surf
i'm in the planning stages of building surf. i built teal and sailed
her all summer. i want something bigger, but want to use the same
sail. other than the several pics in the file section of this site,
does anyone know where i can see pics of surf?
thanks,
bob
thanks,
bob
Hi Peter,
Thanx for your input, I had seen the pictures of your boat, and was
so impressed that I went out and bought some red paint!
There are some cleats where you said, and I wondered if they had
anything to do with the sheets.
I think that I will go for a swinging lee board, It's like really
shallow at Whangateau, that day it was full tide (albeit a small one)
and we ran aground 4 times in one hour! I have averything I need to
do it except the time, I had some breakeges on my outrigger on
Sunday, and I will also need to fix them.
You are winding down, and we are winding up! Getting ready for what
looks like will be a great summer.
Go well,
Rique
"Every day above ground, IS A GOOD DAY"
anon.
Go well,
Rique
anon.
> Hello Rique,
> Lucky you to be given a boat! I built and used my SURF
> several(many) years ago and enjoyed her greatly.In anything but the
> lightest and steadiest of winds,I always held the mainsheet in one
> hand for instant control/release.A pair of regular sailing gloves
took
> the sting out of holding it all day long.
> I also intalled two small cleats,P&S,on the outboard edge of
> the aft deck right where the bulkhead meets the sides.These I would
> use for the mainsheet when winds were light and steady.
> My rudder was a kick-up type,while for the leeboard I chose to
> attach the tongues with bolts and butterfly wing nuts.Also carried
> spare tongue to quickly replace the tongue that breaks when
grounding
> out at speed(it will be the forward tongue that breaks).I found
this
> arrangement much simpler then any type of swing up leeboard.
> You can go to the "files" section and check under SURF for
some
> pictures of a beautiful one under construction and of another
> sailing.Mine is the red one.......
> Happy sailing!
> Sincerely,
> Peter Lenihan,watching the leaves explode into rainbows of colour,
> while contemplating a haul-out date for LESTAT before thr frost
comes
> to the shores of the mighty St.Lawrence........
> --- In bolger@y..., Rique@p... wrote:
> > Hi!
> > I have just been given a Bolger "surf" and I am wondering if
anyone
> > out there has had some experiance with one. We took her out for a
> > sail the day we got it, there was almost no wind, and we ended up
> > rowing quite a lot. I usually sail my outrigger in a shallow
> estuary
> > that isn't a problem for her, but we managed to break the
leeboard
> > mount even with no wind! So she is out of commission untill I
make a
> > Michalak type arraingement. Also she didn't seem to have
anything
> to
> > run the sheet to on the boat, Is one meant to just hold it
without
> > any help? The guy that gave it to me has never sailed it, but
said
> > that the guy that he got it from said that he sailed it all
around
> > Auckland harbour and the inner gulf, but we don't know if he just
> had
> > a rope tied to the boom and held on to the other end.
> > I would love to hear from anyone that knows about this boat.
> > Go well,
> > Rique NZ
Hello Rique,
hand for instant control/release.A pair of regular sailing gloves took
attach the tongues with bolts and butterfly wing nuts.Also carried a
spare tongue to quickly replace the tongue that breaks when grounding
out at speed(it will be the forward tongue that breaks).I found this
You can go to the "files" section and check under SURF for some
Happy sailing!
while contemplating a haul-out date for LESTAT before thr frost comes
Happy sailing!
> Hi!
> I have just been given a Bolger "surf" and I am wondering if anyone
estuary
> that isn't a problem for her, but we managed to break the leeboard
> mount even with no wind! So she is out of commission untill I make a
> Michalak type arraingement. Also she didn't seem to have anything
> run the sheet to on the boat, Is one meant to just hold it without
> any help? The guy that gave it to me has never sailed it, but said
> that the guy that he got it from said that he sailed it all around
had
> Go well,
> Rique NZ
great pictures!
st jan the martyr looks good! really sleek!
jim, I seem to recall you built the boat to test a yuloh oar or
something similar - how did it work?
hannes
hannes
hannes
hannes
Hi!
rowing quite a lot. I usually sail my outrigger in a shallow estuary
Michalak type arraingement. Also she didn't seem to have anything to
Auckland harbour and the inner gulf, but we don't know if he just had
Go well,
Rique NZ
Go well,
Rique NZ
