Re: Redwood?
I used cheap pine for the chine logs on my AF3 sharpie, but I built
the mast out of redwood because it was the only straight, clear 16'
stock they had (a Lumber Yard in Colorado Springs, CO). It was kind
of expensive, but the end result was good. I chose stock that didn't
have much sapwood and then cut to avoid all sapwood. I had to plug
only one 3/4" knothole. The mast is plenty bendy and doesn't seem
too brittle.
scarfing pictures:
http://www.geocities.com/sanmi/creamcheese/scarf1.jpg
http://www.geocities.com/sanmi/creamcheese/scarf2.jpg
http://www.geocities.com/sanmi/creamcheese/scarf3.jpg
too brittle.
scarfing pictures:
--- In bolger@y..., jonpit@y... wrote:
> It is true that redwood is generally light , soft and easily
splits
> along the grain. But, in many years of working with it I've
noticed a
> great range of variation in the material. "Redwood" refers to
Sequoia
> sempervirens - the coast redwood which is used for lumber. The
Giant
> Sequoia that groes in the Sierras is another material. Old, slow
growth
> Redwood tends to be a completely different material which seems
denser
> across grain and less prone to split. It also has more tannins and
rot
> resistance. It is readily available in large unmolested pieces from
> water and wine tanks, old beams and ext. architectural elements.
> , w --- In bolger@y..., boatbuilding@g... wrote:
> > Redwood is never mentioned as an option for boat building. I was
> > just curious as to why that may be. It has reasonable rot
> > resistance, if allowed to dry good and epoxy coated would
stable. I
> > know it may not perfect but for stringers and bilge areas, would
it
> > be a decent option? Epoxy coated, it would last the life a any
wood
> > boat.
> > Curious?
> > Jeff
It is true that redwood is generally light , soft and easily splits
along the grain. But, in many years of working with it I've noticed a
great range of variation in the material. "Redwood" refers to Sequoia
sempervirens - the coast redwood which is used for lumber. The Giant
Sequoia that groes in the Sierras is another material. Old, slow growth
Redwood tends to be a completely different material which seems denser
across grain and less prone to split. It also has more tannins and rot
> resistance, if allowed to dry good and epoxy coated would stable. I
> know it may not perfect but for stringers and bilge areas, would it
> be a decent option? Epoxy coated, it would last the life a any wood
> boat.
> Curious?
> Jeff
>I've used some redwood in my strippers. The small strips of redwood split
> Redwood is occasionally used in strippers. However, there's not much
> grain--it's a nice color, but solid. Cedar, on the other hand, cna have a
> very nice grain to it, too.
very easily when stapled or nailed - they also don't tolerate much bending
before splitting. But it can make very nice accent strips, which is about
all I have the patience to use it for. Nothing really comes close to western
red cedar for stripping - lightweight, beautiful, easy to work, smells good,
etc..... I agree with Tom Dalzell, and Harry James's posts - I've stood next
to some big red cedars in the Sierras, and they are a sight to behold; it's
a shame to see so much perfect red cedar split into shingles - it oughta be
reserved for musical instruments - and boats!
Paul L
On Mon, 1 Oct 2001boatbuilding@...wrote:
dimension. Cedar is lighter, often cheaper, more plentiful around the
country, less prone to splitting, and more able to take a pounding.
I used red cedar as a butt block that runs athwart my shantyboat's cabin
sole (it was a quickie boat, and the bottoms side of the plywood panels
are completely epoxy/fiberglassed). We walk all over it, scuffing along,
and drop things on it. Very little signs of wear--I've benn quite happily
surprised.
> Redwood is never mentioned as an option for boat building. I was justIt's largely because western red cedar is a better option on almost every
> curious as to why that may be. It has reasonable rot resistance, if
> allowed to dry good and epoxy coated would stable. I know it may not
> perfect but for stringers and bilge areas, would it be a decent
> option? Epoxy coated, it would last the life a any wood boat.
surprised.
I guess they hadn't invented the deck yet ;0). The
kind of wood I am talking about should probably be
used only for classical guitars, and other high end
stuff. But as long as they keep making shingles out
of it, I don't know what to say.
Your right about splitting. But in composite, its the
way it works as a core that matters, which is a
different issue.
Fascinating history.
