Re: AS 29 updates
--- In bolger@y..., "petehodges" <petehodges@y...> wrote:
they are coming from behind the boat then the flat bottom of the
stern makes 90%. Since water is incompressible,when the wavelet
energy hits the bottom, the only escape is for it to move the boat.
energy could escape to the sides more easily.
>If the wavelets are coming from in front of the boat, about 90%. If
> How much of the noise and vibration is coming from the bow area?
>Sound= maybe half? That's a guess. Vibration= much or most of it. The
> In your opinion, how effective would adding the rounded hull with
> multi layers of plywood be in dampening the sound and vibration?
>John
> Thanks again.
> Pete
As to the slapping under the bow, it is *quite* loud, but that is not
as much problem as the shuddering it causes when wavelets vibrate the
whole boat. HARD TO SLEEP THROUGH...
John
Thanks again.
Pete
John
Thanks again.
Pete
> It is aOne builder described it as "not hard, but intricate." - Peter
> pretty complex boat and I don't see it as being quickly buildable.
--- In bolger@y..., Vince and Mary Ann Chew <vachew@v...> wrote:
Thanks much for the info. It is hard to see that there's anywhere
else it could go.
My AS 29 was built 92-94, but not by me- I bought it last spring.
After putting some 700 hours into restoration I'd _guess_ that new
construction would take maybe 1600 hours full-time, or 2000 part-
time, with the usual caveats about level of finish, etc. It is a
The main effect of the specific design on construction is that it
allows a less-skilled builder to do a decent job, but not necessarily
a quicker one.
The builders report to me that the boat cost them, by '94, between
$25,000 and 30,000 US completely equipped (good quality stuff); they
had the masts professionally built which probably raised the cost a
bit.
John
> John,w/car
> John,
> I'm not Paul, but I have the MAIB article in front of me. The new
> arrangement calls for a aluminum extrusion Harken type traveller
> located at the forward edge of the deckhouse.(snip)Vince, Paul,
else it could go.
> How long ago did you build your AS29? About how many hours did itPete,
> take? About how much did the materials cost?
> How noisy is the flat bottom at anchor?
a quicker one.
bit.
John
John,
John,
Im not Paul, but I have the MAIB article in front of me. The new
arrangement calls for a aluminum extrusion Harken type traveller w/car
located at the forward edge of the deckhouse. There is a block on the
boom located a few inches aft of a point vertically above the traveller,
a block at the aft end of the boom, and an eye on the boom about 1/2 the
distance between the two blocks. It is difficult to tell from the
picture whether there is more than a simple two part system between the
forward block and the traveller.
It appears that the aft end of the sheet is fixed at the mizen mast
about 1 foot below the foot of the sail. Bolger says there are various
methods for running the sheet [forward part] aft over or around the house.
Vince Chew
John,
Vince Chew
