Re: [bolger] online marine directories
I was going to respond to this and forgot. The best site of maritime
links on the web.
http://www.boat-links.com/boatlink.html
I am sure somebody sent it to you but if not, then here it is.
Levent OZDEMIR wrote:
links on the web.
> hi all,
> We have prepared a web site for our yacht building
> firm, and I wish to submit its URL to yachting/
> boating portals like boatbuilder.com
> But I dont know much sites. I searched on yahoo but I
> found only 4 or 5 marine directories.
> So at this point I need your help to find such portals
> and submit my site.
> Can you send me URLs of these portals?
> Thank you
> Levent OZDEMIR
> Naval Architect
>http://www.orionyachting.com
> D
http://www.mcmaster.com/cgi/loadpage.cgi?pagenum=1854&descid=7296
Look at the bottom under "cold galvanizing compounds"
--- In bolger@y..., willsamson@y... wrote:
> > If it's only the top that is causing grief, why not have a wider
> piece
> > welded to the top for the tiller to attach to? It could be
square
> sided to
> > allow more bearing surface, which would cut down the wiggle even
> more.
> I'd thought about that, but the wider bit at the top couldn't be
> galvanised in situ, and would prevent the rudder and stock from
being
> drawn out through the hole for galvanising - unless you know of an
> effective alternative to hot-dip galvanising that can be done on
> boat?
> At the moment, Chuck Leinweber's suggestion of a pilot 'plug' fixed
> to the 2" auger bit sounds feasible. I could make the plug from
> hardwood and epoxy it onto my 2" bit. I hope that would be strong
> enough - and then it could be removed later. Alternatively, a
piece
> of copper tubing could be used as the plug, and soldered onto the
2"
> bit. No great problem to un-solder it afterwards.
> Thanks again for all your thoughtful replies.
> Bill
hi all,
and submit my site.
Thank you
Levent OZDEMIR
Naval Architect
Do You Yahoo!?
Listen to your Yahoo! Mail messages from any phone.
http://phone.yahoo.com
and submit my site.
Thank you
Levent OZDEMIR
Naval Architect
Do You Yahoo!?
> If it's only the top that is causing grief, why not have a widerpiece
> welded to the top for the tiller to attach to? It could be squaresided to
> allow more bearing surface, which would cut down the wiggle evenmore.
galvanised in situ, and would prevent the rudder and stock from being
effective alternative to hot-dip galvanising that can be done on the
boat?
enough - and then it could be removed later. Alternatively, a piece
of copper tubing could be used as the plug, and soldered onto the 2"
Bill
Hi -- My earlier reply to Bill's note was returned due to server problems.
This may be irrelevant now but here it is anyway!
Hi Bill
If it's only the top that is causing grief, why not have a wider piece
welded to the top for the tiller to attach to? It could be square sided to
allow more bearing surface, which would cut down the wiggle even more.
For cutting a bigger hole, I've seen (in books, maybe Chappelle's) cutters
mounted on shafts that are the same diameter as the original hole -- that
keeps it centred. You could possibly do a home made cutter with a hardwood
shaft and the cutter from an extension bit from a bit and brace set.
Jamie
Hi Bill
Jamie