--- "Harry W. James" <welshman@...> wrote:
<HR>
<html><body>
<tt>
I didn't know that they were using redwood in modern
composite boat<BR>
building. A red and yellow cedar strip hull with
redwood worked in<BR>
artistically would be pretty spectacular. As far as I
know they did<BR>
not use redwood for boatbuilding in the old days. I
have a dim memory<BR>
of asking my dad about why they didn't use it when it
was readily<BR>
available, and as I remember, he said it split too
easily.<BR>
<BR>
The battles of the Save the Redwoods League, to save
the Sequoia<BR>
Gigantia's up in the Sierra in the late 40's early
50's, was not to<BR>
keep the Redwoods from being logged. Lumber guys have
told me that<BR>
their wood did not have much value. The 3000-4500 ft
level where they<BR>
grow promotes very large Pines and Cedars (12-15 ft
through the trunk,<BR>
200 ft plus tall) which are necessary to hold down the
roots of the<BR>
big boys. These trees were the ones the logging
companies wanted. <BR>
<BR>
You can understand this if you have ever stood under a
Sugar Pine with<BR>
a trunk 12' through and a clear run of 100 ft to the
first branch. You<BR>
can picture that incredibly tight grained, clear
lumber hidden from<BR>
your prying eyes just underneath the bark. It is
enough to inspire<BR>
lust in even an amateur woodworker. <BR>
<BR>
<BR>
<BR>
thomas dalzell wrote:<BR>
<br>
<tr bgcolor=#FFFFCC>
</tr>
<tr bgcolor=#FFFFFF>
face=arial
size=-2>ADVERTISEMENT</font><br>
<script language=javascript>
finalURL =
"http://rd.yahoo.com/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=0/*http://shop.store.yahoo.com/cgi-bin/clink?overstock3+shopping:dmad/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=1/1001968806+http://us.rmi.yahoo.com/rmi/http://www.overstock.com/rmi-framed-url/http://www.overstock.com/cgi-bin/d2.cgi%3Fcid=12715";
var flashFileURL =
"http://java.yahoo.com/a/1-/flash/misc/osyahooswf_0925.swf";
var noFlashImg =
"http://java.yahoo.com/a/1-/flash/misc/osyahooalt_0925.gif";
</script>
<script language=JavaScript
src=http://java.yahoo.com/a/1-/flash/test/0124/lrec_browser_071601.js>
</script>
<script language=JavaScript>
function makeNewWindow(url) {
var newWindow = window.open(url); }
</script>
<noscript>
<a
href="http://rd.yahoo.com/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=2/*http://shop.store.yahoo.com/cgi-bin/clink?overstock3+shopping:dmad/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=3/1001968806+http://us.rmi.yahoo.com/rmi/http://www.overstock.com/rmi-framed-url/http://www.overstock.com/cgi-bin/d2.cgi%3Fcid=12715"
target="_blank">
<img
src="http://java.yahoo.com/a/1-/flash/misc/osyahooalt_0925.gif"
width=300 height=250 border=0></a>
</noscript>
</td></tr></table></td>
</tr>
src="http://us.adserver.yahoo.com/l?M=168643.1620686.3168692.1261774/D=egroupmail/S=1705065791:HM/A=799560/rand=985409935"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
topic, and punctuate<BR>
snip all you like<BR>
- Unsubscribe:
<br>
<br>
of Service</a>.</tt>
</br>
</body></html>
Do You Yahoo!?
Get your free @... address athttp://mail.yahoo.ca
different issue.
