RE: [bolger] Re: Non Bolger, but look at this boat...
Yes, I would do that – it’s the big advantage of the bilge board. Considering whether to use a daggerboard or (off-)centerboard, you can get a narrow daggerboard closer to the chine of a flat-bottom boat than you can a long (off-)centerboard. Its true that a pivoting daggerboard adds some complexity, but it would be better than not pivoting when you run aground. And the daggerboard is more efficient.
Bill
Sent: Wednesday, October 10, 2001 7:14 PM
Subject: Re: [bolger] Re: Non Bolger, but look at this boat...
In a message dated 10/10/01 10:55:42 AM Central Daylight Time,
kreamer@...writes:
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=168643.1620686.3205344.1261774/D=egroupweb/S=1705065791:HM/A=816901/R=5/*http://www.overstock.com/cgi-bin/d2.cgi?cid=12973> <http://rd.yahoo.com/M=168643.1620686.3205344.1261774/D=egroupweb/S=1705065791:HM/A=816901/R=6/*http://www.overstock.com/cgi-bin/d2.cgi?cid=12973>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Bill
kreamer@...writes:
> I’m thinking of using two bilge dagger boards, each with an angle of[Non-text portions of this message have been removed]
> attack to weather of maybe 3 degrees, with a lifting foil profile.
> What do you think of the idea?
> Sounds like an awfully complicated effort to achieve doubtful and at best
> very marginal performance improvements. I think the principal advantage of
> bilge boards in scows is that the lee board stands nearer vertical when the
> boat is heeled, an advantage that your concept (if I understand it
> correctly) would not have.
> However, in the interests of science and controversy, I think you should
> execute this concept and give a full report!
> Ciao for Niao,
kreamer@...writes:
kreamer@...writes:
> Ciao for Niao,
kreamer@...writes:
"calculated" the CE of the sail plan on an ink-jet printed profile drawing of
the CK17 blown up to 1cm = 1ft scale. Unless I made some gross conceptual
error, the CE lies on a vertical line passing through the waterline near the
leading edge of the daggerboard. Surprised me! (actually, on my rough
drawing, the intersection point is roughly 1/3 of the dagger board width aft
of the board's leading edge - but I don't think any significance should be
attached to that given the likely margin of error and that the "CE" (or "CA")
is essentially a notional construct.)
(I'd be most appreciative if someone would check my results.)
On first glance (and second and third and still), to my untutored eye it
looks like the dagger board is much farther aft than customary. I would
expect this condition to give severe or uncontrollable LEE helm, not windward
helm. I'm going to check out my limited collection of Bolger, Chapelle and
Parker to try to find a similar profile for comparison purposes.
I believe it is customary for a designer to place the CE some small
percentage of LWL ahead of the CLR, the percentage varying empirically with
hull and appendage shape, but I don't know the range of values used.
If the design does have any gross CE/CLR problem (unlikely, given the
source), I don't think using bilgeboards would do much, if anything to
correct it.
Bill in MN
kreamer@...writes:
> Looks like the CK17 sail plan and daggerboard CEs are reversed fromWhile participating in a rather tedious conference this afternoon, I actually
> usual, so you’d get weather helm. But how much lead should the board
> have, if any?
correct it.
Bill in MN
The web site sail plan shows the sails CE ahead of the board CE, by
quite a lot. Just surprising, thats all.
Bill
Sent: Wednesday, October 10, 2001 12:07 PM
Subject: [bolger] Re: Non Bolger, but look at this boat...
factors that would increase weather helm.
What makes you think an experienced designer and professional
engineer would make a mistake with such a basic aspect of design?
065791:HM/A=816903/R=1/*http://www.overstock.com/cgi-bin/d2.cgi?cid=1297
3>
065791:HM/A=816903/R=2/*http://www.overstock.com/cgi-bin/d2.cgi?cid=1297
3>
Bill
> Looks like the CK17 sail plan and daggerboard CEs are reversed fromThe designer says that the CK17 has 12% lead and notes a couple of
> usual, so you'd get weather helm.
