[bolger] Tanton question
Hi folks, just a thought: perhaps Tanton was asked to do the different rig
shown, and the hull, slightly modified as it was, didn't get credited
properly? There
is no doubt that it is basically the same hull, though a little wider at the
stern, but not much, plus a little drop-board on the rudder.
There may be a story behind all this, so we should hear Tanton out, I
imagine.
As an aside, I remember buying a copy of some Trawler Yacht magazine
(Passagemaker?), and the boat on the cover was, to my eyes, definitely a Jay
Benford Florida Bay Coaster type. Yet it turned out to be another designer
who had most of the credit in the article. Just one little sentence early
on
mentioned Benford's boat as a starting point, then spoke of him no more. The
new designer had done a few modifications to the original, including hull
material, but nothing extreme. I was puzzled. The only link was Ruben Trane,
who has built Benford boats in the past of the same type, and also built
this one.
I don't know what Benford thought of this new boat, but it appeared to be
okay with him (or maybe not?). I still thought it odd, but it is evidently
not uncommon.
Tanton's design in question is alot closer to Bolger's, down to some fairly
minute details. Let's ask him what this is all about!
Alex Christie
properly? There
imagine.
on
this one.
not uncommon.
Alex Christie
To: <bschool3@...>
Sent: Tuesday, January 11, 2000 10:54 AM
Subject: bolger digest
> eGroups Daily Digest: bolger has 21 new messages.
> Click here http://www.eGroups.com/list/bolger/?start=1599 to read them.
> 1599. Carlos Byars Re: Windsprint Progress
> 1600. Richard Re: Windsprint Progress
> 1601. Belenky, Peter Patrick O'Brian appreciation.
> 1602. david Re: Windsprint Progress
> 1603. Robert N. Lundy Re: Windsprint Progress
> 1604. Richard sharpie catamaran
> 1605. Fraser Howell cold weather epoxy
> 1606. tjfatchen@... Re: Windsprint Progress
> 1607. Ryan, Larry Remove from List
> 1608. Giuseppe 'Pippo' Bianco Epoxy: shelf life and cold weather
> 1609. Giuseppe 'Pippo' Bianco ...forgot to add
> 1610. Robert N. Lundy Re: cold weather epoxy
> 1611. Hwal@... Re: Martha Jane/Birdwatcher cross.
> 1612. peter lenihan cold cure epoxy
> 1613. peter lenihan as 29
> 1614. Richard Re: as 29
> 1615. tjfatchen@... as 29 cloned
> 1616. Richard Re: as 29
> 1617. Richard Re: as 29
> 1618. Chuck Merrell Re: as 29
> 1619. tjfatchen@... Re: as 29
> ------------------------------ message 1599 ------------------------------
> From: "Carlos Byars" <c_byars@...>
> Date: Mon, 10 Jan 2000 08:58:00 CST
> X-Mailing-List: bolger@egroups.com
> Subject: [bolger] Re: Windsprint Progress
> MIME-Version: 1.0
> Content-Type: text/plain; format=flowed
> Content-Transfer-Encoding: 7bit
> I hope you arranged for a temperature high enough, or used a fast hardner.
I
> used slow setting stuff that 6 weeks later is still is not cured. Since I
> can't scrape it off, I'm trashing those sheets and starting over. With
> another epoxy, to be sure. Far as I can tell, epoxy work is strictly a
> summer-time occupation.
> ______________________________________________________
> ------------------------------ message 1600 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1600
> Date: Mon, 10 Jan 2000 09:08:15 -0600
> From: Richard <richard@...>
> References: <20000110145800.37780.qmail@...>
> MIME-Version: 1.0
> Content-Type: text/plain; charset=us-ascii
> You can apply it in cold weather, but you need to use the proper hardener
and/or
> heat the work.
> I've put Raka on with fast hardener, and two days later it was still soft.
