Re: [bolger] Re: Galvanize Your Own??
Acetone would be better than nothing, but To get that spray on zinc stuff
to really work you probably have to go through the whole caustic soda wash,
then acid bath route like you would to prepare for real hot dip
galvanizing. It'd be interesting to see how the stuff holds up when applied
to well prepared metal like that.
On Fri, 04 Jan 2002 20:54:42 -0000, Richard Spelling wrote:
> Ah, I take it then that it won't self heal like real hot dipped?
> The peeling could be fixed I'm sure with proper surface prep. Maybe
> acetone to clean off what oils are there?
John <jkohnen@...>
http://www.boat-links.com/
"Necessity is the mother of invention" is a silly proverb.
"Necessity is the mother of futile dodges" is much nearer the truth.
<Alfred North Whitehead>
--- In bolger@y..., "dnjost" <djost@m...> wrote:
> I have used the spray before with limited success. It does perform
> as advertised, but is quite suceptable to scratching and will
peel.
> It is tough to double coat for some reason unkown to me.
> For what it is worth,
> David Jost
> > "Galvanizing Metal Coatings
> > Protects iron and steel just as well as hot-dip
galvanizing.
> > Coatings are solvent based. Brush, roll, spray, or dip them in
> > exterior and well-ventilated interior applications.
> > Cold Galvanizing Coating For long-term rust protection.
This
> > coating "sacrifices" itself to keep corrosion off the surface
it's
> > protecting. Meets MIL-P-46105, MIL-P-21035, and DOD-P-21035a. "
> > Go to www.mcmaster.com, search for "cold galvanizing"
> > --- In bolger@y..., Gronicle <Gronicle@c...> wrote:
> > > > Message: 21
> > > > Date: Wed, 2 Jan 2002 19:21:23 -0500
> > > > From: "David Allen"
> > > > Subject: Hot dipped zinc
> > > > anyone familiar with the hot dip process? in particular, can
I
> > take old
> > > > anodes, melt them down and dip iron parts for use at sea?
> > > > da
> > > Somehow this rings a bell with me. The melting point on zinc
> > alloys is
> > > really low so it can be done in a good old iron pot on your
crab
> > boiler,
> > > but.... isn't there a real serious health hazard to inhaling
zinc
> > > vapors? Is anyone up to speed on the toxology of heavy metals
> > > poisioning?
> > > Think I would just as soon throw the jing at store bought
> > galvanized or
> > > take my gear down to Uncle Jed's place and have him and the
> > boys "dip"
> > > the stuff for me.
> > > Regards, Bubba K.
> > > [Non-text portions of this message have been removed]
as advertised, but is quite suceptable to scratching and will peel.
> Protects iron and steel just as well as hot-dip galvanizing.
> Cold Galvanizing Coating For long-term rust protection. This
> coating "sacrifices" itself to keep corrosion off the surface it's
> > > Message: 21
> > > From: "David Allen"
> > > anyone familiar with the hot dip process? in particular, can I
> take old
> > > da
> alloys is
> > really low so it can be done in a good old iron pot on your crab
> boiler,
> > but.... isn't there a real serious health hazard to inhaling zinc
> > poisioning?
> galvanized or
> boys "dip"
> > the stuff for me.
> > Regards, Bubba K.
McMaster sells a spray that they claim is as good as hot dip
galvanizing.
galvanizing.
> > Message: 21
> > From: "David Allen"
take old
> > da
alloys is
boiler,
> poisioning?
galvanized or
boys "dip"
> the stuff for me.
> Regards, Bubba K.
> Message: 21Somehow this rings a bell with me. The melting point on zinc alloys is
> From: "David Allen"
> anyone familiar with the hot dip process? in particular, can I take old
> da
really low so it can be done in a good old iron pot on your crab boiler,
poisioning?
Think I would just as soon throw the jing at store bought galvanized or
take my gear down to Uncle Jed's place and have him and the boys "dip"
the stuff for me.
Regards, Bubba K.
