Re: [bolger] Re: performance sharpie design
I did a quickie model of Todd's boat in Hulls. Since Hulls won't do a
shallow arch bottom, I did it as a shallow vee instead. Based on the
righting moment calculations, I have to agree that it has more than enough
form stability to dispense with a ballast keel all together. While it is a
handsome hull in profile, looking at it in 3D wireframe it is really, really
fat looking. Cutting the beam to 6' looks a lot better and would probably
perform better.
I think it would not be all that easy to get the all up weight down to 250
lbs without getting a little bit exotic with the construction. The bottom
is
going to need a lot of floors to reinforce it and help it hold its shape.
Getting the lightweight hull to handle the loads generated by the high
powered rig is going to be tricky. It's going to be tough to build much in
the way of cruising
accommodations without increasing the weight so much the performance
suffers.
JB
perform better.
is
the way of cruising
suffers.
JB
Sent: Saturday, November 24, 2001 8:52 AM
Subject: [bolger] Re: performance sharpie design
| Bill, I found the drawings in the Photos section.
| Todd,
| your hull design does have the potential to be very fast. I do think
| that, in a boat that small ballast is going to hinder speed. Consider
| some of the high performance dinghies, and the fact that these are one
| designs which don't have to fit a rule; they are similar in size to
| you proposed boat but no ballast and much narrower.
| Fat is only fast because it increases form stability and decreases
| wieght in big boats in a ideal world skinny is much faster. Consider
| a catamaran, form stability comes from beam but the hulls are very
| narrow. Narrower hulls are also much easier to keep in the groove
| (sailing at good speed); fat high aspect ratio hull and rigs can be
| fast but take alot of attention and skill to get up to spead and keep
| there.
| On the topic of rigs you have mixed a high aspect ratio hull, keel and
| rudder with a low aspect ratio rig, highbread combinations like that
| rarely give the best of both worlds (I assume that is what you are
| after) usually give the worst of both worlds. My inclination would be
| to suggest a multihull, you will get good form stability and speed
| with out the narrow sailing groove.
| Andy
| PS: I appologies to the sharpie fans for steering Todd away from
| sharpies but he did say he wanted speeds 2* the speed of the wind and
| I dont think he will get that easily in a monohull and still have a
| easy to sail boat.
| Bolger rules!!!
| - pls take "personals" off-list, stay on topic, and punctuate
Todd,
there.
Andy
easy to sail boat.
Todd,
there.
Andy
easy to sail boat.
16' performance sharpie LOA 16 LWL 12'6'' BEAM 7'6'' hull weight
including ballast 250lb. sal area 200 sqft.
Th hull should only draw a few inches of water wuth the keel in the
up position. Just kiss the waterwhile still...
Todd
Todd
> If you want advice try to be as specific as possible,
> ideas like "I want the hull to just <BR>
> kiss the water while still", can't be dealt with
> unless we know what you want to do.
Shoal draft is what I'm after as well. Easy to trailer easy to
launch, retractable keel details. Tring to get an effiecient hull to
get the most bang for my buck from a simple rig.
What I want to do ? Sail twice as fast as the wind, with a shoal
draft 16 foot mono hull, with a cat yawl shapie rig. Cabin space for
two sleep cramped.
Todd
two sleep cramped.
Todd
> I am just going by eye. What are the dimension. It
> isn't the curvature I was refering to buth the fact
> the if heeled (though perhaps that isn't in the plans,
> the assymytry between the sides and bottom may affect
> the hydro undesireably
> There isn't anything inherently wrong with bulds, and
> there isn't anything about what kind this is. I just
> saw two things, one is no shoal draft, which is a lot
> of the sharpie apeal, and the other depending on what
> kind of gyzmo this is, is the difficulty of getting it
> right. Again there isn't anything wrong with a simple
> rig, but you will get the most bang and performance
> for the buck, your experience, time spent sorting out
> details, if no particular part of you boat is
> dispropotionately more complex than the other. If the
> fin keel is desined to give you lift to windward that
> your sail plan can't match, what is the point. But I
> sdon't know thatthat is the case, since your design
> isn't in any detail yet.
> The hull shape reminds me of a trimaran, that's one
> way to get that kind of form stability.