The
> instructions say "must be 50 degrees for 12 hours". I turned the heat up
in the
> shop overnight and all was well.
hardner. I
I
> > FreeLotto.com is the only internet site to offer three free chances
> > a day to win $1,000,000.00. We've already had two $1,000,000.00
> > jackpot winners and thousands of other cash prizes. You could be
> > a $1,000,000.00 winner tonight!
> > http://click.egroups.com/1/445/5/_/3457/_/947516283/
> > -- 20 megs of disk space in your group's Document Vault
> > -- http://www.egroups.com/docvault/bolger/?m=1
> ------------------------------ message 1601 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1601
> From: "Belenky, Peter" <Peter.Belenky@...>
> Date: Mon, 10 Jan 2000 10:41:02 -0500
> Subject: [bolger] Patrick O'Brian appreciation.
> MIME-Version: 1.0
> Content-Type: text/plain; charset="iso-8859-1"
> A personal memoir of encounters with Patrick O'Brian by Washington Post
> reporter Ken Ringle, who wrote an article headlined "Is This the Greatest
> Writer You've Never Heard Of?" which introduced O'Brian to a wider
American
> public.
http://search.washingtonpost.com/wp-srv/WPlate/2000-01/08/089l-010800-idx.ht
> ml
> ------------------------------ message 1602 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1602
> Date: Mon, 10 Jan 2000 11:55:21 -0800
> From: david <galvind@...>
> MIME-Version: 1.0
> Carlos:
> It has been my experience (limited to West System products, mostly, but
> chemistry is chemistry) that epoxy will set and cure, eventually. Either
you
> have to raise the ambient temperature in the workshop artificially or you
have
> to wait for Springtime to do it naturally. I discovered this during the
three
> year construction of a 22' Benford Gunkholer in a poorly heated, poorly
> insulated shop in the Catskill Mountains. Winter temps outside were
about -10 to
> 30 F (-24 to -1 C), and inside temps were seldom above 40 F (5 C). None
> less, the epoxy all went off, although it sometimes took weeks and the
resulting
> amine blush was like snow on a mountain. The construction delays were
great
> opportunities to hunker down by the fire and hibernate (vegetate?),
> david
hardner. I
I
> ------------------------------ message 1603 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1603
> From: "Robert N. Lundy" <robert@...>
> Date: Mon, 10 Jan 2000 12:42:12 -0500
> In-Reply-To: <20000110145800.37780.qmail@...>
> MIME-Version: 1.0
> Living in florida has advantages. Especially when it comes to epoxy. At
> the same time, the cure time for the stem/sternpost has been about twice
as
> long as for the other work I did in warmer weather, with only about a 15
> degree (72 degrees vs 87 degrees) difference in daily highs.
> For Carlos' and everone's benefit, has anyone tried any of the "cold"
> weather epoxies? some of these purport to cure at anything above 32
> degrees. Reports appreciated.
> Robert & Amy Lundy
> St. Petersburg, fla.
> robert@...
> amy@...
> > From: Carlos Byars [mailto:c_byars@...]
> > Sent: January 10, 2000 9:58 AM
> > To: bolger@egroups.com
> > hardner. I
I
> ------------------------------ message 1604 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1604
> Date: Mon, 10 Jan 2000 14:48:16 -0600
> Subject: [bolger] sharpie catamaran
> MIME-Version: 1.0
> Ran accross a picture of a Bolger designed 16' catamaran....
> The ones I know of are this 16 footer, the single handed one, and the
> auckland cat.
> Are there more? Anybody built one? Any sailing reports?
> ------------------------------ message 1605 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1605
> Date: Mon, 10 Jan 2000 18:14:10 -0400
> From: fraser.howell@... (Fraser Howell)
> References: <LOBBLGCPIDMGNHNEEBNCEEGLCFAA.robert@...>
> Subject: [bolger] cold weather epoxy
> MIME-Version: 1.0
> The temperature here in Halifax has been a few degrees either side of
> freezing. I am making a mast for my chebacco, using the "birdsmouth"
> cutout technique recently described in WOODENBOAT. All joints are with
> "cold cure" epoxy. The epoxy joints are set up and workable with edge
> tools in 72 hr, but probably take a couple of weeks to reach total cure.
