Re: MDO Test with photos
I'll see what I can rig up, and give it a try.
Also I have photos of some Meranti and Doug fir plywood that went
through about the same treatment. I'll stick them in the Photos
section if anyone is interested.
Rick
--- In bolger@y..., "ghartc" <gcarlson@c...> wrote:
> Rick,
> Can you break them? How about sawing them the same size and
breaking
> them in a vise with a crescent wrench and a spring scale?
> Gregg
> --- In bolger@y..., "sctree" <sctree@d...> wrote:
> > Today I passed the 12 month mark on a little informal test on two
> > sided MDO.
> > A year ago I cut up some pieces and stored one inside (warm, dry
> > and out of the sun). The other two I painted with one coat of
latex
> > primer plus one coat of latex semi (only the faces not the
edges).
> Of
> > those two, one lived on my concrete driveway, the other floated
in
> a
> > bucket of water, both in full sun with temps from 25f to 104f.
> > Today I took photos and cut them open.
> > The "bucket" piece is heavy and stained dark from the water.
Other
> > than that they all seem fine.
> > Go see for yourself, I posted pictures in the PHOTO section under
> > "Plywood Test"
> > Comments?
> > Rick
Rick,
Can you break them? How about sawing them the same size and breaking
Gregg
> sided MDO.
> and out of the sun). The other two I painted with one coat of latex
> primer plus one coat of latex semi (only the faces not the edges).
Of
> those two, one lived on my concrete driveway, the other floated in
> The "bucket" piece is heavy and stained dark from the water. Other
> "Plywood Test"
> Comments?
> Rick
sided MDO.
primer plus one coat of latex semi (only the faces not the edges). Of
those two, one lived on my concrete driveway, the other floated in a
"Plywood Test"
Comments?
Rick