<HR>
<html><body>
<tt>
composite boat<BR>
know they did<BR>
was readily<BR>
easily.<BR>
<BR>
the Sequoia<BR>
told me that<BR>
roots of the<BR>
<BR>
Sugar Pine with<BR>
<BR>
<BR>
<BR>
> <BR>it also<BR>
> Yes sure can, think strip canoes etc... But
> excells for stuff like rudders, centerboards,and<BR>
> paddles, wingspars. The Gougeons are bigpromoters<BR>
> when encapsulated. They built Adreneline arace<BR>
> winning formula 40 out of cedar/carbon. Onthe other<BR>
> hand, the good stuff is cheapish, but not in<BR>Redwood<BR>
> comparison to marine plywood.<BR>
> <BR>
> ---boatbuilding@...wrote:<BR>
> <BR>
> <HR><BR>
> <html><body><BR>
> <tt><BR>
> It doesn't seem to be mentioned here but can
> be use in boat <BR><BR>resistance, and<BR>
> building. It has reasonable rot
> when properly dried, <BR><BR>last the<BR>
> fairly stable. Epoxy coated, it should
> life of a wood <BR><BR>posted<BR>
> boat. <BR><BR>
> <BR><BR>
> I sent this once already as doesn't seem to be
> so I'll try <BR><BR>two.<BR><BR>
> again. Hopefully we don't get
> <BR><BR></tt>
> Jeff Blunck<BR><BR>
> <BR><BR>
> <BR><BR>
> <BR><BR>
> </tt><BR>
> <BR>
><BR>
<br>
</tr>
face=arial
finalURL =
var flashFileURL =
var noFlashImg =
</script>
</script>
</script>
<noscript>
<a
target="_blank">
<img
</noscript>
</tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
Do You Yahoo!?
Always keep in mind that any lumber larger than 1x1
can't be counted on to be stable with a coating alone.
Redwood splits very easilly so I wouldn't use it for
things you are nailling to or screwing to. If you are
worried about wood rot, just use epoxy coving, it is
easy to instal, and will not rot etc...
--- Jeff Blunck <boatbuilding@...> wrote:
<HR>
<html><body>
<tt>
I would believe that Redwood would split if used in
high stress areas. When<BR>
it's dried out, it is light and tender like good old
white pine. My<BR>
thoughts where to use it in places hard to get too to
check for moisture. I<BR>
just figured that coated in epoxy, it might be the
ticket for those hard to<BR>
reach places for things like internal chine logs,
bulkhead framing, etc.<BR>
<BR>
Glued next to plywood as on bulkhead frames would help
splitting and might<BR>
be the way to go if there wasn't a real problems using
it. Safer than<BR>
cutting and handling treated lumber.<BR>
<BR>
Some really nice 2 X 2 stuff at the local lumber yard
right now.<BR>
<BR>
Jeff<BR>
<BR>
<HR>
<html><body>
<tt>
white pine. My<BR>
<BR>
it. Safer than<BR>
<BR>
right now.<BR>
<BR>
Jeff<BR>
<BR>
----- Original Message -----<BR>
<welshman@...><BR>
To: <bolger@yahoogroups.com><BR>
Sent: Monday, October 01, 2001 2:42 PM<BR>
Subject: Re: [bolger] Redwood?<BR>
<BR>
<BR>
modern composite boat<BR>
as I know they did<BR>
I have a dim memory<BR>
when it was readily<BR>
too easily.<BR>
><BR>
save the Sequoia<BR>
early 50's, was not to<BR>
have told me that<BR>
ft level where they<BR>
ft through the trunk,<BR>
down the roots of the<BR>
companies wanted.<BR>
><BR>
under a Sugar Pine with<BR>
the first branch. You<BR>
> lust in even an amateur woodworker.<BR>
><BR>
><BR>
><BR>
<BR>
<BR>
</tt>
<br>
</tr>
face=arial
finalURL =
"http://rd.yahoo.com/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=0/*http://shop.store.yahoo.com/cgi-bin/clink?overstock3+shopping:dmad/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=1/1001969595+http://us.rmi.yahoo.com/rmi/http://www.overstock.com/rmi-framed-url/http://www.overstock.com/cgi-bin/d2.cgi%3Fcid=12715";
var flashFileURL =
var noFlashImg =
</script>
</script>
</script>
<noscript>
<a
href="http://rd.yahoo.com/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=2/*http://shop.store.yahoo.com/cgi-bin/clink?overstock3+shopping:dmad/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=3/1001969595+http://us.rmi.yahoo.com/rmi/http://www.overstock.com/rmi-framed-url/http://www.overstock.com/cgi-bin/d2.cgi%3Fcid=12715"
target="_blank">
<img
</noscript>
</tr>
src="http://us.adserver.yahoo.com/l?M=168643.1620686.3168692.1261774/D=egroupmail/S=1705065791:HM/A=799560/rand=825759370"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
Do You Yahoo!?
I would believe that Redwood would split if used in high stress areas. When
it's dried out, it is light and tender like good old white pine. My
thoughts where to use it in places hard to get too to check for moisture. I
just figured that coated in epoxy, it might be the ticket for those hard to
reach places for things like internal chine logs, bulkhead framing, etc.
