Re: [bolger] Re: building a Sneakeasy
Perfectly clear, and I am sure it worked out great. I
certainly understand your desire to have your boat set
up accurately.
In all cases that would not necesarily create the
layout from the plans, however, which was why I asked.
Since stringers between bulkheads can lie differently
from what the layout is, bent sticks will normaly free
form to a prabolic shape, while a lot of the Bolger's
boats seem to have circular sections. That's just
theory, there probably isn't fraction of an inch
difference in it.
---sneakeasy2000@...wrote:
out the panels to <BR>
exact measurements but rather built the frames(molds)
to be exactly <BR>
like the plans and glued and fastened the panels,
which I cut <BR>
slightly oversized, onto the stringer and chine logs
and trimmed off <BR>
the excess.<BR>
I threw away my sides drawings/patterns (having plotted them out to
tyvek), clamped my sheets directly to the sides/stringers, and
transferred the shape for cutting. Very easy.
Gregg Carlson
> I'm sure your right. How will/have you handle/d the
> possibility that the panel outlines may differ from
> the stringer outlines?
> >I guess it is a matter of personal <BR>
> preference.  <BR>
> <BR>
I guess I wasn't too concerned. I did not lay out the panels to
exact measurements but rather built the frames(molds) to be exactly
like the plans and glued and fastened the panels, which I cut
slightly oversized, onto the stringer and chine logs and trimmed off
the excess.
Steve Bosquette
> preference.  <BR>
> <BR>
preference.  <BR>
<BR>
Thanks Harry
It was my second stop after Greg Carlsons's site.
Steve Bosquette
--- In bolger@y..., "Harry W. James" <welshman@p...> wrote:
> You checked out Fritz's page?
>http://www.alaska.net/~fritzf/Boats/Sneakeasy/Sneakeasy.htm
> HJ
> sneakeasy2000@y... wrote:
> > Is anyone else in the group building a Sneakeasy? I'm about 3/4
done
> > with mine, if the group is interested I have a website for her:
> >http://geocities.com/sneakeasy2000/index.html
> > I would like to hear from a fellow Sneakeasy builder.
> > Steve Bosquette
I approached it from a setup point of view. I was mainly concerned
with getting everything square. Gregg Carlson built his by doing as
you say, mounting the chine logs and sheer stringer on the panels
first. Each works fine , I guess it is a matter of personal
preference.
Steve Bosquette
> Nice site. I'm thinking about it.
> Neat way to build her, kind of like a skin boat. Is
> there any particular reason why you aren't just
> nailing the strigers to the ply, and bending her
> around molds?
> about 3/4 done <BR>
> for her:<BR>
> Is anyone else in the group building a Sneakeasy? I'm about 3/4 done
> Steve Bosquette
around molds?
about 3/4 done <BR>
for her:<BR>
Steve Bosquette
