Re: [bolger] widening holes . . .
I was reading through some of the other replies, and I realized I had
missed the 6" long part. This would be a pretty hard way to accurately
drill out a 6" long 2" hole over a 1" one.
"Harry W. James" wrote:
> Bill
> You have to do this a lot in house building when you screw up on hole
> size for plumbing. Make a plywood square, drill it out with your 2"
> hole saw. Center it over your 1" hole and you can use it as an outside
> bearing without the center bit, to drill an accurate hole. To hold it
> down, you can use screws and repair later, or test out a lot of double
> sided tape, or maybe a glue gun.
> HJ
> Bill Samson wrote:
> > Hi guys,
> > Following the interesting thread regarding rudder stocks for Micro, I've got
> > a notion to change the one in my Chebacco.
> > When I built her I put in a 1" dia galvanised steel stock, which has been
> > fine in most ways, except that the diameter is too small to get a decent
> > tiller attachment at the top, so I've always had tillers that have developed
> > a waggle after sitting on the mooring with tiller lashed for a week or two
> > while the seas bash the rudder around.
> > A 2" dia steel pipe would be much less prone to such wear and I'm minded to
> > replace the smaller stock with this.
> > My problem is this - I already have a 1" dia hole (6" long) in the bottom of
> > the hull to accommodate the stock. How can I widen this to 2". My 2" bit
> > works fine in solid wood where the central spike has something to screw
> > into. I've thought of gluing a 1" dowel in the hole, but this would present
> > end-grain to the screw on the bit, and probably wouldn't work too well.
> > All inspired ideas will be gratefully considered.
> > Thanks in advance!
> > Cheers,
> > Bill
> > PS Yesterday was end-of-season and the moorings need to be lifted, so I
> > hauled my Chebacco using our tiny Peugeot 206 hatchback, and trailed her up
> > the hill to our house. Ain't light displacement boats great?
Screw your 2" hole saw onto the arbor as usual. Then screw on a 1"
hole saw. It will stick out about 1/4". This will act as a pilot
for you 2" saw keeping it concentric as it drills. Works every time!
Bill
Bill Samson wrote:
> Hi guys,
> Thanks in advance!
> Cheers,
> Bill
McFeely's sells what they call an "Oops arbor". This is a hole saw
arbor within a hole saw. With the hole saw you would have to cut some
chisel some which would indeed be tedious in cramped quarters
Bob Chamberland
-- In bolger@y..., KF4call@a... wrote:
> I have seen these for sale in a catalog...don't remember which one
but I have
> > What you need is a piloted counterbore. This just means that
your 2" drill
> > has a protrusion ahead of it that fits the 1" hole that is
already there.
> > This causes the drill to follow exactly the old hole. It is
possible to
> > make such a tool, if you can't find one.
I have seen these for sale in a catalog...don't remember which one but I have
Alden, Woodworkers Supply, McFeely, Amazon and a number of the other common
ones.
Warren
n a message dated 9/30/2001 10:27:04 AM Eastern Daylight Time,
chuck@...writes:
> Hi, Bill.
> What you need is a piloted counterbore. This just means that your 2" drill
> has a protrusion ahead of it that fits the 1" hole that is already there.
> This causes the drill to follow exactly the old hole. It is possible to
Hi, Bill.
<snip> My problem is this - I already have a 1" dia hole (6" long) in the
bottom of
present
Thanks in advance!
Bill
Hi guys,
Thanks in advance!
Bill
