email MAIB
does anybody out there know if Bob Hicks can be reached by
email?
he gives an adress on his letterhead (officesupport@...),
but this does not work.
hannes
who is still in a state of shock after finding out that my overseas
(europe) subscribtion is going up by $41 to $77, of which $59 is
postage - arrrgh!
I will try to talk bob into sending the magazines not once a month,
but twice a year, which should bring costs back to an acceptabe
level.
email?
hannes
postage - arrrgh!
level.
john,
thanks for the update on your progress! sounds like we should
have a report on how bantam handles on the water soon.
I am just as curious as you about who&where the other builder is.
anybody knows?
hannes
p.s. did i get you right: you built the main hull in one piece and
then chopped off the bow piece?
anybody knows?
hannes
john,
anybody knows?
hannes
anybody knows?
hannes
>http://us.click.yahoo.com/Gi0tnD/bQ8CAA/ySSFAA/_0TolB/TM
>have been working about15 hours aweek on bantam for 6
weeks now and is comming along very well. the center
hull is finished and removable nose cut off. very
light the 16 foot part weioghs about80 pounds
unglassed the nose maybe 25 pounds. the sides bottoms
and bulkheads for the two outer hulls are ready to be
assembled this weeekend so far nothing takes up more
space than a canoe in my caeport. everything very
light mostly quarter in ply about three sheets of
half inch. the plans in metric so i had to buy a ma
metric tape and just read the numbers the plans are
vdr very detailed eight sheets Znd took some studying.
i plan to launch as soon as the hull--s are together
and use it as a runabout pontoon boat on weekends
while finishing off the interio and cabin top and
sides the boat looks very promising and the plans up
to bolgers usual high standard keyed with numbers to
instructions anybody should be able to build one. when
bolger sent me the plans he said he had revised them
some changes to the cabin after a hands on visit with
the prototype builder but he didnt say who or whjere
that boat is bei ng built. im planing on powering her
with the same 9,9 yamaha i use on my modified idaho
tenessee but hope i can switch from the high thrust
prop to the normal high speed prop. i dont have the
high thrust motor so use a high thrust prop when i
power the 32 foot sharpie. it works wekll. john
> From: "Jeff Blunck"________________________________________________________________________
> <boatbuilding@...>
> 4. Re: Sneakeasying a Tennessee
> From: "John Bell" <jmbell@...>
> 5. Re: Re: Sneakeasying a Tennessee
> From: "Jeff Blunck"
> <boatbuilding@...>
> 6. Trailer for the topaz-measurement
> From: Brad Raby <sailormon@...>
> 7. info on "missing" Bolger designs
> From: "Gerry" <ghinkle@...>
> 8. Re: info on "missing" Bolger designs
> From: thomas dalzell
> <proaconstrictor@...>
> 9. Re: Re: Sneakeasying a Tennessee
> 10. Re: Re: Sneakeasying a Tennessee
> From: "Harry W. James"
> <welshman@...>
> 11. Proper Bottom Design
> From:pateson@...
> 12. Re: Re: Sneakeasying a Tennessee
> From: "Jeff Blunck"
> <boatbuilding@...>
> 13. RE: Proper Bottom Design
> From: "David Romasco"
> <dromasco@...>
> 14. Re: Proper Bottom Design
> 15. Re: info on "missing" Bolger designs
> From:inf0man@...
> 16. Re: info on "missing" Bolger designs
> From: Chris Crandall <crandall@...>
> 17. Re: Sneakeasying a Tennessee
> From: Vince and Mary Ann Chew
> <vachew@...>
> 18. Diablo
> From:don@...
> 19. Re: Re: Sneakeasying a Tennessee
> From: "Jeff Blunck"
> <boatbuilding@...>
> 20. Re: Sneakeasying a Tennessee
> 21. Re: Re: Sneakeasying a Tennessee
> From: "Jeff Blunck"
> <boatbuilding@...>
> 22. Re: Trailer for the topaz-measurement
> From: Sam Glasscock
> <glasscocklanding@...>
> 23. Re: Re: Sneakeasying a Tennessee
> 24. Re: Re: Sneakeasying a Tennessee
> 25. Re: Re: Sneakeasying a Tennessee
> Message: 1
> Date: Mon, 29 Oct 2001 07:57:57 -0500
> From: "Clyde S. Wisner" <clydewis@...>
> Subject: Re: Re: A gaff rig for Windsprint?
> I wonder if the position or placement of the
> floatation is what did it? Would the largest volumn
> of
> floatation be higher in the water with the boat
> right side up or turned over, once it was full of
> water. I have wondered about this as I filled the
> huge volumns in the bow and stern of my Lily, with
> foam but I also have 300+ lbs of battery ballast.
> Clyde
>teakdeck@...wrote:
> > In a message dated 10/28/01 7:24:45 AM Pacific
> Standard Time,
> >phillip_lea@...writes:
> > << Mike,
> > Did your Windsprint turtle with the rig set,
> i.e., drag the yard
> > and mast underwater? >>
> > No, I had other problems at the dock which led to
> the capsize. My main point
> > was, despite all the flotation, it was amazing to
> me how the boat filled up
> > with water and turned over.
> > MM
> > - no cursing, flaming, trolling, spamming, or
> flogging dead horses
> > - pls take "personals" off-list, stay on topic,
> and punctuate
> > - add your comments at the TOP and SIGN your
> posts, snip all you like
> > - To order plans: Mr. Philip C. Bolger, P.O. Box
> 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
> Message: 2
> Date: Mon, 29 Oct 2001 08:26:00 EST
> From:teakdeck@...
> My Windsprint is decked over and the flotation is in
> both the bow and stern
> of the boat. I thought if the boat ever went over,
> it would float on its
> side. Instead, it filled up with water then easily
> rolled over. It was not
> hard to get it back upright and then bail it out.
> Out in the open water I
> think I would have been in trouble.
> Mike Masten
> In a message dated 10/29/01 5:00:43 AM Pacific
> Standard Time,
>clydewis@...writes:
> << I wonder if the position or placement of the
> Would the largest volumn of
> Clyde
> Standard Time,
> > << Mike,
> i.e., drag the yard
> point
> > MM >>
>=== message truncated ===
Do You Yahoo!?
Find the one for you at Yahoo! Personals
http://personals.yahoo.com
