Re: Steel Plating the bottom
--- In bolger@y..., timothy@e... wrote:
> Hey all,
> Just curious.. has anyone here built a Bolger design with the
bottom
> steel plated? I've heard of a few designs that use that method to
> make the bottom bullet proof and as extra (or even primary) ballast.
> I was curious as to how the plates are attached, how they
performed,
> etc. Thanks! :)
> --Timothy
I had a recent conversation with PB&F regarding a boat (31') that is
to use external steel ballast. There would be several plates, each
pre-formed to the bottom curve. Each section would then be installed
on the bottom using 3M 5200 (or equivalent) and through-bolted.
Les Lampman
If that was me there is no way those bolt are going
through the bottom of the hull. maybe a bunch of
small bolts threaded into the plates, and then the
whole thing dropped into an epoxy puddle on the
bottom, as long as it didn't raise the CG.
---pvanderw@...wrote:
<HR>
<html><body>
<tt>
The instructions for installing the ballast in Black
Skimmer read as <BR>
follows:<BR>
<BR>
Ballast: three 3/4" x 12" x 5'6" steel
plates, galvanized or <BR>
enamelled; 1 3/8" bolt each through bottom of
hull; total weight <BR>
about 500 pounds.<BR>
<BR>
Before going too bonkers about the 1 bolt each, take
note the ballast <BR>
plate is INSIDE the bottom. I had mistakenly said it
was outside <BR>
before I looked it up.<BR>
<BR>
Peter<BR>
<BR>
</tt>
<br>
<tr bgcolor=#FFFFCC>
</tr>
<tr bgcolor=#FFFFFF>
href="http://rd.yahoo.com/M=213858.1737107.3257770.1261774/D=egroupweb/S=1705065791:HM/A=763352/R=0/*http://www.classmates.com/index.tf?s=5085"
target=_top><img
</tr>
src="http://us.adserver.yahoo.com/l?M=213858.1737107.3257770.1261774/D=egroupmail/S=1705065791:HM/A=763352/rand=213145606"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
topic, and punctuate<BR>
snip all you like<BR>
- Unsubscribe:
<br>
<br>
of Service</a>.</tt>
</br>
</body></html>
The instructions for installing the ballast in Black Skimmer read as
follows:
Ballast: three 3/4" x 12" x 5'6" steel plates, galvanized or
enamelled; 1 3/8" bolt each through bottom of hull; total weight
about 500 pounds.
Before going too bonkers about the 1 bolt each, take note the ballast
plate is INSIDE the bottom. I had mistakenly said it was outside
> For external attachment, it would give me a queasy
> feeling. It reminds me of some comments made in
> Outside magazine about the irresponsibility of a yard
> that attached a bulb ballast to an extreme fin keel
> by duct tapping it arround a flange with carbon fiber.
> They kept repeating in varioius issues of Outside
> that the builders were at fault because there wasn't
> any metal to metal connection, as if such a thing is
> ever possible with a glass boat. That's the way I
> would feel about the ballast on a wooden boat, at some
> point your going to violate the envelope. If it was
> up to me I would get some sort of recess in the bottom
> and then bolt it through to the inside, and seal
> everything with 5200. All the holes would have to be
> solid glass, to keep the capsule. And we are talking
> about a lot of holes. But then ballast always scares
> me.
Heh. Well, you can't cheat mother nature. Either you have a light
displacement multihull, or a skiff, and in either case you can't carry
much of a load. Sure, you could built a BIG catamaran, but thats
getting to be a bit much.
You can make monohulls unsinkable if you plan it carefully. Using the
combination of insulation foam and perhaps a few watertight bulkheads.
Anyway, you are totally right. I found out how they do this and it
turns out to be just as you describe. Throughbolt with great, honking,
countersunk steel bolts.. seal everything with 5200.
--Timothy
me.
<HR>
<html><body>
<tt>
The ballast for Black Skimmer is steel plate fastened
by bolts up <BR>
thru the chine logs, as best as I recall. I know that
boats were <BR>
built with a variety of different types of
ballast.<BR>
<BR>
The two issues would be getting a fair bottom, and
longevity (with <BR>
respect to rot and rust). I can't help you on either
count.<BR>
<BR>
PHV<BR>
<BR>
--- In bolger@y..., timothy@e... wrote:<BR>
> Hey all,<BR>
> <BR>
design with the <BR>
bottom <BR>
use that method to <BR>
even primary) ballast.<BR>
> <BR>
how they <BR>
performed, <BR>
> etc. Thanks! :)<BR>
> <BR>
> --Timothy<BR>
<BR>
</tt>
<br>
</tr>
<td align=center width=470><a
href="http://rd.yahoo.com/M=215839.1739749.3263115.1261774/D=egroupweb/S=1705065791:HM/A=868540/R=0/*http://zappos.zappos.com/bin/zapposset?ref=yahoogroups2"><img
src="http://us.a1.yimg.com/us.yimg.com/a/za/zappos/zap_468x60winterboots.gif"
height=60 width=468></a></td>
</tr>
src="http://us.adserver.yahoo.com/l?M=215839.1739749.3263115.1261774/D=egroupmail/S=1705065791:HM/A=868540/rand=721044012"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
> The ballast for Black Skimmer is steel plate fastened by bolts up
> thru the chine logs, as best as I recall. I know that boats were
> built with a variety of different types of ballast.
> The two issues would be getting a fair bottom, and longevity (with
> respect to rot and rust). I can't help you on either count.
> PHV
Hmm. Well, since the steel plating is essentially sacrificial, i.e.
non-structural, I wouldn't be concerned about rust so much. And with
steel being so cheap, replacing a plate every so often would not be a
big deal.
As far as a fair bottom is concerned, with a square/rocker bottom,
you could just have the plates made -for- you with the exact radius
in them needed. Hey, I don't feel like bending 1" plate. ;)
I am really interested in how these are attached though.. phosphor
bronze bolts? Through chine logs? Through a false bottom structure?
etc. And opinions as to how they perform.
Thanks again!
--Timothy
PHV
> Hey all,
bottom
performed,
> etc. Thanks! :)
> --Timothy
Hey all,
Just curious.. has anyone here built a Bolger design with the bottom
I was curious as to how the plates are attached, how they performed,
etc. Thanks! :)
--Timothy
