Re: St. Valery
Wasn't that covered in Moneyboat a while back? Or am I confused? Oops,
excuse me, I meant Woodenboat.
>Tev wrote:
>I have seen a few references to a water ballasted
>Bolger design called the St Valery, but have not been
>able to find any reviews or detailed descriptions.
>Any ideas where there might be info, preferably on
>line.
>Cheers
>Trev
Thanks. Once prompted, I was able to make out the tracing of the
tilted motor in the WB diagram. St. Valery is quite a complicated
little boat!
Purely as an intellectual exercise, I'm thinking of working out a St.
Valery-type arrangement for the Jesse Cooper hull.
little boat!
--- In bolger@y..., "s_paskey" <stephen@p...> wrote:
> Peter: I've posted a scan of the arrangement to the files section
> of Bolger2 (see "st valery motor mount"). As you'll see, the motor
> mount is attached to a bar that tilts up and back.
Steve paskey
Steve paskey
--- In bolger@y..., "pvanderwaart" <pvanderwaart@y...> wrote:
> The text says the ob can be tilted clear of the water, but it is
not
clear from the pictures and plans that this is so. Is there a
sliding panel in the transom, or does the whole motor lift
vertically, or does it really tilt in the volumn indicated, or does
it
not really tilt? Can anyone clarify?
> Peter
Peter: As I recall from the BDQ article on St. Valery, the boat's
motor mount and well are designed to tilt the motor backward (i.e.
with the prop end pointed toward the bow), rather than forward as is
usually the case.
Steve Paskey
usually the case.
Steve Paskey
> Is anyone familiar with the St. Valery? I was looking at the
article that appeared a while back in WoodenBoat on it and the
Jochems schooner and I have a question about the ob motor well.
not clear from the pictures and plans that this is so. Is there a
it
> Peter
Is anyone familiar with the St. Valery? I was looking at the article
that appeared a while back in WoodenBoat on it and the Jochems
The text says the ob can be tilted clear of the water, but it is not
clear from the pictures and plans that this is so. Is there a sliding
panel in the transom, or does the whole motor lift vertically, or
does it really tilt in the volumn indicated, or does it not really