3>
3>
Bilgeboard racing scows (various classes - C and E are common) which
are designed to be sailed a 20-25 degree heel angles, have
essentially two off-centerboards, one for each tack. They're canted
outboard so that the board that's lowered is just about vertical when
the boat is heeled normally. The boards are generally toed in a few
degrees, see:http://www.ncssa.org/CSCOW.htmSome of them have two
rudders also. They're very fast boats.
FWIW, I'd rather have pivoting centerboards rather than two
daggerboards to deal with. I think it would be MUCH easier to change
boards when tacking just by pulling on lines, rather than lifting out
and reinserting a daggerboard.
Keith Wilson
Keith Wilson
--- In bolger@y..., "Bill Kreamer" <kreamer@m...> wrote:
> I'm thinking of using two bilge dagger boards, each with an angle of
usual, so youd get weather helm. But how much lead should the board
have, if any?
Im thinking of using two bilge dagger boards, each with an angle of
attack to weather of maybe 3 degrees, with a lifting foil profile. You
could set the angle so that the board would carry all the sideways load
under certain conditions, and the boat wouldnt make any leeway. Drag
would be reduced because the board is a much more efficient lifting body
than the hull.
To tack, you would first put the weather board in, then put the tiller
down and remove the other board as you come head to wind (big tiller
extension when single handed, or just wait until youre squared away to
remove the weather board). I could arrange the dagger blades to pivot
between two cheeks like a rudder, with the trio fitting into a
wider-than-usual case. When fully in, the cheeks are flush with the
bottom. The wide case would let me experiment with flow fences on the
blade tips.
The case would have room, at the after end, to let the board pivot,
intentionally or when it strikes bottom. There might be a detent in the
straight down position, another in an intermediate position, that
hitting bottom would override. Pulling the board up would return it to
the intermediate position, in which configuration it could be fully
removed or inserted.
Bill
Sent: Tuesday, October 09, 2001 8:00 PM
In a message dated 10/8/01 7:30:25 AM Central Daylight Time,
ellengaest@...writes:
in
the meantime - does the placement of the daggerboard look a little
radical to
anyone else?
Bill in MN
Click Here!
<http://rd.yahoo.com/M=211853.1564077.3168157.1261774/D=egroupweb/S=1705
065791:HM/A=798638/R=0/*http://shop.store.yahoo.com/cgi-bin/clink?workou
twarehouse2+shopping:dmad/M=211853.1564077.3168157.1261774/D=egroupweb/S
=1705065791:HM/A=798638/R=1/1%20>
have, if any?
than the hull.
blade tips.
Bill
> Next,that daggerboard is just a foil looking to foul itself onI'm going to make photocopies of the profile tomorrow to play with, but
in
radical to
anyone else?
Bill in MN
Click Here!
Don, in that context "piano" means "slowly", however you gave me an
idea!
idea!
--- In bolger@y..., dbaldnz@y... wrote:
> Ok Pippo, so you say-
> "Who goes flat goes healthy and goes far away" ??????
> From that I conclude you are searching for the healthiest flat boat
> design to sail to NZ for the next americas cup...most welcome!
> DonB
> > say "chi va piano, va sano e va lontano"...
DonB
--- In bolger@y..., "Giuseppe 'Pippo' Bianco" <giuseppe.bianco@a...>
DonB
> Don, I want to make sure to choose the right one ;-) here in Italywe
> say "chi va piano, va sano e va lontano"...don't
> > Hi Pippo,
> > I thought you were glassing your Chebacco about now?
> > Better put off the Mertens, and invest in a large drawing file
> > cabinet first!
> > DonB
> > wrote:
> > > Hi Peter! Yes, that boat could be the one. Light, simple, an
> almost
> > > perfect daysailer. Not as seaworthy as a Micro, for sure. I'll
> > always
> > > have a soft spot in my heart for the Micro, you know that,
> > you?no
> > > However, this summer's experience with my plastic little sloop
> have
> > > taught me several things. I need a simple boat, shallow draft,
> > light,
> > > fast, with a very comfortable cockpit. The Chebacco comes very
> > close,
> > > but this one weights one fourth of a Chebacco (and of a Micro).
