Re: Of Sawhorses and Gunwales
Bob, thanks for your reply. I agree with you that I have a paint
problem. In the last month I have sanded the exterior and repainted.
However, I have not had a chance to get at the tops of the gunwales
and the interior. I hope to have the opportunity to do that this
month, weather permitting. If not, I will take care of it in the
spring.
Dennis Marshall
--- In bolger@y..., cha62759@t... wrote:
> Hi Dennis,
> The way I read it you have a paint problem. Sooner or later you
will
> be stripping off the old paint and repainting. I don't know what
> Featherwind looks like but if it's an open boat try supporting the
> boat on sawhorses from the inside of the boat, either resting the
> thwarts if any on the sawhorses or the floorboards resting on
> supports. If paint is stripping off it would seem it is not
properly
> cured. Or if you painted over epoxy perhaps you didn't prepare the
> epoxy surface to take the paint. If this is outside storage be sure
> that the carpet can't get wet.
> Bob Chamberland
> --- In bolger@y..., PseudoDion3@a... wrote:
> > Hi, all. I have Inscrutable, the Carnell version of Featherwind,
> > upside down on sawhorses for winter storage. In order to protect
> > gunwales, I tacked some old carpet on the sawhorses. However,
this
> > has not worked out. The weight of the boat causes the gunwales to
> > stick to the carpet and when I lift the boat off of the horses,
> paint
> > and even wood inevitably peels off with it. AARRGH! What can I
use
> to
> > protect the gunwales without slowly destroying the finish and the
> > wood?
> > Thanks,
> > Dennis Marshall
Hi Dennis,
The way I read it you have a paint problem. Sooner or later you will
supports. If paint is stripping off it would seem it is not properly
Bob Chamberland
> upside down on sawhorses for winter storage. In order to protect the
> gunwales, I tacked some old carpet on the sawhorses. However, this
paint
> and even wood inevitably peels off with it. AARRGH! What can I use
> wood?
> Thanks,
> Dennis Marshall
stick to the carpet and when I lift the boat off of the horses, paint
and even wood inevitably peels off with it. AARRGH! What can I use to
wood?
Dennis Marshall