> The plus side is the long working life of a pot of mixed epoxy. It took
> me about two hours, working by myself, to apply the glue, and get the
> strakes lined up and clamped. The stuff is made by Industrial
> Formulators of Canada Ltd., and it is fairly expensive.
> ------------------------------ message 1606 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1606
> From: tjfatchen@...
> Date: Tue, 11 Jan 2000 08:40:06 -93000
> MIME-Version: 1.0
> BO>For Carlos' and everone's benefit, has anyone tried any of the "cold"
> BO>weather epoxies? some of these purport to cure at anything above 32
> BO>degrees. Reports appreciated.
> BO>Robert & Amy Lundy
> As this product is unavailable in the US (only its imitators :-) this is
> perhaps not a great deal of help -- however, BoteCote epoxy using its
> fast hardener cures in a period of about a day with temperatures below
> 40F tho' not below the magic 32F (our little mountain is a cold hole in
> winter). WEST system or system three must surely carry an equivalent.
> Flip side is that it goes off in half an hour in the height of summer...
> Tim & Flying Tadpole
> ------------------------------ message 1607 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1607
> From: "Ryan, Larry" <ryanld@...>
> Date: Mon, 10 Jan 2000 17:16:11 -0500
> Subject: [bolger] Remove from List
> MIME-Version: 1.0
> Please remove my name from the distribution list. Thanks.
> ------------------------------ message 1608 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1608
> Date: Mon, 10 Jan 2000 16:02:26 -0800
> From: "Giuseppe 'Pippo' Bianco" <pippobianco@...>
> Subject: [bolger] Epoxy: shelf life and cold weather
> MIME-Version: 1.0
> Hi all - yesterday I used again my epoxy, more than 2 years old. It
> worked without any problem. Another good surprise was that, in spite of
> the low temperature in my garage (10 degs C), it set up tack free in 24
> hours. The only "tricks" I used was to worm up the plywood and the
> resin before mixing. Now I have my two test butt joints (one is a
> classical ply butt, the other is the Carnell/Payson fiberglass splice)
> in my apartment to allow for full cure before breaking them...
> Regarding the FG splice, well, it's much simpler than I expected, and
> the finish is almost perfect already...
> Keep in touch
> Pippo
> ------------------------------ message 1609 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1609
> Date: Mon, 10 Jan 2000 16:09:06 -0800
> Subject: [bolger] ...forgot to add
> MIME-Version: 1.0
> Hi again - I forgot to add that my epoxy is a no-brand one. It's made
> by an Italian company (no web site), and costs, say, about 1/6th w.r.t.
> to famous Italian or foreign brands. It mixes with a 3:1 ratio (in
> weight) and has a long pot life (even in summer it remains workable for
> 30 minutes). It's very fluid because it's specifically designed for
> ambient temperature use on wood.
> Best, Pippo
> ------------------------------ message 1610 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1610
> Date: Mon, 10 Jan 2000 21:49:01 -0500
> In-reply-to: <387A59B2.5996D93F@...>
> Subject: [bolger] Re: cold weather epoxy
> MIME-Version: 1.0
> Hi Fraser, thanks for the input. Especially the part about pot life and
> birds mouth spar making. As I start to contemplate my Windsprint mast,
this
> info will be handy, as I had planned to use the birds mouth method as
well.
> I know I can get 45 minutes of pot life out of the stuff I'm using and
> Windsprint's mast is smaller (16') but not that much less work.
> Why the replacement for your current Chebacco mast? Just going for
> lightness or did you have a failure?
> Robert & Amy Lundy
> robert@...
> amy@...
> > From: Fraser Howell [mailto:fraser.howell@...]
> > Sent: January 10, 2000 5:14 PM
> > http://click.egroups.com/1/445/5/_/3457/_/947542336/
> ------------------------------ message 1611 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1611
> From: Hwal@...