> The
> > > CK17 drafts 13 cm instead of 55! In my sailing area there are
> > > weeds (sandy, shallow beaches). The winds are normally seabuilding
> breezes
> > up
> > > to force 3. With this boat, I might easily get rid of mooring
> costs
> > > as well... That could be the one...
> > > Best, Pippo
> > > --- In bolger@y..., ellengaest@b... wrote:
> > > > Hi Pippo!
> > > > She sure does look very nice.Are you thinking of
> > > her?a
> > > > The frustrating thing about boats this size is that you soon
> wish
> > > for
> > > > a cabin.That forward open cockpit is a prime candidate for
> > > > cabinhood.Since Mertens boat has a 6 foot beam(like MICRO),we
> > know
> > > it
> > > > has enough room....
> itself
> > > on
> > > > weeds,mud or worse.We may as well go for the centerboard
> > option.But
> > > > wait! Why even bother with an intrusive centerboard case and
> > holenice
> > > > built into the bottom when we can avoid the whole issue by
> using
> > a
> > > > full-lenght keel(like MICRO) and keep the interior open and
> free?
> > > > Since we have already schemed up the notion of perhaps
> > adding
> > > > just a small cabin,this encourages(demands) some serious
> > > cruising.This
> > > > cruising will probably take us to unfamiliar waters where we
> may
> > > also
> > > > be exposed to some un-planned nasty weather.Wouldn't it be
> > ifand
> > > > this boat could be made at least self-righting(like MICRO)?
> > > > The sail plan is nice and easy to handle(like MICRO)
> > > > certainly no more difficult/expensive to build.to
> > > > In the end,we end up with a boat that comes very close
> > > > satisfying alot of wishes but only close.........On the otherget
> > > > hand,MICRO(for which I believe you already have most of the
> > > material
> > > > ;-) ) will be more campact,allow you to cruise under a wider
> > > variety
> > > > of conditions while remaining comfortable,provide greater
> volume
> > of
> > > > dry storage for cruising supplies,keep you safe when things
> > > roughlimited!
> > > > and still be available for quick daysails when time is
> > > > Mertens boat is easier to trailer,I will admit but onlybe
> > until
> > > > you master trailering a MICRO at which point there will not
> > muchfactor
> > > of
> > > > a difference in trailering.
> > > > So..........
> > > > Happy dreaming!
> > > > Sincerely,
> > > > Peter Lenihan,stirring Pippos thoughts from the shores of the
> > > > St.Lawrence,where it is a nippy 3deg.Celsius with a chil
> > of
> > > > -2deg.celsius........Brrrrrrrrr!!
> > > > wrote:
> > > > > Hi Folks
> > > > > have a look to this boat designed by Jacques Mertens:
> > > > >http://www.bateau.com/plans/sail/CK17.php3
> > > > > Looks great, doesn't it?
the meantime - does the placement of the daggerboard look a little radical to
anyone else?
Bill in MN
> Next,that daggerboard is just a foil looking to foul itself onI'm going to make photocopies of the profile tomorrow to play with, but in
anyone else?
Bill in MN
On Mon, 8 Oct 2001djost@...wrote:
if you're lucky, firmly saying "yuck".
> do you think that Mr. Bolger would design a pair of bilge keels forNo. It's so alien to the concept of the boat, he'd write a polite letter,
> Micro?
There is also a Core Sound 20, both by Graham Byrnes at B&B Yacht Design.I've seen the 17 sail and
was impressed enough to buy the plans but somewhere in there I encountered my house project and then
a Freedom 21. Clyde
a Freedom 21. Clyde
cpcorreia@...wrote:
> Pippo,
> This does look like a neat boat. It is very similar to the Core Sound 17.
