Re: selling LED stuff
$75
--- In bolger@y..., "Bill Kreamer" <kreamer@m...> wrote:
> I guess I missed the (estimated?) cost.
> -Bill
> -----Original Message-----
> From: Clyde S. Wisner [mailto:clydewis@c...]
> Sent: Friday, March 08, 2002 8:48 AM
> To: bolger@y...
> Subject: Re: [bolger] Re: selling LED stuff
> Me too, though I can't say that I understand the tech stuff. I can
> follow directions. Clyde
> "Harry W. James" wrote:
> > Well alrighty then, sign me up for a kit.
> > HJ
> > rlspell2000 wrote:
> > > I'm using 16 gauge wire. Max current to the masthead light
(longest
> > > run, highest current) would be about .3 amps. For a 50ft run of
16
> > > gauge wire at .3 amps you loose about .1 volts.
> > >http://www.altronix.com/html/an101.htm
> > > The regulator is adjustable. I'm going to wire up the masthead,
> > > adjust to get 3.6 or so there. Then, should get somewhere around
> 3.65
> > > (depending) on each of the other lights.
> > > --- In bolger@y..., "Harry W. James" <welshman@p...> wrote:
> > > > Well then, how about voltage drop over the wiring resistance,
or
> is
> > > the
> > > > current draw so low that it doesn't matter?
> > > > HJ
> > > > rlspell2000 wrote:
> > > > > Yes. The regulator will take battery power (6v-24v) and
convert
> > > it to
> > > > > exactly 3.6v (or whatever your LED's require, it's
adjustable).
> It
> > > > > will put out around 2 amps of power. The high power LED's
draw
> > > > > about .02 amps (depending). This is 100 LED's, more than
enough
> > > for
> > > > > all the lights on a boat.
> > > > > > Did I understand one of your replies, That this kit would
> supply
> > > > > would
> > > > > > power all LED lights on a boat?
> > > Bolger rules!!!
> > > - no cursing, flaming, trolling, spamming, or flogging dead
horses
> > > - pls take "personals" off-list, stay on topic, and punctuate
> > > - add your comments at the TOP and SIGN your posts, snip all you
> like
> > > - To order plans: Mr. Philip C. Bolger, P.O. Box 1209,
Gloucester,
> MA, 01930, Fax: (978) 282-1349
> > > - Unsubscribe: bolger-unsubscribe@y...
> > > Your use of Yahoo! Groups is subject to
like
Gloucester, MA,
> Yahoo! Groups Sponsor
> ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1818248.3328688.1261774/D=egroupweb/S=17
05
> 065791:HM/A=847665/R=0/*http://ads.x10.com/?
bHlhaG9vbW9uc3RlcjcuZGF0=101
> 5595655%
3eM=215002.1818248.3328688.1261774/D=egroupweb/S=1705065791:HM/A
> =847665/R=1>
like
> - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
MA,
> <http://docs.yahoo.com/info/terms/> .
-Bill
> HJ
> rlspell2000 wrote:
> > I'm using 16 gauge wire. Max current to the masthead light (longest
> > run, highest current) would be about .3 amps. For a 50ft run of 16
> > The regulator is adjustable. I'm going to wire up the masthead, and
3.65
> > > Well then, how about voltage drop over the wiring resistance, or
is
> > the
> > > HJ
> > > rlspell2000 wrote:
> > > > Yes. The regulator will take battery power (6v-24v) and convert
> > it to
> > > > exactly 3.6v (or whatever your LED's require, it's adjustable).
It
> > > > will put out around 2 amps of power. The high power LED's draw
> > > > about .02 amps (depending). This is 100 LED's, more than enough
> > for
supply
> > > > would
like
<http://rd.yahoo.com/M=215002.1818248.3328688.1261774/D=egroupweb/S=1705
065791:HM/A=847665/R=0/*http://ads.x10.com/?bHlhaG9vbW9uc3RlcjcuZGF0=101
5595655%3eM=215002.1818248.3328688.1261774/D=egroupweb/S=1705065791:HM/A
=847665/R=1>
Me too, though I can't say that I understand the tech stuff. I can follow directions. Clyde
> HJ
> > adjust to get 3.6 or so there. Then, should get somewhere around 3.65
> > > Well then, how about voltage drop over the wiring resistance, or is
> > the
> > > HJ
> > it to
> > > > exactly 3.6v (or whatever your LED's require, it's adjustable). It
> > for
> > > > > Did I understand one of your replies, That this kit would supply
> > > > would
> > - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
> > Your use of Yahoo! Groups is subject tohttp://docs.yahoo.com/info/terms/
> the
> > HJ
> it to
> for
> > > would
Wooden mast, will run the wires inside when I make it!