> Date: Mon, 10 Jan 2000 22:26:37 EST
> Subject: [bolger] Re: Martha Jane/Birdwatcher cross.
> MIME-Version: 1.0
> Content-Type: text/plain; charset="us-ascii"
> In a message dated 1/9/2000 6:09:29 PM Eastern Standard Time,
pcb@...
> writes:
> << In a little while there will be a comprehensive upgrade of MARTHA JANE
> covering
> new leeboard geometry, rudder alternative, and 'house'.
> Being just about done with my martha jane - I'm wondering if any of these
> upgrades - the leeboards in particular - will be able to be adapted for
> existing martha janes?? Steve Anderson
> ------------------------------ message 1612 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1612
> Date: Mon, 10 Jan 2000 23:06:02 -0800
> From: "peter lenihan" <widsith@...>
> Subject: [bolger] cold cure epoxy
> MIME-Version: 1.0
> To Fraser and co.,
> Cold Cure epoxy is indeed great stuff for when things get a bit
> nippy outside especially for us Canucks!Industrial Formulators of
> Canada was recently purchased by the folks at System Three Epoxies and
> I have been assured that the product line will not be changed!I now
> pray nightly that the only change will be a lowering of the price of
> their excellent products!
> Regards,
> Peter L.
> ------------------------------ message 1613 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1613
> Date: Tue, 11 Jan 2000 01:02:22 -0800
> Subject: [bolger] as 29
> MIME-Version: 1.0
> I am not sure what is going on here but I would invite one and all to
> take a look at the following sight(www.tantonyachts.com) and go to the
> designs section.Once there,look at design number 980.Now,unless I have
> missed something during the Y2K partying,this is a AS 29.Perhaps
> Mr.Bolger should be informed of this especially as he appears to have
> been"ripped off"in the past with alot of his copyrighted work.
> At any rate,I sure would like to here an explaination for this apparent
> copy of the venerable AS 29.
> Regards,
> Peter L.
> ------------------------------ message 1614 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1614
> Date: Tue, 11 Jan 2000 08:43:11 -0600
> References: <85eriu$odk8@...>
> Subject: [bolger] Re: as 29
> MIME-Version: 1.0
> Content-Type: multipart/alternative;
boundary="------------A630EAFF986981AD98E31478"
> --------------A630EAFF986981AD98E31478
> charset="us-ascii"
> content-transfer-encoding: 7bit
> http://www.tantonyachts.com/images10.htm#No. 980
> Sure looks like one to me.
> > Regards,
> > Peter L.
> > http://click.egroups.com/1/445/5/_/3457/_/947601158/
> > -- Create a poll/survey for your group!
> > -- http://www.egroups.com/vote?listname=bolger&m=1
> Content-Type: text/html;
> charset="us-ascii"
> <!doctype html public "-//w3c//dtd html 4.0 transitional//en">
> <html>
> <A
HREF="http://www.tantonyachts.com/images10.htm#No">http://www.tantonyachts.c
om/images10.htm#No</A>. 980
> <br>Sure looks like one to me.
> <p>peter lenihan wrote:
> <blockquote TYPE=CITE>I am not sure what is going on here but I would
invite
> one and all to
> <br>take a look at the following sight(www.tantonyachts.com) and go to
> the
> <br>designs section.Once there,look at design number 980.Now,unless I have
> <br>missed something during the Y2K partying,this is a AS 29.Perhaps
> <br>Mr.Bolger should be informed of this especially as he appears to have
> <br>been"ripped off"in the past with alot of his copyrighted work.
> <br>At any rate,I sure would like to here an explaination for this
apparent
> <br>copy of the venerable AS 29.
<br>
&nbs
p; &n
bsp;
> Regards,
<br>
&nbs
p; &n
bsp;
> Peter L.