>http://www.bandbyachtdesigns.com/cs17.htm
> I like the fact that the CS17 has more sail area, but has a third location
> for a mast which allows one sail to be carried on those windy days. Have you
> compared these boats. What do you think?
> Chuck, (California)
> In a message dated 10/8/01 1:29:16 AM Pacific Daylight Time,
>giuseppe.bianco@...writes:
> << Hi Folks
Don, I want to make sure to choose the right one ;-) here in Italy we
> Hi Pippo,
> cabinet first!
> DonB
almost
> always
> > have a soft spot in my heart for the Micro, you know that, don't
> you?
have
> light,
> close,
The
> > CK17 drafts 13 cm instead of 55! In my sailing area there are no
breezes
> up
costs
> > Best, Pippo
> > > Hi Pippo!
> > > She sure does look very nice.Are you thinking of building
> > her?
wish
> > for
> know
> > it
> > > has enough room....
itself
> > on
> option.But
> > > wait! Why even bother with an intrusive centerboard case and a
> hole
using
> a
free?
> adding
> > cruising.This
may
> > also
> > > be exposed to some un-planned nasty weather.Wouldn't it be nice
> if
> > > The sail plan is nice and easy to handle(like MICRO) and
> > > In the end,we end up with a boat that comes very close to
> > material
> > variety
volume
> of
> > > dry storage for cruising supplies,keep you safe when things get
> > rough
> > > and still be available for quick daysails when time is limited!
> until
> > > you master trailering a MICRO at which point there will not be
> much
> > of
> > > So..........
> > > Happy dreaming!
> > > Sincerely,
> > > St.Lawrence,where it is a nippy 3deg.Celsius with a chil factor
> of
> > > wrote:
> > > > Hi Folks
Chuck, how are you?
Yes, I've compared the two boats and definitely prefer the Mertens'
one due to its extremely clever cockpit design (it has two cockpits
actually, one being for the skipper, the other for the crew), other
than the very significant storage space. One of the many things I've
learned in one month of daysailing is that storage space is
fundamental. On my little plastic 16 footer, which is supposed to be
a spacious boat by its size, there's definitely a problem to find
suitable storage for things like floating jackets, oars, ropes,
fenders, and so on.
Best, Pippo
fenders, and so on.
Best, Pippo
--- In bolger@y..., cpcorreia@a... wrote:
> Pippo,
Sound 17.
location
days. Have you
> Chuck, (California)
> giuseppe.bianco@a... writes:
> << Hi Folks
Hi Pippo,
cabinet first!
DonB
cabinet first!
DonB
> Hi Peter! Yes, that boat could be the one. Light, simple, an almostalways
> have a soft spot in my heart for the Micro, you know that, don'tyou?
> However, this summer's experience with my plastic little sloop havelight,
> fast, with a very comfortable cockpit. The Chebacco comes veryclose,
> but this one weights one fourth of a Chebacco (and of a Micro). Theup
> weeds (sandy, shallow beaches). The winds are normally sea breezes
> to force 3. With this boat, I might easily get rid of mooring costsknow
> Best, Pippo
> > Hi Pippo!
> her?
> > The frustrating thing about boats this size is that you soon wish
> for
> itoption.But
> > has enough room....
> on
> > wait! Why even bother with an intrusive centerboard case and ahole
> > built into the bottom when we can avoid the whole issue by usinga
> > full-lenght keel(like MICRO) and keep the interior open and free?adding
> > just a small cabin,this encourages(demands) some seriousif
> cruising.This
> > cruising will probably take us to unfamiliar waters where we may
> also
> > this boat could be made at least self-righting(like MICRO)?of
> material
> variety
> > of conditions while remaining comfortable,provide greater volume
> > dry storage for cruising supplies,keep you safe when things getuntil
> rough
> > you master trailering a MICRO at which point there will not bemuch
> ofof
> > So..........
> > Happy dreaming!
