Re: free albatros'
Actualy, I'm looking at a 6hp instead of the eight. Only a couple of
pounds, and a couple of hundred more, than the 5hp.
Maybe the Mercury with the high thrust prop...?
--- In bolger@y..., "Orr, Jamie" <jorr@b...> wrote:
> Richard, I expect that's for your Chebacco? I don't know what the
Nissan
> weighs, but I've got a 5 hp Honda (advertised at 60 pounds dry
weight.) I
> wouldn't want any more weight than that back there, and I can't use
more
> than those 5 horses anyway. Also, Bill Samson uses his 4 hp to
successfully
> buck some strong currents in the Tay estuary. You might find a
lighter
> engine is better suited -- cheaper too.
> I should add, I guess, that my 3 gallon tank also sits in the well
with the
> engine, and adds it's weight, but I like the range all that gas
gives me,
> and its nice to have it outside the cockpit/cabin areas.
> Nice "negotiating", there!
> Jamie Orr
> -----Original Message-----
> From: Richard Spelling [mailto:richard@s...]
> Sent: January 14, 2002 7:47 PM
> To: Michalak@y...; bolger@y...
> Subject: [bolger] free albatros'
> Wife had a fit last night when I told her I had decided to fix the
15hp Eska
> in the scrap pile. She threatened to take it to the dump! I told
her they
> would charge her $100 to get rid of it. She then threatened to dump
it off
> beside the road! She ordered me to buy the 8hp Nissan, new, with the
> warrenty.
> Such is life.
> Then, she accused me of setting her up, so she would tell me to buy
the new
> motor! Like I would do that!
> Anyway, I have a 15hp Otasco (Eska) and a 7.5hp Sears motor, with
an extra
> lower unit for the 15hp.
> They are good for parts, though someone with the "touch" might be
able to
> get one or both to work.
> Any takers?
> - add your comments at the TOP and SIGN your posts, snip all you
like
> - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
MA,
> 01930, Fax: (978) 282-1349
> Your use of Yahoo! Groups is subject to
I second Jamie Orr's advice. I have a 5hp Merc on my 2250lb sloop,
and it is more than enough power.
PHV
Richard, I expect that's for your Chebacco? I don't know what the Nissan
weighs, but I've got a 5 hp Honda (advertised at 60 pounds dry weight.) I
wouldn't want any more weight than that back there, and I can't use more
than those 5 horses anyway. Also, Bill Samson uses his 4 hp to successfully
buck some strong currents in the Tay estuary. You might find a lighter
I should add, I guess, that my 3 gallon tank also sits in the well with the
engine, and adds it's weight, but I like the range all that gas gives me,
Jamie Orr
To:Michalak@yahoogroups.com;bolger@yahoogroups.com
Wife had a fit last night when I told her I had decided to fix the 15hp Eska
in the scrap pile. She threatened to take it to the dump! I told her they
would charge her $100 to get rid of it. She then threatened to dump it off
warrenty.
Such is life.
Then, she accused me of setting her up, so she would tell me to buy the new
Anyway, I have a 15hp Otasco (Eska) and a 7.5hp Sears motor, with an extra
They are good for parts, though someone with the "touch" might be able to
Any takers?
Tulsa, OK.
--- In bolger@y..., David Allen <davidallen@i...> wrote:
> where are you located? I'd be interested if you weren't too far.
> da
> > with an extra lower unit for the 15hp.
> > might be able to get one or both to work.
> > Any takers?
da
> Any takers?
Wife had a fit last night when I told her I had decided to fix the 15hp Eska in the scrap pile. She threatened to take it to the dump! I told her they would charge her $100 to get rid of it. She then threatened to dump it off beside the road! She ordered me to buy the 8hp Nissan, new, with the warrenty.
Such is life.
Then, she accused me of setting her up, so she would tell me to buy the new motor! Like I would do that!
Anyway, I have a 15hp Otasco (Eska) and a 7.5hp Sears motor, with an extra lower unit for the 15hp.
They are good for parts, though someone with the "touch" might be able to get one or both to work.
Any takers?