--- In bolger@y..., "rnlocnil" <lincolnr@m...> wrote:
> No reason to use heavy wire, just add a tenth or two to the voltage
> and use light wire! Are you getting a 25 foot run by using the mast
> for return? Connections to aluminum aren't always the most
reliable.
> On the other hand, your masthead fixture is probably going to have
> quite a few bulbs in it, say 10, or 0.2A in all. Still, that's
> less than two tenths of a volt for 22 ga wire. Cheaper way to
> lighten your mast than thinning out the wall and using boron! Could
> save you on the order of half a pound.
> --- In bolger@y..., "rlspell2000" <richard@s...> wrote:
> > Actualy, thanks for asking that quesiton. I'm going to use 14
gauge
> > wire instead, and only have a .07 volt drop to the masthead light.
> > Another actualy, the masthead light is at the top of a 25ft run,
I
> > was using the return figures for a total run lenght of 50ft.
> > So, the number would be half again. 14 gauge would give you a
> voltage
> > drop at the masthead light of .035 volts.
or
> is
> > the
> > > HJ
convert
> > it to
adjustable).
> It
enough
> > for
> supply
> > > > would
for return? Connections to aluminum aren't always the most reliable.
> Actualy, thanks for asking that quesiton. I'm going to use 14 gauge
> Another actualy, the masthead light is at the top of a 25ft run, I
voltage
is
> the
> > HJ
> it to
It
> for
supply
> > > would
So, the number would be half again. 14 gauge would give you a voltage
> HJ
it to
for
> > would
> HJ
it to
for
> > would
Well then, how about voltage drop over the wiring resistance, or is the
rlspell2000 wrote:
> Yes. The regulator will take battery power (6v-24v) and convert it to
> about .02 amps (depending). This is 100 LED's, more than enough for
> would
would
> HJ
> rlspell2000 wrote:
> > I'm thinking of offering a kit for the 3.6v regulator needed for
> > bright white LED lights on boats, as well as the assembled unit.
This
> > would be a high efficiency switching regulator, connectors, case,
etc.
> > Maybe etched circuit boards for mouting LED's on too.
> > I'd be selling them on chebacco.com.
> > Buyers would gain:
> > 1) Known configuration that works
> > 2) Would not need the infrastructure to work with surface mount
> > components
> > 3) Would not need the infrasturcture to etch PC boards
> > 4) Would not need to find sources for the various components.
> > Any thoughts? I would offer the kit for the regulator for about
$75.
> > Anybody interested?
like
Did I understand one of your replies, That this kit would supply would
> bright white LED lights on boats, as well as the assembled unit. This
> would be a high efficiency switching regulator, connectors, case, etc.
> Buyers would gain:
> components
> Any thoughts? I would offer the kit for the regulator for about $75.
> Anybody interested?
You can buy the bulb for $125. Goggle "LED anchor light".
--- In bolger@y..., "petehodges" <petehodges@y...> wrote:
> I would be interested.
> I would also suggest you look at a kit that could be used to
> manufacture a replacement bulb for incadecent bulbs, e.g. a fitting
> that would plug into an existing 12v socket.
> You could even provide a frenzel(sp?) lense that could be used for
> masthead light.
> Keep me informed.
> This
> etc.
> > Buyers would gain:
> > components
$75.
> > Anybody interested?
You could even provide a frenzel(sp?) lense that could be used for a
masthead light.
Keep me informed.
This
etc.
> Buyers would gain:
> components
> Anybody interested?
http://www.deepcreekdesign.com/tristarpage.html
--- In bolger@y..., "Charles Whipple" <ctw-inex@k...> wrote:
> I've been looking for LED navigational lights, so I don't have to
worry
> about changing bulbs for a million hours. Know of any available?
> >From: "rlspell2000" <richard@s...>
> >To: bolger@y...
> >Subject: [bolger] selling LED stuff
> >Date: Thu, 21 Feb 2002 20:49:01 -0000
This
etc.
> > Buyers would gain:
> > components
$75.
> > Anybody interested?
I've been looking for LED navigational lights, so I don't have to worry
>From: "rlspell2000" <richard@...>
> Buyers would gain:
> components
> Anybody interested?
Buyers would gain:
components
Anybody interested?