<p>------------------------------------------------------------------------
> <br>FreeLotto.com is the only internet site to offer three free chances
> <p>a day to win $1,000,000.00. We've already had two $1,000,000.00
> <p>jackpot winners and thousands of other cash prizes. You could
> be
> <p>a $1,000,000.00 winner tonight!
> <br><a
href="http://click.egroups.com/1/445/5/_/3457/_/947601158/">http://click.egr
oups.com/1/445/5/_/3457/_/947601158/</a>
> <p>-- Create a poll/survey for your group!
> <br>-- <a
href="http://www.egroups.com/vote?listname=bolger&m=1">http://www.egroups.co
m/vote?listname=bolger&m=1</a></blockquote>
> </body></html>
> --------------A630EAFF986981AD98E31478--
> ------------------------------ message 1615 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1615
> From: tjfatchen@...
> Date: Wed, 12 Jan 2000 01:16:00 -93000
> Subject: [bolger] as 29 cloned
> MIME-Version: 1.0
> BO>I am not sure what is going on here but I would invite one and all to
> BO>take a look at the following sight(www.tantonyachts.com) and go to the
> BO>designs section.Once there,look at design number 980.Now,unless I have
> BO>missed something during the Y2K partying,this is a AS 29.Perhaps
> BO>Mr.Bolger should be informed of this especially as he appears to have
> BO>been"ripped off"in the past with alot of his copyrighted work.
> BO>At any rate,I sure would like to here an explaination for this apparent
> BO>copy of the venerable AS 29.
> BO> Regards,
> BO> Peter L.
> You're dead right Peter. The only differences are the rig, the extended
> bow (to a point) and the slightly extended dog-house. From their
> diagram, there are even the same number of shelves next to the head, the
> cockpit has exactly the same slope (I know, cos mine was built without
> it, grrr), double berth's the same shape, identical bulkheads etc etc.
> Tim & Lady Kate
> ------------------------------ message 1616 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1616
> Date: Tue, 11 Jan 2000 08:47:09 -0600
<387B417F.6C0BA5B2@...>
> MIME-Version: 1.0
boundary="------------43530DE3D81C94B34674AB78"
> --------------43530DE3D81C94B34674AB78
> charset="us-ascii"
> >> to
> >> the
> >> have
> >> have
> >> apparent
> >> Regards,
> >> Peter L.
> > [Click Here!]
> > eGroups.com Home: http://www.egroups.com/group/bolger
> > www.egroups.com - Simplifying group communications
> Content-Type: multipart/related;
> boundary="------------96132C325DCE40AA7607E1B4"
> --------------96132C325DCE40AA7607E1B4
> charset="us-ascii"
> <html>
> <a
href="http://www.tantonyachts.com/images10.htm#No">http://www.tantonyachts.c
om/images10.htm</a>
> <br>
> <p>Richard wrote:
> <blockquote TYPE=CITE><a
om/images10.htm#No</a>.
> 980
invite
> one and all to
> the
apparent
<br>
&nbs
p; &n
bsp;
> Regards,
<br>
&nbs
p; &n
bsp;
> Peter L.
> be
> <br><a
> <br>-- <a
> <hr>
> <center><!-- begin banner runid: 448 crid: 153 -->
> <br><a href="http://click.egroups.com/1/448/5/_/3457/_/947602148/"
target="egnewwin"><img
SRC="cid:part1.387B4266.43211279@..." ALT="Click Here!"
BORDER=0 height=60 width=468></a>
> <br><!-- end banner --></center>
> eGroups.com Home: <a
href="http://www.egroups.com/group/bolger">http://www.egroups.com/group/bolg
er</a>
> <br><a href="http://www.egroups.com">www.egroups.com</a> - Simplifying
> group communications</blockquote>
> </body></html>
> Content-Type: image/gif
> content-disposition: inline; filename="C:\WINDOWS\TEMP\nsmail7C.gif"
> content-id: <part1.387B4266.43211279@...>
> content-transfer-encoding: base64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> inDIh18Yg0fogeXETa6IgC04Th4qqBe3OBm9WIS4WIzGeIzImIzKuIzM2IzO+IzGGAQAOw==
> --------------96132C325DCE40AA7607E1B4--
> --------------43530DE3D81C94B34674AB78--
> ------------------------------ message 1617 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1617
> Date: Tue, 11 Jan 2000 08:47:28 -0600
> MIME-Version: 1.0
boundary="------------3CBD8FAF80764AF3E8CB7F97"
> --------------3CBD8FAF80764AF3E8CB7F97
> charset="us-ascii"
> >> to
> >> the
> >> have
> >> have
> >> apparent
> >> Regards,
> >> Peter L.