> > Sincerely,
> > wrote:
> > > Hi Folks
Pippo,
Chuck, (California)
<< Hi Folks
Chuck, (California)
<< Hi Folks
Pippo,
Here is a thought.
for Micro. I just got a peak at a Hurley 22 with bilge keels, and
the idea hit me. not only could you possible reduce draft enough to
sneak in and out of anywhere, but you could also sit upright when the
tide leaves. Maybe a rudder with an end plate to go with it.
Anyone else have an idea?
"0c this morning in Massachusetts.
The poor tomatoes have had it."
Here is a thought.
Jacques has indicated that the ck17 daggerboard has some sort of
unique feature that should help keep out of trouble if it hits the
bottom. I will be interested to see a description.
As for choosing your boat based on its underbody, there are separate
problems of the water depth in your mooring area (and if you want to
beach the boat), and your water depth in your sailing area. The
daggerboard would be fine if the former is small, but the latter is
large. But if you want to sail in shallow water (e.g. Barnegat Bay
here on the US east coast), you want a shallower keel.
Pippo,
I would go for it! Mertens boat sure looks nice.....a great
daysailor.Any boat that can get you out on the water,especially one
that you build, will be a fantastic high! Furthermore,as your kids
grow up,they can use it themselves for some really fun boating
adventures while you build another boat for your retirement!
Keep us posted of your progress,when you start this fun
boat!Certainly you will have no problems with epoxy curing in
27 degree weather! It has gone up one whole degree to 4 degrees
Celsius here in Montréal at 10:01 and if it gets any warmer,I just may
break out in a sweat.........:-D
Peter Lenihan,wondering about that"accident" in Milan,from the cool
sunny shores of the St.Lawrence.......... half-way around the world.
> Hi Peter! Yes, that boat could be the one. Light, simple, an almostlight,
> perfect daysailer. I need a simple boat, shallow draft,
> fast, with a very comfortable cockpit.That could be the one...
> Best, Pippo
And the temperature right now (3:15 PM) is about 27 degrees Celsius...
Cheers from sunny (albeit humid) southern Italy
Pippo
Pippo
> Hi Pippo!
her?
for
> cabinhood.Since Mertens boat has a 6 foot beam(like MICRO),we know
it
> has enough room....
on
> weeds,mud or worse.We may as well go for the centerboard option.But
> wait! Why even bother with an intrusive centerboard case and a hole
> built into the bottom when we can avoid the whole issue by using a
> Since we have already schemed up the notion of perhaps adding
cruising.This
also
> be exposed to some un-planned nasty weather.Wouldn't it be nice if
material
variety
> of conditions while remaining comfortable,provide greater volume of
rough
> Mertens boat is easier to trailer,I will admit but only until
> you master trailering a MICRO at which point there will not be much
> So..........
> Happy dreaming!
> Sincerely,
> St.Lawrence,where it is a nippy 3deg.Celsius with a chil factor of
> wrote:
> > Hi Folks
perfect daysailer. Not as seaworthy as a Micro, for sure. I'll always
have a soft spot in my heart for the Micro, you know that, don't you?
taught me several things. I need a simple boat, shallow draft, light,
fast, with a very comfortable cockpit. The Chebacco comes very close,
weeds (sandy, shallow beaches). The winds are normally sea breezes up
Best, Pippo
Best, Pippo
> Hi Pippo!
her?
for
it
> has enough room....
on
cruising.This
also
material
variety
rough
> So..........
> Happy dreaming!
> Sincerely,
> wrote:
> > Hi Folks
Hi Pippo!
She sure does look very nice.Are you thinking of building her?
The frustrating thing about boats this size is that you soon wish for
cabinhood.Since Mertens boat has a 6 foot beam(like MICRO),we know it
has enough room....
just a small cabin,this encourages(demands) some serious cruising.This
cruising will probably take us to unfamiliar waters where we may also
hand,MICRO(for which I believe you already have most of the material
;-) ) will be more campact,allow you to cruise under a wider variety
dry storage for cruising supplies,keep you safe when things get rough
you master trailering a MICRO at which point there will not be much of
So..........
Happy dreaming!
has enough room....
So..........
Happy dreaming!
> Hi Folks
Hi Folks
