[bolger] Re: Router uses
Robert,
Sounds like a good use for the router, though I do hope you wore
respiration gear. That must make some serious glass flecks to breathe.
I'd agree a piloted straight bit is my favorite. If I'm ever making
more then 1 of anything flat I make the first exactly right, then clamp
it under a slightly oversized blank and use it as a template. And to
cut dead straight edges in plywood nothing beats a straight bit. I
bought a metal 8' straight edge just for that
Of course, nothing on a boat is straight and you rarely need 2 of
anything but maybe this will change if you build some interior
cabinetry. <s>
Enjoy
Ernie
"robert n. lundy" <rober-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=1568
cabinetry. <s>
Enjoy
Ernie
> About two weeks ago I was deciding how to get the untrimmed (about1-2")
> glass epoxy strip that overhung my Windsprint chines trimmed and wasbeing
> pretty unsuccessful with scissors and a utility knife. I know you'reto
> supposed to trim this while the epoxy is "gelling" but I wasn't going
> touch a thing, since the process had gone pretty well for me as abit.
> first-timer.
> Anyway, I hit in the idea of using the router with a laminate trimmer
> There was barely enough room for the little bearing to ride and stillhave
> the cutter working, but what a great job this did! I don't eventhink it
> needs any sanding/finishing.works on
> So my question is, has anyone else done this? Obviously it only
> external chine log boats, but I'm surprised I've never read about it.there was
> Oh, and the funny part happens when you hit one of the areas where
> very little epoxy drip: when that cutter head gets dry glass coth init, you
> feel like you're harvesting raw cotton fibers. One tiny patch ofglass made
> a tumbleweed about 4" in diameter.
> Robert & Amy Lundy
> St. Petersburg, fla.
>robert@...
>amy@...
I built a couple of new saw horses last week. Rather than measure and cut
the 1/4" plywood gussets on the sides, I simply nailed scraps of ply to the
legs and trimmed it off flush with -- you guessed it -- my router fitted
with a laminate trimming bit.
When it get time to cut out the windows on IMB, the router will go to work
again. It is very useful tool for us lazy types, isn't it?
John Bell
Kennesaw, GA
jmbell@...
John Bell
Kennesaw, GA
jmbell@...
To: A-Bolger List <bolger@egroups.com>
Sent: Thursday, January 06, 2000 6:24 PM
Subject: [bolger] Router uses
> About two weeks ago I was deciding how to get the untrimmed (about 1-2")
> glass epoxy strip that overhung my Windsprint chines trimmed and was being
> supposed to trim this while the epoxy is "gelling" but I wasn't going to
> first-timer.
> Anyway, I hit in the idea of using the router with a laminate trimmer bit.
> There was barely enough room for the little bearing to ride and still have
> the cutter working, but what a great job this did! I don't even think it
> So my question is, has anyone else done this? Obviously it only works on
> Oh, and the funny part happens when you hit one of the areas where there
was
> very little epoxy drip: when that cutter head gets dry glass coth in it,
you
> feel like you're harvesting raw cotton fibers. One tiny patch of glass
made
> Robert & Amy Lundy
>robert@...
>amy@...
> FreeLotto.com is the only internet site to offer three free chances
> a day to win $1,000,000.00. We've already had two $1,000,000.00
> jackpot winners and thousands of other cash prizes. You could be
> a $1,000,000.00 winner tonight!
>http://click.egroups.com/1/445/5/_/3457/_/947201125
first-timer.
Oh, and the funny part happens when you hit one of the areas where there was
very little epoxy drip: when that cutter head gets dry glass coth in it, you
feel like you're harvesting raw cotton fibers. One tiny patch of glass made
Robert & Amy Lundy
robert@...
amy@...
first-timer.
Robert & Amy Lundy
robert@...
amy@...