> > [Click Here!]
> boundary="------------92827DC271D1EE1B6FB70BEB"
> --------------92827DC271D1EE1B6FB70BEB
> charset="us-ascii"
> <html>
> <a
om/images10.htm</a>
> <br>
> 980
invite
> one and all to
> the
apparent
<br>
&nbs
p; &n
bsp;
> Regards,
<br>
&nbs
p; &n
bsp;
> Peter L.
> be
> <br><a
> <br>-- <a
> <hr>
SRC="cid:part1.387B427B.99EE3931@..." ALT="Click Here!"
er</a>
> </body></html>
> content-disposition: inline; filename="C:\WINDOWS\TEMP\nsmailPL.gif"
> content-id: <part1.387B427B.99EE3931@...>
> --------------92827DC271D1EE1B6FB70BEB--
> --------------3CBD8FAF80764AF3E8CB7F97--
> ------------------------------ message 1618 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1618
> From: "Chuck Merrell" <chuckmerrell@...>
> Date: Tue, 11 Jan 2000 07:25:49 -0800
> MIME-Version: 1.0
> Peter,
> Lemme do a little tidying up here for a minute . . .
> Yves Marie is NOT "ripping" Bolger off any more than two designers who do
> America's Cup boats or IOR designs can be accused of "ripping" each other
> off just because the boats have a similar look. I've known Yves for
thirty
> years. He's about as legit as you can get and probably has about twice
> design practice that Phil Bolger has. Bottom line, he doesn't need to rip
> anyone off, least of all Phil.
> What the story is about Tanton's similar looking boat (to the AS29) I
don't
> know, but you might want to email Yves Marie himself and ask him before
> accusing him of plagiarism. He'll tell you, I'm sure. He's a nice,
> forthcoming guy, and one of the better designers working these days.
> If you're on a scavenger hunt for smoking guns and similar designs, you
> might want to review Jim Michalak's catalog and web site and report back
> the list what you find there.
> Regards,
> Chuck
> CHUCK MERRELL
> MERRELL WATERCRAFT
> P. O. Box 80264
> Seattle, WA 98108-0264
> (206) 764-1298
> Email: chuck@...
> Web Site: http://www.boatdesign.com
> To: <bolger@...>
> Sent: Tuesday, January 11, 2000 1:02 AM
> > Regards,
> > Peter L.
> ------------------------------ message 1619 ------------------------------
> http://www.eGroups.com/list/bolger/?start=1619
> From: tjfatchen@...
> Date: Wed, 12 Jan 2000 02:02:16 -93000
> MIME-Version: 1.0
> BO>Lemme do a little tidying up here for a minute . . .
> BO>Yves Marie is NOT "ripping" Bolger off any more than two designers who
do
> BO>America's Cup boats or IOR designs can be accused of "ripping" each
other
> BO>off just because the boats have a similar look.
> Chuck, in defence of Peter, the study plans appear to go beyond similar
> looks to major concordance in details. Michalak's boats on the other
> hand have a similar look'n'feel, but are clearly their own boats. I
> don't know the person but on the face of it the two designs are so
> similar that Peter's query would seem entirely justifiable.
> Tim Fatchen
> View the full archives, subscribe/unsubscribe, use the
> group calendar at http://www.eGroups.com/list/bolger
> Manage your subscriptions at http://eGroups.com
> Free e-mail groups by eGroups.com.