Glued next to plywood as on bulkhead frames would help splitting and might
be the way to go if there wasn't a real problems using it. Safer than
Some really nice 2 X 2 stuff at the local lumber yard right now.
> I didn't know that they were using redwood in modern composite boat
> building. A red and yellow cedar strip hull with redwood worked in
> artistically would be pretty spectacular. As far as I know they did
> not use redwood for boatbuilding in the old days. I have a dim memory
> of asking my dad about why they didn't use it when it was readily
> available, and as I remember, he said it split too easily.
> The battles of the Save the Redwoods League, to save the Sequoia
> Gigantia's up in the Sierra in the late 40's early 50's, was not to
> keep the Redwoods from being logged. Lumber guys have told me that
> their wood did not have much value. The 3000-4500 ft level where they
> grow promotes very large Pines and Cedars (12-15 ft through the trunk,
> 200 ft plus tall) which are necessary to hold down the roots of the
> big boys. These trees were the ones the logging companies wanted.
> You can understand this if you have ever stood under a Sugar Pine with
> a trunk 12' through and a clear run of 100 ft to the first branch. You
> can picture that incredibly tight grained, clear lumber hidden from
> your prying eyes just underneath the bark. It is enough to inspire
> Yes sure can, think strip canoes etc... But it also
> excells for stuff like rudders, centerboards, and
> paddles, wingspars. The Gougeons are big promoters
> when encapsulated. They built Adreneline a race
> winning formula 40 out of cedar/carbon. On the other
> <HR>
> <html><body>
> <tt>
> It doesn't seem to be mentioned here but can Redwood
> be use in boat <BR>
> building. It has reasonable rot resistance, and
> fairly stable. Epoxy coated, it should last the
> life of a wood <BR>
> boat. <BR>
> <BR>
> I sent this once already as doesn't seem to be posted
> so I'll try <BR>
> again. Hopefully we don't get two.<BR>
> <BR>
> Jeff Blunck<BR>
> <BR>
> <BR>
> <BR>
> </tt>
<HR>
<html><body>
<tt>
be use in boat <BR>
life of a wood <BR>
boat. <BR>
<BR>
so I'll try <BR>
<BR>
Jeff Blunck<BR>
<BR>
<BR>
<BR>
</tt>
<br>
</tr>
face=arial
finalURL =
"http://rd.yahoo.com/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=0/*http://shop.store.yahoo.com/cgi-bin/clink?overstock3+shopping:dmad/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=1/1001958293+http://us.rmi.yahoo.com/rmi/http://www.overstock.com/rmi-framed-url/http://www.overstock.com/cgi-bin/d2.cgi%3Fcid=12715";
var flashFileURL =
var noFlashImg =
</script>
</script>
</script>
<noscript>
<a
href="http://rd.yahoo.com/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=2/*http://shop.store.yahoo.com/cgi-bin/clink?overstock3+shopping:dmad/M=168643.1620686.3168692.1261774/D=egroupweb/S=1705065791:HM/A=799560/R=3/1001958293+http://us.rmi.yahoo.com/rmi/http://www.overstock.com/rmi-framed-url/http://www.overstock.com/cgi-bin/d2.cgi%3Fcid=12715"
target="_blank">
<img
</noscript>
</tr>
src="http://us.adserver.yahoo.com/l?M=168643.1620686.3168692.1261774/D=egroupmail/S=1705065791:HM/A=799560/rand=283101620"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
Do You Yahoo!?
<HR>
<html><body>
<tt>
be use in boat <BR>
life of a wood <BR>
boat. <BR>
<BR>
so I'll try <BR>
<BR>
Jeff Blunck<BR>
<BR>
<BR>
<BR>
</tt>
<br>
</tr>
face=arial
finalURL =
var flashFileURL =
var noFlashImg =
</script>
</script>
</script>
<noscript>
<a
target="_blank">
<img
</noscript>
</tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
Do You Yahoo!?
It doesn't seem to be mentioned here but can Redwood be use in boat
building. It has reasonable rot resistance, and when properly dried,
fairly stable. Epoxy coated, it should last the life of a wood
boat.
I sent this once already as doesn't seem to be posted so I'll try
Jeff Blunck
boat.
Jeff Blunck
boat.
Curious?
boat.
Curious?