> --- Todd <bitme1234@y...> wrote:
> <HR>
> <html><body>
> <tt>
> Thanks for the ideas . Not to round from mid ship back
> to the stern. <BR>
> Keel Bulb, use somthing like the his her schooner
> dagger board.<BR>
> <BR>
> Whats wrong with putting the simple rig on the so
> called complex hull.<BR>
> <BR>
> I'm not much of a designer I know, but would love to
> hear how to make <BR>
> this shape or similar shape work . Seems to me similar
> shapes have <BR>
> proven to be very stable and very fast.<BR>
> <BR>
> Its not so much wider than the micro. <BR>
> <BR>
> Why do I need more rocker? How much rocker? I want the
> hull to just <BR>
> kiss the water while still. "like in the not to
> scale drawing". If <BR>
> this is achievable? <BR>
> <BR>
> Thanks ,<BR>
> Todd<BR>
> <BR>
> The pics are in the photos file on the left.
> <BR>
> <BR>
> --- In bolger@y..., proaconstrictor@y... wrote:<BR>
> > It doesn't look all that much like a sharpie, It
> is hugely fat, if <BR>
> it <BR>
> > ever did get over on it's side, there would be a
> tremendous <BR>
> assymetry <BR>
> > to the hull due to the very rounded sides and
> flat bottom. A bulb <BR>
> > keel would destroy her ability to be shoal draft
> (retractible?), <BR>
> and <BR>
> > one would have to wonder why embrace all that
> complexity below the <BR>
> > water line, and then put such a plan rig
> above.<BR>
> > <BR>
> > People have tried this kind of approach before,
> but with narrower <BR>
> > hulls. Something part way might be found
> under the Norwalk Island <BR>
> > Sharpie. If you want more info on sharpies,
> look at Ruel Parker's <BR>
> > book.<BR>
> > <BR>
> > To make your design efforts easier you might look
> for one of the <BR>
> hull <BR>
> > design programs out there. I have low end pro
> version, so I don't <BR>
> > know much about the freebies, except they
> exist.<BR>
> > <BR>
> > <BR>
> > --- In bolger@y..., "Todd"
> bitme1234@y... wrote:<BR>
> > > I have posted a design that I drew with my
> paint program in <BR>
> > pictures. <BR>
> > > kind of a scaled down performance sharpie
> 6.5. Its sort of a <BR>
> > sharpie <BR>
> > > isn't it?<BR>
> > > I want to build as soon as i figure out the
> numbers.<BR>
> > > <BR>
> > > What do you think?<BR>
> > > <BR>
> > > Todd<BR>
> <BR>
> </tt>
> <br>
> <!-- |**|begin egp html banner|**| -->
> <table border=0 cellspacing=0 cellpadding=2>
> <tr bgcolor=#FFFFCC>
> <td align=center><font size="-1"
> color=#003399><b>Yahoo! Groups Sponsor</b></font></td>
> </tr>
> <tr bgcolor=#FFFFFF>
> <td align=center width=470><table border=0
> cellpadding=0 cellspacing=0><tr><td align=center><font
> face=arial size=-2>ADVERTISEMENT</font><br><a
href="http://rd.yahoo.com/M=213858.1737107.3257770.1261774/D=egroupweb
/S=1705065791:HM/A=763352/R=0/*http://www.classmates.com/index.tf?
s=5085"
> target=_top><img
src="http://us.a1.yimg.com/us.yimg.com/a/cl/classmates_com2/bll_lrec1.
gif"
> alt="" width="300" height="250"
> border="0"></a></td></tr></table></td>
> </tr>
> <tr><td><img alt="" width=1 height=1
> src="http://us.adserver.yahoo.com/l?
