Re: [bolger] Re: Sailing a Micro (newbie)
Sent: Saturday, December 29, 2001 8:55 PM
Subject: Re: [bolger] Re: Sailing a Micro (newbie)
> G'day
> re : your problem with out board motor
> I was up against the same problem tryng to fit my outboard into the Long
> Micro I am building. I got around it by introducing a curve to the top of
> the transom this gained me about 2 inches or more.
> You can see what I have done at the the website I'm putting together (
just
> updated )
> I'm as interested as you regarding other's suggestions for mooring lines
> etc.
> Good luck with sorting it out.
> My website athttp://members.tripod.com/rivaldukesite has lots of
> construction pictures and takes awhile to load
> Thanks Andrew Pryer
> Victoria
> Australia
> From: "ellengaestboatbuildingcom" <ellengaest@...>
> Sent: Saturday, December 29, 2001 1:50 AM
> Subject: [bolger] Re: Sailing a Micro (newbie)
> > --- In bolger@y..., "robertsmme" <martin.me.roberts@b...> wrote:
> > > I have just purchase a 2nd hand micro, and was wondering if any one
> > > could give me tips on sailing one. I live on a tidal estuary, The
> > > Deben in eastern England and would appreciate any help and piinters
> > > that people can give. I am concerned about two things in
> > particular:
> > > 1) As the rear bulkhead was not adjusted for a larger motor the
> > motor
> > > has been put on a bracket behind the rear bulkhead. This means
> > > reaching it is going to be difficult. Any tips on either remotely
> > > controlling the motor or on adjusting the rear bulk head to
> > > accomodate the larger motor.
> > > 2) Attaching the Bow to a mooring or anchor. Do you attach them
> > > through the 'ladder' holes or over the bow gunnel?
> > > Thanks
> > Hello Lucky Micro owner,
> > When you say the transom was not adjusted for a larger motor,are
> > you refering to the vertical dimension? If so,then the easy solution
> > is to cut out the top section over the opening and install a
> > traveller horse.You can also widen the opening a wee bit too,if that
> > is tight.
> > As to the anchoring question,I resolved mine through the
> > installation of a hawse pipe located between to two step cut-outs.
> > Hopefully,other satisfied Micro owners will chime in with other
> > solutions to ensure trouble free use of your boat!
> > Sincerely,
> > Peter Lenihan,happy Micro owner................
> > - pls take "personals" off-list, stay on topic, and punctuate
> > - add your comments at the TOP and SIGN your posts, snip all you like
> > - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,
> 01930, Fax: (978) 282-1349
Robert,
I solved the problem by purchasing a motor that fits in the hole.
I found a 4hp 1973 Evinrude Yachtwin with a 20" shaft that fits it
perfectly. The funny thing is, I owned one of these up until about 2
years prior to starting my Micro. It is a great motor and easy to
service and maintain. (now, to find a new impeller and spark plugs)
I have had to unwrap Micro twice this season due to curious
onlookers. People can't get enough of her. I wish it was about 40
degrees warmer so I could work on her.
For a bow strap, you could take a piece of stainless pipe or rod, and
bend it around the sides near the water line. and attach the mooring
line / trailer cable to that. I am just going to make it fast to the
mast through the holes in the bow transom, or through a hawser like
Peter did (very shippy, that). Wrapping the mooring line with garden
hose and chaffing tape works quite well.
"not enjoying a snowless New England winter, Maybe time to take up
hard water sailing"
hard water sailing"
> 1) As the rear bulkhead was not adjusted for a larger motor themotor
> Thanks
G'day
You can see what I have done at the the website I'm putting together ( just
updated )
etc.
Thanks Andrew Pryer
Victoria
Australia
updated )
etc.
Thanks Andrew Pryer
Victoria
Australia
> particular:
> motor
> > Thanks
> is tight.
> Sincerely,
Good luck with your Micro.
1. My motor hit the beam across the top too. I cut the middle
section of beam out, and put a strut both sides back to the
bulkhead. This worked fine, and gives an easy step-thru boarding
access from the dinghy, when the motor is not in place.
2. I think there may be a time when you want to free your mooring
rope completely and quickly, and not a good idea to have it through a
permanent port.
I fixed a strong ply breasthook on top, connecting the bow transom to
the gunwales, and fitted a roller fitting with release pin to the
front, and a large mooring cleat on the top of cabin bulkhead, offset
so rope misses the mast. This setup worked without fault on a
terribly exposed mooring.
DonB
permanent port.
DonB
particular:
motor
> Thanks
is tight.
> I have just purchase a 2nd hand micro, and was wondering if any oneparticular:
>motor
> has been put on a bracket behind the rear bulkhead. This meansHello Lucky Micro owner,
> Thanks
is tight.
that people can give. I am concerned about two things in particular:
1) As the rear bulkhead was not adjusted for a larger motor the motor
Thanks
Thanks
