[bolger] Re: Shrinking Martha Jane
Greg, I've been thinking about the discussion on fairing the bottom of your
Sneakeasy. I forget who, but someone mentioned that they only got about a 1/2
knot increase in speed out of it...
This was on a racing sailboat, probably already going pretty close to hull speed.
A small increase in speed close to hull speed requires a LOT of power. If they
got this from fairing the hull then there was a significant decrease in
resistance.
Also, it's my understanding that within limits power/speed on a planing hull is
relatively linear. A 15 % increase in power (or decrease in resistance) should
give about a 15% increase in speed...
Bottom line, I would guess that a 1/2 knot speed increase in a displacement hull
close to hull speed gained by fairing the hull would equate to several knots in
the Sneakeasy...
Just my 2 cents.
GHC wrote:
> 15% is about the limit before you get worried. I had a problem with my
> freeboard being too low in scaling down my whitehall dory - but it's pretty
> low on that boat, anyway.
> Gregg
> At 08:31 AM 8/27/1999 -0500, you wrote:
> >The general concensus on rec.boats.building is that it's not good to
> >change the size of a boat very much, that it is much better to look for
> >another
> >design in the size you want.
> >That said, all kinds of ratios change. You would probably need to look at
> >freeboard, rocker,
> >beam, and sail/board area. When you rescale something, the surface area
> >changes at the square, and the volume changes at the cube.
> >Probably the best bet would be to write bolger and ask him. Also, out of the
> >hundreds of designs he has, he may have one you like in the size range you
> >are looking for.
> >kahtola@...wrote:
> >> Hi!
> >> Martha Jane looks like a very nice boat, but is a bit too large.
> >> I have been thinking, if it could be made a little smaller.
> >> 15% smaller might be enough. It's lenght would be ~7 metres --> ~6
> >> metres,
> >> and it's beam 1,80 metres --> ~1,5 metres.
> >> What do you think? Is it possible to do, and what should be considered
> >> specially? Could it also be made 9 mm plywood instead of 12 mm?
> >> Cheers,
> >> Teppo Kahtola
> >> eGroups.com home:http://www.egroups.com/group/bolger
> >>http://www.egroups.com- Simplifying group communications
Gregg
>another
>freeboard, rocker,
>are looking for.
>kahtola@...wrote:
>> Hi!
>> metres,
>> Cheers,
>> Teppo Kahtola
another
freeboard, rocker,
are looking for.
kahtola@...wrote:
> Hi!
> metres,
> Cheers,
> Teppo Kahtola
Hi!
metres,
Teppo Kahtola