M=213858.1737107.3257770.1261774/D=egroupmail/S=1705065791:HM/A=763352
/rand=550860725"></td></tr>
> </table>
> <!-- |**|end egp html banner|**| -->
> <br>
> <tt>
> Bolger rules!!!<BR>
> dead horses<BR>
> topic, and punctuate<BR>
> snip all you like<BR>
> Gloucester, MA, 01930, Fax: (978) 282-1349<BR>
> - Unsubscribe:
> bolger-unsubscribe@y...</tt>
> <br>
> <br>
> <tt>Your use of Yahoo! Groups is subject to the <a
> href="http://docs.yahoo.com/info/terms/">Yahoo! Terms
> of Service</a>.</tt>
> </br>
> </body></html>
> _______________________________________________________
> Build your own website in minutes and for free at
http://ca.geocities.com
--- Todd <bitme1234@...> wrote:
<HR>
<html><body>
<tt>
to the stern. <BR>
dagger board.<BR>
<BR>
<BR>
shapes have <BR>
<BR>
<BR>
hull to just <BR>
<BR>
Thanks ,<BR>
Todd<BR>
<BR>
<BR>
<BR>
it <BR>
assymetry <BR>
and <BR>
hull <BR>
</tt>
<br>
</tr>
href="http://rd.yahoo.com/M=213858.1737107.3257770.1261774/D=egroupweb/S=1705065791:HM/A=763352/R=0/*http://www.classmates.com/index.tf?s=5085"
target=_top><img
</tr>
src="http://us.adserver.yahoo.com/l?M=213858.1737107.3257770.1261774/D=egroupmail/S=1705065791:HM/A=763352/rand=550860725"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
<HR>
<html><body>
<tt>
to the stern. <BR>
dagger board.<BR>
<BR>
<BR>
shapes have <BR>
<BR>
<BR>
hull to just <BR>
<BR>
Thanks ,<BR>
Todd<BR>
<BR>
<BR>
<BR>
> It doesn't look all that much like a sharpie, Itis hugely fat, if <BR>
it <BR>
> ever did get over on it's side, there would be atremendous <BR>
assymetry <BR>
> to the hull due to the very rounded sides andflat bottom. A bulb <BR>
> keel would destroy her ability to be shoal draft(retractible?), <BR>
and <BR>
> one would have to wonder why embrace all thatcomplexity below the <BR>
> water line, and then put such a plan rigabove.<BR>
> <BR>but with narrower <BR>
> hulls. Something part way might be foundunder the Norwalk Island <BR>
> Sharpie. If you want more info on sharpies,look at Ruel Parker's <BR>
> book.<BR>for one of the <BR>
> <BR>
hull <BR>
> design programs out there. I have low end proversion, so I don't <BR>
> know much about the freebies, except theyexist.<BR>
> <BR><bitme1234@y...> wrote:<BR>
> <BR>
> > I have posted a design that I drew with mypaint program in <BR>
> pictures. <BR>6.5. Its sort of a <BR>
> sharpie <BR>numbers.<BR>
> > isn't it?<BR>
> > <BR><BR>
> > <BR>
> > Todd<BR>
</tt>
<br>
</tr>
target=_top><img
</tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
Thanks for the ideas . Not to round from mid ship back to the stern.
Keel Bulb, use somthing like the his her schooner dagger board.
Whats wrong with putting the simple rig on the so called complex hull.
I'm not much of a designer I know, but would love to hear how to make
this shape or similar shape work . Seems to me similar shapes have
Why do I need more rocker? How much rocker? I want the hull to just
kiss the water while still. "like in the not to scale drawing". If
this is achievable?
Thanks ,
Todd
this is achievable?
Thanks ,
Todd
> It doesn't look all that much like a sharpie, It is hugely fat, if
it
> ever did get over on it's side, there would be a tremendous
assymetry
> to the hull due to the very rounded sides and flat bottom. A bulb
> keel would destroy her ability to be shoal draft (retractible?),
> one would have to wonder why embrace all that complexity below the
> water line, and then put such a plan rig above.
> People have tried this kind of approach before, but with narrower
> hulls. Something part way might be found under the Norwalk Island
> Sharpie. If you want more info on sharpies, look at Ruel Parker's
> book.
> To make your design efforts easier you might look for one of the
hull
> design programs out there. I have low end pro version, so I don't
> know much about the freebies, except they exist.
> --- In bolger@y..., "Todd" <bitme1234@y...> wrote:
> > I have posted a design that I drew with my paint program in
> pictures.
> > kind of a scaled down performance sharpie 6.5. Its sort of a
> sharpie
> > isn't it?
> > I want to build as soon as i figure out the numbers.
> > What do you think?
> > Todd
Todd, where can I see it? (Probably obvious, but I dont see where to
go.)
- Bill
Sent: Thursday, November 22, 2001 11:15 AM
Subject: [bolger] performance sharpie design
I have posted a design that I drew with my paint program in pictures.
kind of a scaled down performance sharpie 6.5. Its sort of a sharpie
isn't it?
What do you think?
Todd
<http://rd.yahoo.com/M=213858.1737107.3257770.1261774/D=egroupweb/S=1705
065791:HM/A=763352/R=0/*http://www.classmates.com/index.tf?s=5085>
go.)
- Bill
isn't it?
What do you think?
Todd
It doesn't look all that much like a sharpie, It is hugely fat, if it
ever did get over on it's side, there would be a tremendous assymetry
keel would destroy her ability to be shoal draft (retractible?), and
book.
To make your design efforts easier you might look for one of the hull
book.
pictures.
sharpie
> isn't it?
> What do you think?
> Todd
isn't it?
What do you think?
Todd
isn't it?
What do you think?
Todd
