wood?
> Thank
> Pat Patteson
> Molalla, Oregon
Pressure treated lumber is call such because chemicals are forced into the
grain usually of southern yellow pine under pressure. The moisture and some
chemicals work their way back out of the wood over the first couple of months
after treating. This is why you should not paint treated lumber right away
but you should apply a stabilizer. SY pine is used because it readily will
absorb moisture which makes it great for pressure treating it also readily
gives off its moisture, hence the need for a stabilizer, if left to absorb
and release moisture the wood will crack, warp, and tear it's fasteners
loose. What you see may be the results of partial drying and off gassing of
the treatment. Most manufactures give their products a life expectancy of
between 40-50 years. PL makes a treated lumber adhesive for gluing up treated
lumber. Be sure to wear to dust mask and wash up after handling this lumber
as some of the chemicals used are not very friendly. In years past things
like arsenic were used.
Hope this helps
Jim
Hope this helps
Jim
The treatment is for rot prevention, not holding up to the weather.
All the home shows recommend you treat the cut ends, as you noticed,
the presure treatment only goes in so far.
That said, even if you dont treat the cut areas, it is still better
than untreated wood. I'm going to seal all the exposed cut ares with
epoxy and milled glass fiber. I'm hoping the milled fiber will work
like cloth to prevent checking
If you are making thin slats, use thin stock to start with.
Or, if you are really concerned, laminate thicker sections up out of
3/4" (nominal 1") boards, which should have the treatment all the way
through.
Epoxy sticks to presure treated wood just fine.
through.
> suggested Cedar.
> their decision.)
> Thank
> Pat Patteson
> Molalla, Oregon
suggested Cedar.
their decision.)
Thank
Pat Patteson
Molalla, Oregon
suggested Cedar.
their decision.)
Thank
Pat Patteson
Molalla, Oregon
